Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
KODAK ALL IN ONE 5500 PRINTER KEEPS SAYING PAPER TRAY IS EMPTY
PRINTER WILL NOT GRAB THE PAPER IN THE PAPER TRY, 8 1/2 X 11 NOR 4 X 6 PHOTO TRAY. MESSAGE KEEPS APPEARING STATING PAPER TRAY IS EMPTY. FANNING PAER DOES NOT WORK, 1 SHEET AT A TIME DOES NOT WORK. PLEASE ADVISE WHAT COULD BE WRONG AS SOON AS POSSIBLE
THANK YOU
  • 2 more comments
  • Anonymous Jan 03, 2009
    About 3 weeks ago, this started on my Kodak EasyShare 5500. I found a website that said I should download new firmware for the site. I tried this but it did not fix the problem.
    Harry Sangree
  • Anonymous Feb 18, 2009
    Same problem. Indicates photo tray is empty whether I am trying to copy or print. infuriating.
  • TALynch555 Mar 30, 2009
    my says paper jam but not jamed
  • Anonymous Mar 23, 2014
    "out of paper" message keep coming up after all checks are done!
  • 45 Answers
Shut down everything, printer and computer and try again.
Posted on Dec 22, 2008
I have a Brother DCP 195c and it wouldn't take in other photo papers! I tried to print using the free brother photo paper and it's fine but when I use other inkjet glossy photo, it wouldn't take in the...
Your glossy paper is too smooth for the rubber rollers to grab it.
You need to wet the rubber rollers. Ever licked your finger in order to turn a page in a book? Same concept solution here.
Remove the paper tray. Take a look inside the space created where the tray was, and locate the rubber rollers. Lick your fingers, and use them to moisten the rubber rollers.
Reset printer and print again. Or try "un-smooth" the paper where the rollers grab it.
Oct 11, 2010 | Brother DCP 165C Compact Color Inkjet...
My printer wont take the paper, keeps saying its out of paper when there is a full tray
I have tried to copy a photo on my HP C4600 printer, I put photo under lid in correct place and inserted paper in the correct way yet printer screen keeps coming up paper empty ? what should I do please ? thank you
Aug 10, 2010 | HP Officejet 5610 All-In-One InkJet...
Can't print on photo paper from iphoto
When running a piece of photo paper through the printer you must first remove the stack of regular paper from the tray and run only one photo paper at a time. Thank you, Dana
Oct 08, 2009 | HP Photosmart C6180 All-In-One InkJet...
Printer will not print properly, say photo tray not engaged.
take out the photo tray if you can and put it back into its place /
turn off the printer and turn it back on . if it works fine if it does not ,the sensor is bad .
it gives you this message only if the paper try is not inserted properly or it is a false error message .
Aug 10, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Keep getting message phot tray not engaged
This should not be a problem at all, that message only means that (as it says) the photo tray is not engaged, and so you are going to print on the main tray. This is meant as a warning, not as an error message, and it shouldn't be getting in your way of printing.
Nov 18, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Its saying the paper tray is empty even though there is paper
the problem is with the paper sesor in the paper tray. It must
be under the tray lift mechanism.
This is located in the right front part of the paper tray.
Nov 18, 2008 | Brother MFC-8460N All-In-One Printer
My kodak easyshare5300 is printing black picture
Hi-
If your product is still within the warranty period from KOdak then you can call them up for some step by step troubleshooting to help you with your problem and as well they can replace the printer if defective.
Try this first
Calibrate your printer, then print a demo sheet.
  1. If paper is in the photo paper tray, remove it.
  2. Load photo paper into the photo tray.
    1. Fan the paper to keep the sheets from sticking together. IMPORTANT: Do not overload the photo tray.
    2. Load a maximum of 20 sheets into the photo tray, with the Kodak logo facing up.
  3. Calibrate your printer.
    1. Press Menu.
    2. Select Calibrate Printer, then press Start.
    3. Wait for your printer to print the calibration sheet.
    4. Place the calibration sheet face down on the scanner glass.
      • For the 5300 AiO printer, place the sheet on the front right corner of the scanner glass.
      • For the 5500 AiO printer, place the sheet on the left rear corner of the scanner glass.
    5. Press Start.
    6. Wait until "Calibration complete. Remove calibration page from scanner glass. Press OK to continue." appears on the LCD display.
    7. Remove the calibration sheet from the scanner glass, then press OK.
  4. Print a demo sheet.
    1. Disengage the photo tray by sliding it towards you until it stops. When the photo tray is disengaged, the main tray is active.
    2. Select Print Demo Page, then press Start.
    3. Wait for the demo sheet to print.
Then call them if issue Persist at these numbers:
In the U.S. and Canada: 1-800-421-6699
In Australia and New Zealand: 1800 793 895
Thanks for using Fixya!
Jun 21, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak 5300 wont print on glossy side of photo paper
I just sussed this issue out. On the front of the printer tray there is another pull out tray, this opens up and must activate the photo printing for A4 because it stops the paper falling on the floor once printed (cos once printed on photo paper it may still be wet). As soon as I opened the tray (and it then opens again - you'll see what I mean) it printed A4 photo paper perfectly
Hope this helps others
Feb 23, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
530 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
