Question about Pentax K1000 35mm SLR Camera
Rewind shaft installation
How do i replace a rewind shaft on a pentax k1000?
    Scholar:
  • 185 Answers
Bremerfamily,
to remove the shaft, lift the knob until the film door opens, place a small screwdriver between the prongs and turn the knob to the left. pull the shaft down and out. replace the shaft------ if the new shaft has a notch on the collar just rotate the shaft while pushing back in. if no collar, use a pin to push the spring away while inserting the shaft----- don't force it or you will bend the spring.
Posted on Dec 28, 2008
How do you replace the rewind shaft of a pentax k1000 without causing any damage?
Open the camera film cover back.
Stick a flat blade screwdriver between the silver film sprocket, then turn the Film Rewind Crank out.
atdlee@netzero.com
Jun 25, 2014 | Photography
Asahi pentax sv film advance lever stuck
Without film in the camera it may well read before zero, my K1000, K1000Se, and K2 do that. Press the film rewind button, maybe that will release it for you.
For camera repairs look to:
Eric Hendrickson: http://www.pentaxs.com/index.html
Oct 02, 2012 | Pentax K1000 35mm SLR Camera
The flip up switch to rewind the film has fallen off, I have all the original pieces but cannot fit the bar in. How do I take off the rewind lever to fix it?
Perhaps the following site will help you visualize the fixing. I remind you that these film cameras sell for very little now days and can be purchased for a song. see: http://www.slideshare.net/lokerd/pentax-k1000-35mm-slr
Apr 14, 2011 | Pentax K1000 35mm SLR Camera
My pentax k1000 works great except for when I first load the film. Every time I first load the film, the rewind knob wont rotate when I snap pictures. Everything on the inside is intact and usually I have...
I'm not sure I see a problem here. There is enough slack in the film that the first few exposures can spool out of the canister without it turning. If in doubt, close the back and then _lightly_ turn the rewind crank to take up the slack. Don't force it, just turn it until you feel resistance. Then advance the film and see whether the rewind knob turns.
Feb 28, 2011 | Pentax K1000 35mm SLR Camera
Pentex k1000 rewind knob unscrewed, shaft fell inside camera
first make a small hook on the end of a straightened paper clip. insert the hook and pull up rotating the hook as you pull up. being careful not to bend the spring near the hole. once the back door is opened check the rewind shaft, there should be a beveled edge on the collar of the shaft. rotate the shaft while pushing up. if no beveled edge on the shaft use the paper clip to push the spring out of the way while inserting the shaft. if it still will not return file a bevel on the collar of the shaft. I am assuming there is no film in the camera as the canister will prevent the shaft from falling in.
Jan 29, 2010 | Pentax K1000 35mm SLR Camera
The nob that rewinds the film fell off my camera, and i unfortunately could not find it. Is there anyway to get the film out of the camera before I get a replacement piece?
yes, after dark find the darkest room or closet you can find, make sure no light is coming in around the door. pull up on the rewind shaft to open the back door. remove the film and rewind it into the canister by hand. turning to the right.
Oct 21, 2009 | Pentax K1000 35mm SLR Camera
Pentax K1000 rewinding knob restore
Pentax fan
There is a spring in the way. straighten a paper clip and from the top of the camera push it out of the way while you gently push the shaft up. rotating the shaft helps.
or you could file a little of the shaft collar on an angle ( if it's not there ) then rotate the shaft while gently pushing up. don't bend the spring.
Mar 21, 2009 | Pentax Photography
Pentax k1000
darrenwithey
just pull up the rewind knob.
Mar 13, 2009 | Pentax K1000 35mm SLR Camera
How do I rewind and take the film out of a pentax k1000?
mhamabrown,
push the rewind button on bottom of camera and turn rewind knob to the right, ( clock wise ) then pull the rewind knob up to open the film door.
Feb 24, 2009 | Pentax K1000 35mm SLR Camera
Purchase part
If the threads are not stripped on the knob or shaft, just screw it on clock-wise.
If the threads are stripped on the shaft, it must be replaced, same with knob.
To replace the shaft (if the knob is off) just pull it down in the film compartment. now there is a spring to hold the shaft up or down if the new shaft has a beveled shoulder just turn the shaft while pushing it back up. If no beveled shoulder is on the shaft then with a long needle or pin hold the spring back while pushing the shaft back up. Don't bend the spring. just move it out of the way.
Aug 18, 2008 | Pentax K1000 35mm SLR Camera
Pentax K1000 35mm SLR Camera Logo
542 people viewed this question
Top Pentax Photography Experts
pontelemon
pontelemon
Bill Eager
Are you a Pentax Photography Expert? Answer questions, earn points and help others
