Question about Ariens 34 In. Zoom Series Riding Mower
Snowblower won't start- electric or manual - has only been used a few times and always had difficulty starting it Model 8524
  • Anonymous Jan 20, 2009
    I had the same I pull the recoil with the key "on" or "off"?
Sounds like its flooded. This same exact thing just happened to me.
Let it sit with the the choke off. After a few hours, try starting it again, but don't mess with the choke (leave the choke set as if it was running hot). By your pulling of the recoil cord, you will be helping to clean out the flooded engine. Don not prime it during this excercise. (only pull the recoil 4 or 5 times).
Then let it sit again for a few hours.
After that waiting period, you should be able to start as normal, use the electroic start to get it going and lest it run, as normal.
You should then be all set.
Posted on Dec 22, 2008
My snowblower isn't starting
If it's the starter that makes a humming noise then you need to check the starter out. the gears could be stripped or even a tooth missing so it won't grab the fly wheel. Try pulling the start rope and see if that makes a difference. My Craftsman 8 horse has a recoil starter as well and I quite often use it as well. I don't always use the electric start.
Jan 10, 2016 | Craftsman Snow Blower / Snowblower Bottom...
Brand new snowblower. Engine will not start
Stuck? you mean if you try to use the pull starter the engine will not let you pull the cord out?
Will it not start OR is the engine frozen. help us with your description
Take the Spark Plug out and see if that helps it turn over. Maybe the float in the Carburetor is stuck open and the cylinder filled with gas Causing Hydrolock.
Dec 19, 2015 | Craftsman Snow Blower / Snowblower Bottom...
I have a snapper snow blower model # LE3190E that will never start by the pull cord. But if I use the electric start it starts every time. Why does any one know
Feb 28, 2015 | Garden
Craftsman snowblower Model 536885214 plug in electric start, started, ran few minutes, now turns over but wont start ?
My 8 horse has an adjustment screw on the carburetor Turn it out a little at a time till it keeps running Just don't over do it If you turn out too far you will flood it.
Dec 26, 2012 | Craftsman Snow Blower / Snowblower Bottom...
How to start my snowblower model #247 886911
check gas and oil
put full thottle
full choke
prime 3 times
pull cord or electric start
repeat if doesnt start
Dec 25, 2012 | Craftsman Snow Blower / Snowblower Bottom...
I need a manual
Try Home Depot. They carry a wide range of snowblowers with tecumseh engines.
Jan 09, 2012 | Tecumseh Snowblower Snow Blower Starter...
My snowblower just died 2 years old its an ariens 8524 just sold it to a friend and he said it siezed up no iol is this possible or is there a saftey device on the engine that just shuts it down
there is a low oil sensor that does shut down the motor when the oil level gets to low -- fill oil to the correct height and try and start the machine.
now if the motor is infact siezed up and wont even pull ( siezed piston ) then there is a chance that the sensor failed and the machine did run out of oil and siezed up. if this is the case then the piston rings will need to be replaced.
Feb 02, 2011 | Electric Garden
MTD Snowblower starts good but runs very rough
Carb adjustment. There is usually a HIGH and LOW fuel mixture adjustment on the carb. Sounds like the LOW needs to be adjusted. Do a search on the Internet for a service manual for your particular model/make. Simple job IF you have the manual there for guidance.
Good Luck
Jan 26, 2010 | Mtd Products Yard Machines 158CC Tiller
I can't find my manual for a Tecumsah LawnBoy 824E 8.0HP Electric start snowblower. It starts fine, but does not continue running. I just filled the tank with new gas. It ran to run about 25 feet and then...
Sounds like a clogged carb which is a common problem for snowblowers due to they set around more then they get used and gas turns stale and clogs carb. Most of the times the problem is in the bolt that holds the carb bowl on it should have 2 or 3 small holes in it. Check that the holes are all open and clean if this does not help you will need to remove and clean whole carb.
Please vote
Jan 07, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
Ariens 34 In. Zoom Series Riding Mower Logo
468 people viewed this question
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Paul Sikkema
Paul Sikkema
Are you an Ariens Garden Expert? Answer questions, earn points and help others
