Question about Hampton Bay 54 In. 5-Blade Fan, Chestnut, Autumn Mist
Reverse module not working
I have a ceiling fan that has lost the intensity of the bulb, I changed the bulb twice and still the same problem. At the store I was told the transformer was broken. I looked inside the fan and found the reverse module Type B from Rhine company#UC7067REV. Can't find a company in USA to buy it. I only found the company who makes them in Taiwan. Is there some one who has them in USA?
  • 1 more comment
  • myrna_sanche Jan 07, 2009
    I guess I will buy the new fan. Thank you.
  • Anonymous Jan 14, 2009
    I can't get my lights back to a brighter density.
  • Wally-Tonya Czyz
    Wally-Tonya Czyz May 30, 2017
    Why not just solder in a new capacitor and problem solved?
Would you sell me the remote for that fan?
Posted on Mar 11, 2010
    Sergeant:
    Champion:
  • 239 Answers
Will be cheaper getting a new fan!
Posted on Jan 04, 2009
I need a replacement part for a rhine pl-190B
A PL-190B ceiling fan module is is a Wattage Limiter rated at 190W maximum. It is about 1" square and has a red, blue and white factory wired into the fan's light circuit in most cases. The AC power to the lights is run through the module to "ensure" no one puts more than 190W (about 2 amps)of light bulbs through the circuit for "safety" reasons. So four 60w bulbs and some CFLs will trip the module. These wattage limiters are sometimes feeding the fan motor in addition to the lights, however the units I have seen just control the "blue wire" going to the lights.
Some suggest simply cutting it out and splice the blue and red wires (or blue and blue) that are left in the fan after removing out the module. If the module has two whites, wirenut them together separately. Otherwise just insulate or cap the single white.
At that point your ceiling fan and lights are like all others made before 2005 and depend on the circuit breaker and you to only use four 40w bulbs max in the fan. As indicated, some low wattage CFLs will also trip the module. Some internet sources have the PL-190B available for around $15.
Dec 31, 2013 | Hampton Bay 24002 Ceiling Fan
Can't removed the glass to change light bulb!!!!
Try using an oil filter band style wrench wrapped in a towel.
It it breaks,that's OK-you won't get bloody.
Mar 02, 2013 | Casablanca Fan Stealth 3211T Ceiling
Hunter ceiling fan 22450 no reverse switch manual says there is.
The reverse switch usually is in the lamp housing directly under the motor. With a vaulted ceiling installation, you would need to use a ladder to get access to the switch
Jan 04, 2013 | Hunter 52" Ceiling Fan With Light And...
Hampton Bay
the lamp bulb or halogen lamp module has reached the end of its serviceable life, not because of any wiring problems. Low beam burns out first because it is on the most. If low beam is lost simultaneously in both headlights, I would check fuse first, then the headlight switch. If low beam is lost on one side only, it is almost always going to be due to the bulb or lamp module needing to be replaced. In that case, replace them in both headlights because the other one will be going kaput in short order, as well.
ceiling light
Jun 06, 2012 | Dryers
My Callaway II ceiling fan transmitter shows that air is being pushed down. However, the ceiling fan is actually pushing air upward. I've tried everything I can think of to get the transmitter and...
If I recall, this fan has no external switches that can be operated - all of the fan and light functions are controlled by the remote alone. If this is indeed the case, there is little that can be done outside of hoping the problem is with the remote itself. If that is the case, replacing the remote is likely to be cheaper and less labor intensive - that is if you can find one.
From what I have read, this fan is no longer in production nor available for purchase. You may have luck bringing the remote to Home Depot - the main (possibly the exclusive) distributor of the Hampton Bay brand to see if they have fans on display that make use of remotes for fan and light control. If so, try to see if all your remote functions work. If you find that the reverse function no longer works - you should ask the sales associate about how to go about ordering a replacement remote. If the remote fails to work at all, you can 1) try a "shot in the dark" about ordering a an exact replacement remote - with the hopes that the remote itself is defective - rather than the paddle fan, or 2) start new by buying a new paddle fan with hardware switches for fan speed, direction and light operation AND a remote control module to perform a whole replacement of your existing paddle fan.
The "add on" remote control gives you many of the benefits of the remote only fan - but also provides a "back up" way to operate the fan should the remote or module fail. Had this been the style you have currently, you could operate the fan by hand until the remote and / or ceiling module was replaced.
I hope this helps and good luck. Please rate my reply. Thank you.
Jun 01, 2011 | Hampton Bay 46056 Callaway II Ceiling Fan
Ceiling fan capacitor hook up problem. I have a 3 speed fan. 4 switch. A 3 wire capacitor - CBB61. Kids lost wiring diagram. Any which way I try to wire it up only one of the speeds works. Any wiring...
The reverse switch on my Hampton Bay ceiling fan didn't work. I cut the 6 wires; 1 white, 1 gray, 2 pink, 2 yellow. Here's what I did. Removed reverse switch. Had 6 wires white, gray, 2 yellow, 2 pink. Connected gray to yellow, connected white to pink and fan runs fine. Is this OK? I do not need to reverse fan. It's been running for 1 hour now with no problems. Don S.
May 15, 2010 | Dryers
Question about light bulb problem in ceiling fan
Check wiring @ ceiling. Should b a black, white, green & red wire coming frm fan. Green is ground. Black & Red is power. White is neutral. Black provides power to fan, red provides lat power 4 lights. Remove light assembly, blue wire provides power. B sure 2 turn off power 2 fan b 4 working on it w/switch & breaker. Maybe lose wire connection or pinched wire grounding out. Fans require vibration proof bulbs regular bulb elements will break after short time use. Fan bulbs have larger filiments inside bulb.
Aug 23, 2009 | Aloha Housewares (93645) Ceiling Fan
Can't find switch to reverse direction (24002)
I found a pdf of the manual on "KingOfFans.com" and there was a graphic showing the location of the switch. It is on top of the motor underneath the small bulbs in the top section of the fan. It is really rather difficult to get to and not the best design but I found it and it worked.
Jun 11, 2009 | Hampton Bay 24002 Ceiling Fan
Can't figure out how to reverse the Hampton fan with the remote
I have the Hampton Bay Windward II Ceiling Fan SKU 523-127. I have replaced various parts over the years including the ballast, light shade, 9" 30 Watt Circline bulb and the remote.
Hampton Bay Windward II Ceiling Fan SKU 523-127 was sold by Home Depot, and manufactured by King of Fans.
King of Fans website is: http://www.kingoffans.com
This fan can be seen by clicking on Products --> Ceiling Fans --> Click on page 9 (at the bottom of the webpage) then click on the Windward II fan picture, then you will be able to click on Download Owner's Guide.
Mar 11, 2009 | Dryers
Change light bulb
I have a fan just like that one to change a light bulb all you have to do is unscrew it from the fan itself and if that dosnt work then unscrew the plastic cover or unscrew a screw on the plastic cover
Dec 30, 2007 | Madison Avenue 04889 Hampton Bay Ceiling...
Hampton Bay 54 In. 5-Blade Fan, Chestnut, Autumn Mist Logo
1,654 people viewed this question
Top Hampton Bay Dryers Experts
Craig Butler
Craig Butler
Steve Allison
Steve Allison
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
