Question about Dell 1110 Laser Printer
Dell 1110 Laser Printer Solid red warning light
Hi there, we had a paper jam, cleared everything ( I think) but the solid red LED stays on. I'm not able to access the online manual, can you tell me why the light stays on? Thanks! Lee
  • purepoint Mar 31, 2009
    Paper is jam in the printer. I removed the toner but cannot free the paper? I need help?
The first thing to do on any Dell laser unit is to reset it. On the 1100/1110 just hold down the cancel button while flipping the power switch on. Keep holding it until the green power LED and the red exclamation LED flash alternately. Flip the power switch off and back on again. The unit has now been reset, if the exclamation light is still on, try something else. If it's not, you're welcome. =)
I just fixed one of these here in the office a few minutes ago with just a reset. It previsously had the red exclamation LED on solid. Always reset these 1100/1110s first. They can be cranky sometimes. =)
Posted on Oct 26, 2011
  • 191 Answers
Hi in this case the paper jam made some sensor through the paper road they are not in normal position or still tigger on by piece of something or error stander. you may try:
1) check paper input sensor near paper tray roller\
2) check margin sensor inside paper way before drum unit
3) check fuser sensor near fuser unit
4) check paper output sensor near output tray roller
sometime need sensor adjustment back to normal position
Posted on Dec 22, 2008
Dell1110 Laser Printer. Changed Cartridge - New Fuse - Checked twice Simpson 260 No blown fuses on circuit board. (1) Fuse, (2) wire. No burn spots Red & Green lights blink after 10 sec of OR/GR...
If you have flashing RED and GREEN LEDs on your Dell 1110 your printer will need servicing by the Dell service department. It is hard to say what is wrong without looking at the printer in person but those two lights together spell trouble not easily fixed. It could be a damaged circuit board or component. This typically has nothing to do with ink, paper jams, etc.
Regards, Chris
Aug 17, 2011 | Dell 1110 Laser Printer
I have a MacBook, and a Lexmark E232 laser printer. It has worked fine for several years but all of a sudden when I try to print the light for the light for a paper jam comes on. I have cleared it, and...
The problem is that the printer thinks that there is a paper jam inside the printer. What could be happening is that there was a paper jam the paper was pulled out but the actual sensor that detected the paper probably got damaged, either broken or malfunctioning. In this case try the following, turn off the printer and open the front cover. Then press and hold down the two front buttons while having the cover open and turn the printer on. Then wait untill the bottom light stays on solid then release the buttons that should reset the printer. If after that the paper jam error does not go away then you are probably looking at a damaged sensor. To fix that you will have to take it in to have it service.
Hope it helps.
Mar 19, 2010 | Lexmark E232 Laser Printer
Dell Laserjet 1110 that won't print. Red light is on steady
When power on if your printer is red light>insert paper in tray.If red light is not go green.then you can get a decision paper sensor missing or paper jam or any sensor displace,check it .If you are not fix this problem,please open cartridge and insert again also the same problem.may be is fault fussier unite.please call a service technician who is expert this printer.
Dec 14, 2009 | Dell 1110 Laser Printer
Status light solid red not printing
Press the menu button for 20 sec and then try to turn on the printer
Sep 15, 2009 | Brother HL 5140 Laser Printer
Samsung printer ml 1510 red light flashes after self test
Red Error Light Stays On The following conditions can cause the On Line LED to glow solid red:
  • Printer paper is jammed inside your printer.
  • A cover is not be closed properly.
  • The toner cartridge is not inserted properly and needs to be reinstalled.
  • The toner cartridge is running low.
  • There is no paper in the paper tray.
  • The paper inside the paper tray is not be installed correctly.
Red Error Light Blinks If your printer's On Line LED is blinking red, your printer's toner is exhausted and needs to be replaced. On Line and Error Light Blink Simultaneously
If your printer's On Line and Toner Save LEDs blink simultaneously, your printer requires service.
You can go to samsung online service request http://www.samsung.com/us/support/repaironline/supportOnlineServiceRequest.do
Mar 21, 2009 | Samsung ML 1510 Laser Printer
HL-5140 Brother laser printer red status light remains on.
The red lite indicates one of the following needs to be looked at:
Cover open (Front cover) Close the front cover.
Cover open (Jam clear cover) Close the jam clear cover of the fuser unit.
Memory full - Press the go button.
Print overrun - Press the go button.
Clean drum unit - Clean the corona wire.
Jan 15, 2009 | Brother HL 5140 Laser Printer
Paper Jam
from fixya knowledge base I found this solution
1. Power Unit off
2. Open front cover
3. Press and hold GO and turn power on
4. When all 3 lights lit release and press GO twice
5. All lights turn solid
6. With all solid, press GO 5 times
7. Ready light GOes red
8. Close door and you're all set
Let know if working and don't forget to rate solution
Jan 11, 2009 | Brother HL-2040 Laser Printer
Yellow light on and won't print on Dell model 1110 Lazer Printer
Dell printers are the worst I have worked with, this problem may be a 'paper jam' when there is no paper jam at all (or one REALLY stuck on the fuser). Check on the back of the printer for a piece of paper jammed on a sensor.
Dec 14, 2008 | Dell 1110 Laser Printer
Samsung ml 2010 r laser printer
Check your manual, there is a solution there or download the user guide from
this site below or read the information below.
http://downloadcenter.samsung.com/content/UM/200602/20060216163720484_ML-2010_English.pdf
LED pattern Possible Problems and Solutions
Your system has some problems. If this problem occurs,
contact your service representative.
On Line/Error LED
lights red
• Paper jam occurs. To solve the problem, see “Clearing
Paper Jams” on page 5.6.
• The front cover is open. Close the front cover.
• Paper tray is empty. Load the paper in the Tray.
• The toner cartridge is out of toner. Remove the old toner
cartridge and install a new one. See “Installing the Toner
Cartridge” on page 2.4.
• You pressed the Cancel button while the printer is
receiving data.
• In Manual Feed mode, there is no paper in the manual
tray. Load paper into the manual tray.
• If the printer is receiving data, the On Line/Error LED
slowly blinks green.
• If the printer is printing the received data, the On Line/
Error LED blinks green fast.
Jul 17, 2008 | Samsung ML 2010 Laser Printer
Can't print - paper light is on
turn the printer off, count to ten, then note the light sequence ie: flashing organge solid orange, flashing green or solid green
Jul 25, 2007 | Brother HL-5250dnt Laser Printer
Dell 1110 Laser Printer Logo
9,229 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
