Question about Samsung HT-DB600 System
Generic remote control
The remote doesn't work and I haven't been able to use a "generic" Does somebody know the number codes to input in a generic remote? thanks
  • bethen69 Sep 07, 2008
    I have a new dvr player from cox cable. My remote for the dvd player has never worked and I would like a list of codes so I may program the dvd player and dvr to work from the same remote. (cox)Is this possible? Thanks, beth
    President:
  • 3,130 Answers
Remote transmitters have to have the program in it for the device you are trying to use it with, and the codes simply retreive the progrom, so there are no codes to install as it simply cannot be done. An original replacement can be gotten here: http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&m1=HT-DB600&uid=11758875673120, or the original remote from Samsung is less expensive and can be gotten here: http://www.samsungparts.com/part_detail.asp?catalog%5Fname=Parts+and+Accessories&product%5Fid=AH59%2D01169L&search%5Fmodel=HTDB600 Good Luck
Posted on Apr 06, 2007
I have a 1997 admiral TV model number jsj12305 serial number 538259. I need to know how to change the input so that my Dish will work again.
You should have its remote control to select the inputs.
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops.
Aug 13, 2014 | Televison & Video
I need to use a RCA remote to program a DVD and with out the codes and program a tv
Try writing to RCA Customer Service to see if it is a: feasible, and b: doable if they send you the right codes. If they elect to play ball, and they might if you offer to buy a new one as well, you will get a sheet of microscopic print that lists several paragraphs of models which will accept a particular set of codes you program into the remote, and then try that combination on all of your equipment, then try to next code on the list, ad nauseum, until you accidently find a combination that works. I have (eventually even gotten old, old equipment working in that way, including an off-off-off brand tv with all of the buttons on the front removed (toddler time) including the power button. Using some obscure setting for a generic remote that cost all of five or eight dollars gave me power on/off, volume, channel up-and-down, direct channel entry, input selection, and even a feature I did not know the tv had, a timer to have it shut itself off after a programmable number of minutes. If you have no such luck getting such a sheet of codes from the maker of the remote you want to add new functionality to (presumably, your existing remote does things that a "generic" remote may not, like setting gamma levels, color temperature, and muffler belt tension) which is the only good reason to hold onto it RATHER THAN FORK OVER FIVE OR TEN DOLLARS TO BUY A GENERIC REMOTE THAT WILL DUPLICATE THE CONTROLS YOU HAVE AND LET YOU CONTROL OTHER DEVICES AS WELL. I even have an extra one I could sell you, except it would cost more in postage than it would take to go to Walgreen's or KMart and buy a generic remote (with the pages of microscopic type listing suggestions of from one to several dozen possibilities for a CD player, a cassette tape recorder/player, a vcr, a tv set, etc. and you just put aside an afternoon to try entering different numbers for that remote with a given component, then trying the next number, and so on. Eventually you should hit something that works; write that "combination code" down, and move on don the line, determining what make of VCR you have, looking at that paragraph of codes, sighing deeply, and beginning to, again, trying code after code, attempting to "do something" with the remote after punching in a particular code, and then starting over with the next number. For $150-$400 yon by remote which not only let you manually program setting in this way, but also will try a series of attempts automatically until it finds a set of commands that "work". Best of all, if you have the original remote(s), for under $500 you can buy univeral "learning" remotes, that will take ALL your remotes, like the one you are holding, tell the Universal Remote what your programming, i.e. a VCR, and place the two remotes head-to-hear and press and hold down the fast-forward button on the "old" vcr remote, while simultaneously storing the correct "codes" into the "new" remote, then hitting save, and from that point on, your tablet or monster remote will control you VCR; then you perform the same steps with your stereo amplifier(s), receivers, phonographs, etc. The you can take all the batteries out of the remotes that came with each unit, and tape them securely to the face or back of the remote (so that you can use the remote to re-program the big remote again) and in that way you keep the battery from corroding in place due to inactivity and the eventual breakdown of almost any battery if given too much time: the same chemical reaction that makes the battery useful later, after not being able to power a device properly, goes "dead' and then, gasp, starts corroding away the metal springs and tabs in the battery cell cavity on the back or side of the remote. Try the $5-$10 remote idea first, and if that doesn't do it for you, consider if your setup would benefit from a big-time "universal" remote, with fancy color screens to show you what device it is currently controlling. Good luck.
P.S. I eventually wrote down the settings for the tv, teh stereo receiver, the cd player, the vcr codes, etc., on a cut-down 3x5" card, covered with wide package sealing tape, on the back of the el cheapo remote, so that I could look at the back, and know that if I was going to use it to control the TV, I had a four digit number written down which, after pressing a certain key on the front of the remote, followed by the special code that transformed the remote into a tv remote ("3145") and then the equivalent of an [enter] key. Then I had a tv remote. to turn the stereo, I would look at the back of the remote, flip it back over, enter a code ("8989") and the channel up and down buttons would let me traverse the radio dial, etc, and best of all, the volume and tone controls are right back at your fingertips. Enter a new code to start up the cd player, skip to a certain song, then turn the remote back into a controller for the receiver, etc. There are probably apps that do this for the iPad, maybe Android devices, perhaps even iPhones or SIIIs camera/phones/mp3 players. Good luck, have patience,as you will only have to do these steps of "code discovery!" once if you have a chart and write down the winning codes)!
Oct 09, 2012 | Televison & Video
Prgram old RCA removte
I also have an early RCA universal remote with the number 97P04730 stamped on the battery cover. I do know if that is the part number for the remote. There are buttons labelled TV and VCR, presumably to select which device the buttons will work for. This remote has a "search" button, but no "code search" button that is found on later RCA remotes. I have spend several hours searching the net for any information on this device. The only thing I found was a post that claimed this early remote is programmed by pressing and holding the device button (TV or VCR) and simultaneously entering the device code. Because this is a very old remote, it probably uses 3 digit codes. There are several places that list RCA 3 digit remote codes. I have tried to program mine this way, but I have not been successful. Possibly my remote is not working correctly, but it is putting out IR.
Jan 29, 2012 | RCA Universal Remote Control
What is the code for an apex digital converter box?
Hello
You haven't specified the exact model number of your RCA remote control. Three device remotes for RCA is in many model numbers. If it is RCA Systemlink-3 remote control, there is no setup code for Apex Digital Converter Box. OK.
Oct 21, 2011 | RCA 3-Device Universal Remote
I cant figure out how to put the tv on video 1
With the remote in TV mode, the input button on the remote should change the source (TV, AV1, etc. depending on the TV).
If the input button doesn't work, try a different code for your TV manufacturer. A code that controls the basic functions of the remote may not control the full set of functions of the TV. For some TVs, you can change the source from within the Menu. (It depends on the TV. I didn't notice if there was a Menu button that will open the TV menu on the RCA RCU600M.)
If none of the codes work, check if your TV has a Source or Input button on the unit. See if that button works.
If you have a different remote, please indicate the model.
I hope this helps.
Oct 13, 2011 | RCA RCU600M Remote Control
The code of my home theater (Sony BDV-E570) listed in remote manual ( Kamaleon URC-9960b01) doesn't work. Do you have the right one?
Hello
That is I wonder about your problem post! No universal remotes have the codes for Blu-Rays so far. You haven't try for that. You can synchronise other devices like TVs, VCRs, DVDs and so n, but not with Blu-Rays. The remote control you posesses now is one amoung the greatest one universal remotes we can get from market. Not waste your time for this purpose. Try to get its original number remote control from Sony. Just contact the nearest Sony Authorised Service center. They can provide you the original number remote handset. If you don't know the number of the remote control, isn't matter, just give them the exact model number of your device. OK.
Aug 05, 2011 | One For All Kameleon URC-9960 LCD...
Do you know the sky+ remote code? So I can operate the volume control on the sky+ remote. I've tried loads already hope you can help.
It would help to know the model number of your LG TV. However, you can try the generic codes for LG which I've listed here:
Rev 8 remote: 1293, 1206, 0206, 0065, 0904
Rev 6 remote: 0065, 0742, 0502, 0672, 0634, 0136,
Rev 4 remote: Same as Rev 6
RC1600/00 remote: codes not available and unlikely to work with your TV
** Your Sky remote version can be found on a sticker inside the battery compartment. **
Try these codes but if they don't work, please post back with your TV model number. It's possible that your remote does not have a code which will work with your TV, in which case, you will need to use the remote supplied with your TV to control volume and power functions. Unfortunately, when a TV is newer than the remote and uses a new flash pattern not programmed into that remote, the remote wont work. However manufacturers often keep the same flash patterns for common functions, so the generic codes might work for you.
I'm informed that a new Sky remote version is due but I've not been able to confirm this yet.
Hope this helps - please post back if you need further assistance.
Regards,
BElectric
Nov 25, 2010 | LG Televison & Video
I need the tv code number to get my remote
give me the brand tv so i can give yu the code numbers
Nov 15, 2009 | Universal Remote Control URC-6131N Remote...
Need the RAV-300 Remote Control Setting Steps
RAV311 WJ40930 US
(1) To program the remote to control a TV, press and hold [TV] for at least 5 seconds. To program the remote to control any other device, press and hold [AV] and the desired input button, (i.e. Press and hold [AV] + (DVD) at the same time for 5 seconds for a DVD player.
(2) Enter the 4 digit code for the device
Hope this helps.
Jan 08, 2008 | Yamaha RAV-300 Remote Control
Samsung HT-DB600 System Logo
535 people viewed this question
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
