Question about Dell Dimension 2400 PC Desktop
Dell 2400 wont recognize harddrive
My friend brought me this computer that would not recognize the hard drive. I figured it was bad so I got a new drive and it still will not recognize the drive. I have been reading about f2 setup mode and a driver that needs to be installed. I cannot locate any issue within the bios or the driver on dell's website.
Thanks
  • Dell Master
  • 5,568 Answers
I don't know how old the Dell is but I have not seen a BIOS setup routine that did not automatically find and recognize a new hard drive for many years. Perhaps the BIOS is the source of the problem.  Did you try the removed drive in another system? Did you check the CMOS backup battery? If this needs to be replaced, it may not recognize much of anything.
Posted on Dec 22, 2008
Wont see slave Hard Drive in a Dell Dimension 2400
Did you set the Master harddrive as master?
Or is your reference that you set the jumper cap, on the jumper pins; of both harddrives to Cable Select?
What are the manufacturer names, and model numbers of the two harddrives?
If you just see something like - WD2500JB, that will work.
How many wire is the Flat IDE ribbon cable?
There are 40 wire versions, and 80 wire versions.
Notice I stated - Wire.
They will both have 39 socket holes that are used.
(40 socket holes, with 1 blocked off)
80 wire IDE ribbon cable has Master harddrive in middle.
Slave harddrive at end of cable.
Little weird, huh?
40 wire IDE ribbon cable, has Master harddrive at end of cable, Slave in middle.
As for, "Computer will not see it."
Not trying to insult your intelligence. Am trying to see if we are both on the same page.............
1) You go to My Computer, and there is no drive letter assigned to that harddrive you just installed?
If it is there, you double-click on it to open that harddrive.
Please post back in a Comment.
Regards,
joecoolvette
Mar 30, 2013 | Dell Dimension 8400 PC Desktop
Hardrive is unknown device in bios
The BIOS determines the maximum size hard disk the computer can support.
The max hard disk size for this model Dell is 80Gb.
To use your 250Gb hard drive, install this Hard drive into an USB hard drive case and use it as an external USB hard drive.
Mar 09, 2013 | Computers & Internet
Where is harddrive located in 2400 series
here is the detailed instructions for locating removing or replacing hdd from your computer https://support.dell.com/support/edocs/systems/dim2400/en/sm_en/drives.htm
Jan 23, 2012 | Dell Dimension 2400 PC Desktop
I got a new hard drive for my dell dimension 2400. I have tried everything I know to do, jumpers to cable select, master. I know the hard drive works as I hooked it up along with my old drive and cloned...
Enter the BIOS (setup menu on power on) and then holddown the key and depress the then the keys insuccession. This will force the motherboard to load default settings and alsoforce the motherboard to redetect all IDE devices. Note: The selection for thefloppy drive will be set to ON. If you do not have one then you must disablefloppy in set up (BIOS) menu.
Aug 27, 2011 | Dell Dimension 2400 PC Desktop
Vista can't detect my hard drive
Is it a new hard drive? if so many harddrives come blank and you will have to format it before any computer will recognize it. It is probably just unallocated.
Nov 18, 2009 | Dell Inspiron 531s Desktop Computer
External Harddrive not recognized.
perhaps this new computer has usb 2.0 while the old dell was of older standards.check whether the external hdd supports usb 2.0,,if it do so,,buy a usb 2.0 cable and start using it.best of luck
Jan 16, 2009 | Western Digital Caviar SE WD5000AAJB -...
Dell Inspiron E1505 won't boot
Try this site to look for hard drives. Not just any drive will work, so make sure you confirm with the company's sales or tech support to make sure it'll work.
LINK
Dec 11, 2008 | Hitachi Travelstar 5K100 HTS541060G9SA00...
Trying to install a new sata harddrive but win xp does not recogn
check bios and set the parameters for the new hard drive. These parameter should be found on the hard drive itself
Dec 10, 2008 | Dell Computers & Internet
Dell 600m says no bootable devices! wont load xp?
it is not recognizing your harddrive you will need to make sure that your harddrive is connected properly then boot into bios and under the ide section have the computer check for the harddrive if it finds it there then save and exit and reboot please keep me posted on this i can help you further if needed regards mike
Aug 19, 2008 | Computers & Internet
Replaced hard drive
try connecting it as slave and after rebooting the system, your harddrive may be recosnise by the system. after copy the data and format this HDD in low level.
Jul 29, 2008 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 PC Desktop Logo
254 people viewed this question
Alun Cox
