Question about Bosch Washing Machines
My Bosch washing machine is spinning the clothes, just not as fast as it used to, I think, and items coming out still soaked. I did put a floor rug in that had alot of fuzz on it...don't know if that is related...Tried the spin cycle again...to no avail
  • Bosch Master
  • 3,463 Answers
Sounds to me like the filter needs to be cleaned.
It is located behind a removable plastic panel at the front of the m/c, on the right usually.
Remove and clean, unscrew it anti-clockwise.
The other possibilityis that the brushes are worn in the motor, but you would have to remove the motor to check these, so try the filter first.
Plz rate my solution.
Thanks.
Posted on Dec 22, 2008
Hotpoint WF250 clothes coming out soaking wet after spin?
The fast wash cycle is for a reduced capacity load of approximately 3kg , it does not pump or spin long enough for a full capacity load
Jun 15, 2016 | Hotpoint Washing Machines
Why do all loads in our Top Load HE Washing Machine - Model # WT5070CW - stop because of UNBALANCED LOAD ERROR?
1st check ur floor level if the floor level is not flat means sure the error will come.. and dont put a blanket with other clothes
Feb 26, 2015 | LG WT5070CW White Top-Loading Washer
What will cause my Whirlpool washing machine to set on low speed spin cycle?
The machine uses automatic load sensors to balance the load and when you put something in the machine that is big, like a comforter, it knows that it cannot balance that item. So with a front loader it wont spin at high speed because it would be off balance and either damage the machine or the machine would "walk" because of the off balance motion.
Apr 28, 2014 | Whirlpool Washing Machines
My Bosch next 300 washer doesn't spin as fast as it did. It leaves the clothes wet and some water in the drum. No error code comes up? How do we fix it?
If the tub still moves but it's just not spinning that fast (and the water is draining out), then that means your motor control board has just started to fail and it will need to be ordered and replaced to fix the issue. If you pull the washer out and remove the back panel, there is a control board mounted to the floor under the tub. This is the motor control board and it will need to be ordered and replaced to fix the issue.
Oct 28, 2012 | Bosch Nexxt 300 Series WFMC2201UC
Fills with water then does not rotate, also does not spin
Check for large items of clothes being tangled if the Bosch washing machine doesn't spin. The weight could not be evenly distributed in the drum and the spin cycle will have been disabled to prevent damage to the clothes..
Load the drum with large and small clothes together and run the entire washing cycle and spin cycle again.
Add more powder and run the entire washing and spin cycle again if you haven't found tangled large items, but the spin cycle still failed. This indicates the amount of cloths was too small.
Add 1 tablespoon of fabric softener to 1 pint of water and pour it into the main detergent dispenser if there's no tangling and the load was a normal size. The cause would have been excessive suds because of too much, or the wrong kind, of detergent. Use HE (High Efficiency) detergent in Bosch washing machines.
Nov 01, 2010 | Bosch Washing Machines
When I put towels or rugs in the washer the cycle show complete, but when I open it the items are soaking wet.
Its probably because the items are too heavy for the washer to safely spin.
If you squeeze some of the water out of them into a sink then put it on spin cycle, it should work. Otherwise spin them in two loads. Its a bit of a pain but its to protect the washing machine mechanical parts.
Hope that helps!
Dec 29, 2009 | Kenmore 43142 Front Load Washer
Clothes coming out of washer still soaking wet
is it a kenmore top load?if so the motor is not kicking in to 2nd gear for high fast spin,does it have a speed control on the head?are you using it on the reg. wash cycle?-mike
Apr 18, 2009 | Washing Machines
Rugs won't dry
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} There is a round door on the lower front of the washer. There is a small hole near the door. Put a small screwdriver blade in the hole, push in just a little, and you can rotate the door clockwise, the door will come out and you can get to the problem.
Immediately facing you is a black connector, about 4 inches (10cm) in diameter. When you unscrew this, all the water left in the washer will spill out onto the floor. Use a plastic bag to catch this or a small pan.(later models have a drain hose?) The black connector unscrews counterclockwise, and takes quite a few turns. Once you have it out, you'll find the source of your clog. Remove it, clean out, screw the black connector back in. You can check with rinse, if you want to make sure there are no leaks. Put the door back on and rotate.
Pl rate me 'very helpful' for the free help, thanks!
Jun 22, 2008 | Bosch Classixx WFL 2066 Front Load Washer
Washing machine
This deffenitly could be the brushes. Wierd sound normally comes from the electric sparking between the stator and the brushes. If it are not the brushes the best bet will be the bearing.
May 13, 2008 | Bosch Classixx WFO 2466 Front Load Washer
Samsung P1253 washing machine doesn't spin fast leaving clothes wet
I found a solution on another site. At first I didn't think it would work, but it did....
The samsung washer is very sensitve to balance. Although you may feel you have all of the feet tight to the floor....run the spin cycle, as it runs up to the middle speed, watch each foot closely, one of the feet will lift up and down just a tiny bit (or more)
Lift that corner slightly and Tighten that foot. Continue to run the spin and watch the feet, make sure none of them move at all.
Mine immediatly went up to the faster speed and wrang out the clothes like it did the first day i got the machine. Once done, be sure to LOCK the feet with the ring at the top.
good luck!
Jan 12, 2008 | Washing Machines
Washing Machines Logo
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
