Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer
My control panel is reading "control locked". How do I turn this off???
  • Anonymous Jan 05, 2008
    none of the buttons work when pressed
    locked on normal wash
  • madjen17 Jan 15, 2008
    My washer is stuck on "control locked" and the only way to turn lights on is by holding cancel then control on...but i still cant change anything on the screen to do the reset i read to fix it! I even unplugged it for 10 minutes
Push end of cycle signal button(it's the last button on the far right)
Posted on Sep 05, 2007
EXCELLENT & SIMPLE SOLUTION -- THANKS! Philip from Toronto
Posted on Sep 03, 2007
Press the end of cycle indicator button for a few seconds.
Posted on Apr 14, 2007
  • Soccermom73 Jul 11, 2011
    Thank you for your help!
4 Suggested Answers
SOURCE:
  • 32 Answers
SOURCE: Control lock light on
take a good look on control panel i don't remember which button you should push and hold for 3 for 5 sec. to lock or unlock control panel (it also called child lock) let me know it help or not. thanks....
Posted on Jun 24, 2009
  • 662 Answers
SOURCE: Duet GHW9150P Front Load Washer: whirlpool washer says control locked, how can we f...
Press and hold "end of cycle" button for 3 seconds, on the right side of panel. This is the child lock feature, do it again & it locks.
If helped, pl rate me good!!
Posted on May 19, 2010
marka19
  • 1430 Answers
SOURCE: Whirlpool Duet washer stuck in "control locked"
Press and hold the end of cycle button for 15 seconds this should clear it.
Control locked
Posted on Nov 26, 2010
How do you unlock a whirpool duet control panel?
Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off. This unlocks the control panel so that the washer is ready for use.
Read more : http://www.ehow.com/how_5701217_unlock-control-whirlpool-duet.html How to Unlock the Control on Whirlpool Duet eHow
Sep 29, 2015 | Washing Machines
How do I unlock the control panel?
here you go
Sep 29, 2015 | Whirlpool WFW70HEBW Duet 4.1 Cu. Ft. Front...
Control lock lit, no other buttons work
Instructions
    • 1 Press any of the buttons on the control panel to see if the buttons are operational or check to see if the "Control Locked" indicator light is lit. If the control panel is operational, you may mistakenly lock the door.
    • 2 Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off. The control panel is now unlocked, and the washer is ready for use.
    • 3 Lock the washer again by pressing and holding the "End of Cycle Signal" button until the "Control Locked" indicator light turns on.
Read more: How to Unlock the Control on a Whirlpool Duet ' eHow.com http://www.ehow.com/how_5701217_unlock-control-whirlpool-duet.html#ixzz2HVS4i8hL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 09, 2013 | Kenmore HE4t 3.8 Cu. Ft. King Size...
Control is locked
To unlock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds until the
CONTROL LOCKED Status light turns off.
Feb 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a Duet washer, and the Control lock light is lite, how do I get it to turn off
Somewhere on the control panel under one of the buttons it will say hold for 3 or 5 seconds to lock or unlock control panel. You may have accidently locked panel while cleaning or some one held button for too long and panel locked. The control lock is there in case you want to prevent small children from turning on your washer. Just hold down button for a few seconds and light should go off.
Feb 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The control panel on my Whirlpool Duet model # GHW9100LW1 reads control locked. How do I get out of this?
There is a control lock so noone can start the washer washer or change your settings after starting the washer. There is a subscript under one of the option buttons that says (usually not very dark or prominant) Control Lock Hold for 3 seconds. Hold this button in for 3 seconds, sometimes slightly longer and the control lock should turn off. Most are not aware of this feature because it is never used. If this does not solve your problem unplug the washer for about five minutes and try again, if problem still persists please repost.
Thank you
Please rate this post
Jan 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Control panel reads control locked
You problem have locked the control. There is a button on the front panel that says control lock. If you push adn hold this button for 3 secs the control locks or unlocks.
WHAT IS 'CONTROL LOCK' ON THE WHIRLPOOL DUET
Control Lock is a designed safety feature that allows you to lock/unlock the control panel to prevent small children from manipulating the controls. To lock or unlock the control panel, click on the following link:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
If this does not fix your problem, please let me know. I hope this helps you.
Jul 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Jun 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet
On the far right sode of the control panel there is a unlock control reset button. Hold it for 3 seconds and the fault will clear.
Mar 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
236 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
