Question about Samsung DLP HL-P5663W 56" TV
Screen Resolution Problems with Samsung 50" DLP
I seem to be having problems with my Samsung DLP TV. I have a set top box that is set to pass through resolution to the TV, but on all HD channels, part of the screen is cut off horizontally at the bottom (most noticable on sports channels that have "tickers". The TV is set to 16:9 mode. I've checked with the cable company and there's no issue with the set top box. Box is connected to TV using Monster Component cables.
Wondering if the lamp or projector can be adjusted (ie: has it been knocked slightly askew?)
    Sergeant:
    Novelist:
  • 192 Answers
You may have already done this, but check to see if you can change the screen size in the set-top-box settings and set this to widescreen 16:9 to match the tv. You may also have 14:9 as an option too. Also, check your video output settings, this can be changed between RGB, Composite, PAL or NTSC.
Let me know if that does or doesn't solve the problem
Tim
Posted on Dec 22, 2008
Trying to connect dell desktop to my Samsung DLP HL-R5064W tv through vga cable to watch movies. Toggle source button on remote to pc, but receive an out of range message. please help
"Out of range" message indicates that the output from your computer to display it from your Samsung HLR5064W DLP TV is too large. You need to adjust the screen resolution settings for you TV. I have attached images of display settings dialog boxes from different versions of Windows.
You may open the display settings of your computer by clicking on START > CONTROL PANEL > DISPLAY. While your TV is connected, click on IDENTIFY button. You will notice that numbers 1 and 2 will appear briefly on your screens consecutively. As the dialog box shows 2 monitors with numbers 1 and 2, click on the monitor with "2" on it. Then, adjust resolution to 1280 x 720 as this is the highest resolution your TV can handle. You may adjust the TV (monitor #2) to be IDENTICAL or to EXTEND the display of your computer. You can also assign it as the main monitor but not recommended. Click OK then try to toggle your computer's display. You should be able to see a display from your TV this time.
I hope this works for you. Kindly reply for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
DELL Tech ID #456563
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
Feb 22, 2011 | Samsung HLR5064W DLP Projection TV
I cannot tell the difference between my SD channels and my HD channels. I have samsung DLP tv, HD cable box and bose theater system. I am using an HDMI cable but there is not difference between that and...
In most cases you will not be able to see a great difference between HDMI and Component connections. As far as not seeing a difference between HD and SD signals from your cable box, go into the settings of it and see what resolution it is putting out. If you have a Motorola cable box, with it off and the TV on press the menu button and the setup screen will appear. That will tell you the output resolution as well as what the 4:3 override is set to. Please take a few moments to rate my answer. Thanks....
Nov 22, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Speckles in dlp tv screen samsung 50" dlp
No they couldn't have replaced everything or did they Replace Light Engine? Because that is what is Bad on your TV if under warranty get it Fixed Now Light Engine is very COSTLY !!!!!!!!
Sep 16, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
923nw samsung resolution problem
on ooptions screen, click box that says only show settings the monitor can handle. Then try changing the horizonal and vertical settings on monitor to match it up with your settings.
On your windows main screen, right click, then properties, then settings, check all the settings
Jul 09, 2009 | Samsung 923NW 19" LCD Monitor
DLP HL-R5067W
Your model has a maximum resolution of 720p. What you might want to do is make sure that both your cable/sat box and game stations are outputting at no more than 720 resolution. It's easy to assume that all HDTVs may accept a higher signal, and while they might, some of the scene changes or handshakes may make that operation cause the symptoms you describe.
Feb 08, 2008 | Samsung DLP HL-P5663W 56" TV
Dlp vertical lines
the person you talked to at samsung is more than likely a customer support rep that does know anything but what his computer tells him. i have seen this symptom several times in many makes and models. if you can give me your full model number i will give you a part number to fix this issue.
Oct 24, 2007 | Samsung HLN5065W 50" Rear Projection...
Samsung DLP HL-P5663W 56" TV Logo
343 people viewed this question
Jerry Greenberg
Jerry Greenberg
