Question about NetGear WGR614 Wireless Router
Can't access configuration for Wgr614 v5 Netgear Wireless router
I have a Sierra Wireless card that I use to get on the internet. When I try to access the Netgear router, it's not connecting. I share the connection for other computers, so I think it something to do with that. I tried to ping the netgear router, but It can't find it. Is there a way around having to access the internet to config the netgear router. You didn't need to access the internet to config the older versions of the wgr614 routers. All you had to do is connect it and access it locally. Can you help me ?
  • ricker1960 Dec 22, 2008
    I can ping the router now. I plugged the router into my ethernet connection on my computer. But when I go to the routerlogin.com , It won't connect to the internet.
    That's the whole problem. I can't get to the router configuration. Here is how my network is setup. I have a wireless pcmcia card plugged into a pci/pcmcia adapter in my pc. Then I have a ethernet cable plugged into my nic on my pc going to a regular hub. From there I have the Netgear wireless router plugged in. I have recently used a diffferent model netgear router that way with no problems. The only difference is that it didn't require an internet connection to configure.
    This new router (WGR614 v5) defaults to assigning ipaddresses, which I don't want it to. I am only using it to connect a laptop like a hub. Is there a way I can configure the router without an internet connection ? ????
  • 6,487 Answers
Since you cannot ping the router, first thing to do here is to reset the router by pressing the reset button of the router for 30 seconds while power is On and then after the reset power off the router for 5 seconds and then when the router is already power On try to ping the IP of the router using a computer that is wired to it if still cannot be ping better contact Netgear support if the router is still underw arranty and have it replace...
Posted on Dec 22, 2008
  • Mark Gil
    Mark Gil Dec 22, 2008
    You need to reconfigure the router to work with you ISP , since we reset the router its back to it default settings so you only need to reconfigure it back putting the proper settings for your ISP...
Connect Nokia C3 to Netgear router
Connect a LAN cable from the Netgear to the LAN port on your computer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = password You can now change the default admin password and configure the wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption to protect your wireless network and Internet from unauthorized access.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Mar 18, 2013 | NetGear WGR614 Wireless Router
My laptop cant connect to the internet
http://192.168.0.1
Jan 21, 2013 | NetGear WGR614 Wireless Router
Need to put a block on my internet
http://192.168.0.1
Jan 04, 2013 | NetGear WGR614 Wireless Router
Ialso have suddenlink
How to Set Up a Netgear WGR614 V5 Wireless Router
Netgear routers--like all wireless routers--give you the opportunity to access the Internet with your laptop or wireless-adapted computer from virtually anywhere in your house within range of the router's WiFi signal. Though slightly different in appearance from other router models by Netgear, the WGR614 V5 acts similar in its setup process as others such as the WGT624 or WNR1000 series routers.
Things You'll Need:
Netgear WGR615 V5 routerNetgear resource CDEthernet wireBlue network wireModemComputer
1 Prepare to install the Netgear router. Log off and shut down your computer system. Turn your Internet modem off and/or disconnect its power supply from the electrical outlet. Take out the contents of the Netgear router box and verify that all the essentials are present: the resource CD, the yellow wire and the router itself.
2 Connect the Internet modem to the Netgear WGR614 v5 router. Locate the yellow Ethernet wire running from one end of the Internet modem to the computer's Ethernet port. Unhook the computer-end of the Ethernet wire and insert this end into the port on the router labeled "Internet." After inserting, confirm that the wire runs from the modem to the router.
3 Connect the Netgear router to the computer. Grab the blue cable supplied with the router. Securely insert one end of the blue cable into one of the four "LAN" ports on the router (the "LAN" ports are labeled with numbers from 1 to 4). Insert the other end of the blue wire into your computer's Ethernet port.
4 Start your network devices. Turn on or connect your Internet modem to an electrical outlet. Wait for at least two minutes to allow the modem to fully boot. Plug the Netgear router into the wall or electrical outlet as well, and wait one to two minutes. Turn on your computer.
5 Look at the Netgear router to verify that all lights are on. The "power," "Internet" and "wireless" icon symbols on the front of the router should be solidly lit. One of the four "LAN" ports should also be lit with either a green or amber color.
6 Insert the resource CD that came with your Netgear router to launch the "welcome" screen. Select "Router Setup" from the menu to begin the "Smart Wizard" setup application. Read and follow the setup steps, including naming your SSID (secure set identifier) or "network name" and setting a level of wireless security. Finish the setup process, ending with the registration of your Netgear router.
7 Verify that your Netgear router has been set up correctly. Open an Internet browser from both the computer that is connected to the router and on a computer that has a wireless card or adapter. Surf to your favorite Internet sites to verify your connection is working. Open your "network connections" utility on your operating system and make sure it shows that you're connected to your own wireless network.
Jan 09, 2012 | NetGear WGR614 Wireless Router
Can't get access to my secure netgear router
If your computer does not connect to the wireless router, most likely the wireless card has not been configured with the router's wireless settings ie. SSID, encryption etc.
To secure your wireless network, configure the wireless router and the wireless card in the computer, please click on this link and follow my instructions :-
Jan 29, 2010 | NetGear WGR614 Wireless Router
I am given a set up error while trying to configure netgear WGR614. Below is the message The router is setup with the static IP values read from the computer. However, there is no Internet connection with...
You need to contact your Internet Service Provider to obtain the setup configuration for the cable or DSL modem. A LAN cable is then connected from the modem to the Internet LAN port on the wireless router.
Normally you do not set a static IP address on the router, and the wireless card should be set to obtain an IP address automatically.
If you still have problems, give me details of what configuration steps you have carried out on the router and the wireless card together with the error messages.
Sep 12, 2009 | NetGear WGR614 Wireless Router
Sierra Wireless AirCard 595U And PS3
I understand that you want to connect the PS3 using the Wireless card and NETGEAR card. Please note that the setup you have will not work for internet access. You can not configure the Air card to work with NETGEAR router. you need to have wih a broadband connection available for this router to connect to internet.
Once you have the router configured with Internet access then you may either connect the PS3 wired or wireless to the router, like you connect a desktop or laptop to the router.
Jan 12, 2009 | NetGear WGR614 Wireless Router
Problem in reconfiguring WGR614 v5 after reset
You should configure the 2wire to a bridged modem for the autentication to work on Netgear.check with your ISP for configuring your 2wire to bridged modem
Cheers !!
Feb 24, 2008 | NetGear WGR614 Wireless Router
NetGear WGR614 Wireless Router Logo
263 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
