Question about Apple iPod MA446LL/A MP3 Player
Sad Ipod sign and B&W charging battery sign....
My 60gb Ipod video does not appear on my computer. When I charge it, it shows a B&W battery for sometime then the black screen with the apple logo. After that it shows the dreadfull sad ipod sign for a few seconds then turns off. It repeats this continuesly. I've tried reseting it a couple of times and it appeared on the computer once (for several seconds). Is it posible that something is loose? Or an easy way to fix it?
  • Waggygee Gee
    Waggygee Gee Apr 06, 2007
    I have tried reinstaling my drivers and itunes (the ipod showed for a second or 2 the disappeared and began its cycle of sad face etc). Is it posible that my hard drive is messed up or could its simply be a loose cable somewhere?
  • Anonymous Jan 06, 2008
    I replace a cracked screen, new battery and new logic board.
You have a bad hard drive and it needs to be replaced
Posted on May 22, 2007
  • 30 Answers
Have you tried reinstalling the drivers?
Posted on Apr 06, 2007
  • Mortaza Ghanbarzehi
    Mortaza Ghanbarzehi Apr 06, 2007
    Don't think that it is a loose cable or your hard drive. Have you tried it on another computer? They problem may be with the ipd itself.
I would suggest uninstalling everything that had to do with you ipod off your computer (itunes, drivers, etc. and then reinstalling them. My friend was having a similar problem and this is what I told him to do and it worked for him. Hope this helps.
My ipod does nothing just shows a sad face
The "sad" iPod icon usually indicated that the iPod is having trouble connecting with a computer. This is, in most cases, not a serious issue and can be resolved with a few easy procedures. In most cases the data on the iPod is intact, even if the sad icon was displayed.
Verify the iPod has a charge. If in doubt, allow it to charge for 30 to 60 minutes. Do not remove charging cable. Toggle the Hold switch to the Hold position and back. Then press both the center (Select) button and the Menu (upper part of wheel) for up to 10 seconds. Release the Select and Menu buttons when the Apple logo appears, and quickly simultaneously press the Select and Play/Pause (bottom of the wheel) button. Switch from the electrical plug to a computer connection (if necessary) when the Disk Mode screen appears. The screen should change to the normal "Do Not Disconnect" update screen. Contact Apple about finding a repair service if the iPod will not go into Disk Mode.
Feb 03, 2013 | Apple iPod Audio Players & Recorders
Flashing icons while charging... am I really charging?
If the iPod is showing the "Sad iPod face" icon, this means that the hard drive inside the iPod (located on the logic/circuit board) has died/failed and needs to be replaced. If you plan on replacing this part, you may also need to purchase and solder a new battery to the iPod logic board if you were to do it yourself.
May 26, 2009 | Apple iPod nano
Ipod showing sad face
There is a free video on the Sad Face icon issue at the following web address. I hope that it is very helpful to you.
http://fixyouripod.weebly.com/
It is the first video on the page, just scroll down a little bit. :)
May 08, 2009 | Apple iPod shuffle MP3 Player
30gb video has sad face and low battery and will not charge even
Don't just change the hard drive,Change the motorboard as well.Different generation ipods use different boards and the hard drive from one won't always just plug in and work.
Dec 10, 2008 | Apple iPod MA446LL/A MP3 Player
My ipod video 60GB did not charge when I connect it to the usb
the us might be damged or if depending on how long you charged the ipod the battery might have die and wont hold a charge.
Nov 28, 2008 | Apple iPod MA446LL/A MP3 Player
IPOD Video 30gm
Hold down on the center button while hold down on the menu button. The apple logo will appear. Your Ipod is now rebooted.
Is the new battery fully charged? Usually it takes 6 hours on a new battery.
Jun 08, 2008 | Apple iPod MA446LL/A MP3 Player
Ipod troubles
Put the switch on hold then unhold it
now press the center and the menu button simultaneously for about 6 seconds
till the apple sign appears.
May 27, 2008 | Audio Players & Recorders
IPod does not charge
Search for 'The iPod battery Unplugged' it will probably help you diagnose the problem cheaper than apple will
Nov 27, 2007 | Audio Players & Recorders
Why isn't the charging icon always animated (flashing)?
For Mac users "When you plug your iPod nano into a power source, the charging icon appears?it's a lightning bolt over a battery. Depending on the state of the battery, it may or may not animate (flash between gray and green). In either case, the icon indicates the battery is charging successfully. When the battery is fully depleted, the iPod nano may not appear in iTunes until it has been charged for about 10 minutes.The non-animated version of the icon, shown above, appears when your battery has been fully or nearly depleted of charge. This appears for up to 10 minutes. Note: If your iPod nano is connected to the computer, the computer won't see it until after that 10 minutes has elapsed. After that, you'll see the ""Do not disconnect"" screen. If the charging icon is flashing and your computer doesn't recognize it,Can't see your iPod in iTunes or or the Finder? Remember these five basic suggestions when you run into a problem with your iPod. If one of the following doesn?t help, read on for solutions to specific problems. Reset, Retry, Restart, Reinstall , Restore Reset your iPod. Retry with a different USB or FireWire port. Restart your computer and make sure you have the latest software updates installed. Remove iTunes software and then reinstall iPod and iTunes software from latest versions on the web. Restore your iPod. See ?Updating and Restoring iPod Software? in the user's guide. Still can't see your iPod? Several things could keep iPod from appearing in iTunes or in the Finder when you connect it to your Mac. The most likely causes are listed below in logical order (you'll find information for both USB and FireWire iPod connections). Check each one starting from the top of the list to see if that is what's keeping iPod from appearing. Battery depleted? If you have an iPod nano, click here to find out what you'll see if the battery is depleted. If this is what you are seeing, wait 10 minutes while iPod nano is charging. You're using USB instead of FireWire If you use USB instead of FireWire to connect, it won't appear in iTunes unless you update to Mac OS X 10.3.4 or later. If you can't update your software, then use FireWire instead. Note: iPod shuffle and iPod nano are compatible with USB only. With any model of iPod (except for iPod shuffle), if you connect it to a low-powered USB port (such as one on your keyboard or bus-powered USB hub), the following alert may appear: If you click OK, your iPod won't appear. Make sure that you connect your iPod directly to one of the computer's USB ports or to a powered (as in connected to an electrical outlet) USB hub. Your Mac is sleeping Your Mac must be awake to recognize iPod. Be sure that you wake the computer before connecting your iPod. Your Mac doesn't meet iPod system requirements Make sure that your Mac meets the iPod system requirements. Third-party FireWire and USB cards and PC cards may not work and are not supported by Apple. You're missing some system sof
Sep 28, 2005 | Apple iPod nano
Charging icon
For windows users "When you plug your iPod nano into a power source, the charging icon appears?it's a lightning bolt over a battery. Depending on the state of the battery, it may or may not animate (flash between gray and green). In either case, the icon indicates the battery is charging successfully. When the battery is fully depleted, the iPod nano may not appear in iTunes until it has been charged for about 10 minutes. The non-animated version of the icon, shown above, appears when your battery has been fully or nearly depleted of charge. This appears for up to 10 minutes. Note: If your iPod nano is connected to the computer, the computer won't see it until after that 10 minutes has elapsed. After that, you'll see the ""Do not disconnect"" screen. Here's the animated version you would see after 10 minutes, or when the battery is not fully drained: If the charging icon is flashing and your computer doesn't recognize it, Can't see your iPod in iTunes or Windows Explorer? Remember these five basic suggestions when you run into a problem with your iPod. If one of the following doesn?t help, read on for solutions to specific problems. Reset, Retry, Restart, Reinstall , Restore Reset your iPod. Retry with a different USB port. Restart your computer and make sure you have the latest software updates installed. Remove iTunes software and then reinstall iPod and iTunes software from latest versions on the web. Restore your iPod. See ?Updating and Restoring iPod Software? in the user's guide. Still can't see your iPod? Several things could keep iPod from appearing in iTunes or Windows Explorer. The most likely causes are listed below?you'll find information for both USB and FireWire (IEEE 1394) iPod connections. Check each one starting from the top of the list to see if that is what's keeping iPod from appearing. iPod appears in Windows Explorer but not in iTunes or iPod Updater If your iPod shows up in My Computer, but iTunes and iPod Updater don't recognize it, there may be a software conflict, or iPod Service didn't load. You may see an ""iPod Service Error"" alert or a ""Please Reinstall iTunes"" message. If you see either of these messages, try the solutions in this article to resolve the issue. Laptop or portable connecting via USB? See iPod not recognized when connected to Windows laptop over USB for more information. Your computer doesn't meet iPod system requirements Make sure that your computer meets the system requirements to use iPod for Windows. Your iPod displays an exclamation point folder or sad iPod icon, or doesn't appear in iTunes or My Computer If your iPod displays a folder with an exclamation point icon or a sad (unhappy) iPod icon on its screen, or if your iPod doesn't appear in iTunes or My Computer, follow these instructions to resolve the issue. Your iPod isn't formatted for Windows iPod for Windows Software only recognizes iPod for Windows. You cannot use iPod for Macintosh
Apple iPod MA446LL/A MP3 Player Logo
67 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
