Question about Bosch & Tankless LP Hot Water Heater
Tp valve opening and dumping water
The tp valve on my aquastar tankless lp water heater keeps dumping water. I replaced the valve but the problem still exists. When I turn the hot water on, I get hot water but when I shut the hot water off, the valve dumps. I also seem to have lower water pressure (volume) within the house. Any ideas?
  • georgeb527 Dec 23, 2008
    The pressure reducing valve had indeed gone bad. Once replaced (by the water district), everything was fine. Thanks so much.
  • Anonymous Mar 20, 2014
    I have stated the problem. Would the microswitch be the problem?
    Scholar:
  • 101 Answers
Certain water heaters can only handle so much pressure from the main line. There is a pressure controller between your water meter and you house, it's called a pressure regulator. You need to call a plumber to check and see if it needs to be adjusted or even replaced.
Posted on Dec 22, 2008
I have abosch 1600 ps aquastar 4.3 gpm indoor when i turn hot water on it all fires up but no hot water comes out only luke warm water why
Water heater is heating water but only luke warm water arrives at faucet.
Open TP valve and confirm that hot water is available.
If water at TP valve is hot, then problem might be plumbing-related, for example crossover.
http://waterheatertimer.org/Crossover.html
Aug 15, 2011 | Bosch 1600PS NG Aquastar 4.3 GPM Indoor...
Aqua star runs on and was running water to out side I guess it would be the overflow ( tankless). Had to turn the water off
Problem is not clear
Before calling service technician, open following link for Bosch troubleshooting resources including contact information for Bosch:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Jun 09, 2011 | Bosch 2400ES LP AquaStar 6.4 GPM Indoor...
Pilot light works but no flame. Somehow, think it overheated due to stoppage of water flow at sink.
Before calling service technician, open following links for Bosch troubleshooting resources:
Resources at Bosch
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/tabid/370/Default.aspx
Typical Bosch Aquastar manual:
http://waterheatertimer.org/pdf/Bosch-aquastar-170vp-manual.pdf
All tankless and tank-type gas water heaters require regular cleaning and maintenance.
It is unknown if your unit needs maintenance or repair parts, but catching up on maintenance using information from manual is good place to start.
Gas appliances are increasingly complicated and experienced technician is good resource to have in local area before installing tankless.
Apr 16, 2011 | Bosch AQ125BO LP AquaStar 4.3 GPM Outdoor...
Fan won't stop running
remove from the wall.... donate to charity and purchase a quality tankless water heater!!!
Rinnai, Takagi, Noritz are the only brands I will install. I refuse to even work on Bosch "Aquastar", complete garbage!
Aug 05, 2010 | Bosch AquaStar 125FXKIT-LP 125FX Liquid...
I have a 250SX aquastar Bosch tankless hot water heater . It keeps going out on EC code; whats wrong? Also I've been running the unit for about a 9 months without hooking up the condensate dain line.
The 250 MUST have the condensate line connected. EC comes from gas supply problems and CO2 levels not being adjusted. LP units require 3/4" smooth gas pipe or 1" corrugated pipe minimum size. The LP regulator needs to be turned up to about 13 inches of water column and with all the gas appliances on, measure no less than 11 inches of water column. The CO2 levels must be measured by a qualified gas technician with a calibrated (with in 6 months) CO2 analyzer.
Mar 20, 2010 | Bosch & Tankless LP Hot Water Heater
Heater will work for a while then it goes on and off with a PSI error
Make sure water supply not restrcicted, valve partially closed, if on well raise pressure
Oct 25, 2009 | Bosch 1600H-LP Liquid Propane AquaStar...
Bosch Aquastar tankless water heater model 1600P Pilot is lit but main burner will not lite. replace water valve that controls ignition.
There should be a thermocoupler, it is that bulb that sits in the pilot flame. If it is not functioning properly the main gas valve will not open.. Hmmm, Is the main valve in the on position?
Oct 10, 2009 | Bosch AquaStar 1600P-LP 1600P Liquid...
Looking for Outdoor Tankless propane water heaters
it will tell you right on the box if it for indoors or out doors either way they have to have a cover over them,,
Jun 09, 2009 | Bosch AquaStar Propane Tankless Water...
No hot water
Aquastar 1600H NG Natural Gas Tankless Water Heater Bosch AquaStar Model 1600H NG Natural Gas Whole house tankless gas water heater, 117,000 Btu input, natural draft with hydro-generated ignition. Provides endless hot water for one major application at a time . Can replace 40-gallon storage tank water heater. Optional Accessory: Model AQ1- Power vent with built-in... More freeze protection when venting horizontally. Capacity: 1 to 2 Bathrooms Dimensions: 8.75D x 18.25 W x 29.75H Weight: 40 Max GPM @ 45F Rise: 4.2 Energy Factor: NG .80 LP .84 Minimum Input: 28,000 Maximum Input: 117,000 Vent Size: 5 Gas Connection: 3/4 Water Connections: 1/2 Warranty: 12-year warranty on heat exchanger, 2-year on parts Features: Endless hot water Can save up to 50% off utility costs annually Perfect for one major application at a time No standing pilot, hydro generated
Mar 01, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Bosch & Tankless LP Hot Water Heater  Logo
151 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
Donni Steen
john h
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
