Question about Sony Cyber-shot DSC-W50 Digital Camera
Lens mechanism problem.
Recently my lens has been failing to contract and expand normally. It is stuck about 1/3 of the way out. The lens covers are also stuck half way out. When I am in picture mode, the screen is black and it prompts me to turn the power off and on. It repeatedly beeps in this situation. I can still review pictures that i have already taken.
Also try twisting the camera lens left and right (as in reving up a motocycle engine) do it a few time (5x). I did it and it works for my camera. yess
Posted on Jun 29, 2007
Sounds like a Sony rep is giving you advice here. It is simply amazing how many people have had this same problem will all models of cybershot. What is more amazing are the ones that buy another Sony when they find out how much it would be to "Replace the lens". For a solution get off this site and try: http://www.photographers.co.uk/html/photographers-forum-1.cfm?ForumNumber=875&Title=sony%20cybershot%20DSC-U30 or http://www.pechorin.com/m/2003/07/12/SONY_C1301_ERROR-202719-32.html
Posted on May 28, 2007
    Sergeant:
    Champion:
  • 326 Answers
Hello, there is an ultimate solution for the above problem. Please replace the lens (optical) unit part number 178836311. If you need more info please advice.
Posted on Apr 09, 2007
Lens protector stuck open
A stuck lens cover is a fairly common problem, but it is normally easy to fix. A single grain of sand jamming the cover mechanism is normally the culprit, and you want to try to dislodge it. There are many non-invasive techniques that people have come up with to accomplish this. Some may be seen on this blog article. You can also open the lens barrel up to fix the covers, but only as a very last resort. This article provides further information on correcting this problem.
Jan 24, 2012 | Canon PowerShot S90 Digital Camera
Shutter is not opening in PL-90
A stuck automatic lens cover is a fairly common problem, but it is normally easy to fix. A single grain of sand jamming the cover mechanism is normally the culprit, and you want to try to dislodge it:
METHOD 1:
Point the camera straight down into a vacuum hose (while the vacuum is on) and tap it around the insides. This will help to **** the dirt out instead of pushing it in further like compressed air might do.Also turn the camera on and off constantly while doing this.
METHOD 2:
1) Try blowing lots of compressed air around the lens cover to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Use no heat mode if possible.
2) Slide a thin strip of paper between the lens cover shutters and the outer support ring. Work it around 360 degrees to clear out any debris that may be in there.
3) With the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. Repeat the above three steps several times. If repeated tries don't work then it may be necessary to open the lens barrel to access the lens cover mechanism.The lens cover mechanism is usually accessible for many cameras without needing to open up the camera case.
May 31, 2011 | Samsung PL90 Digital Camera
The lens cover does not open or close completely. just started happening. the camera is 2 years old and the battery is fully charged
A stuck lens cover is a fairly common problem, but it is normally easy to fix. A single grain of sand jamming the cover mechanism is normally the culprit, and you want to try to dislodge it: 1) Try blowing lots of compressed air around the lens cover to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Use no heat mode if possible. 2) Slide a thin strip of paper between the lens cover shutters and the outer support ring. Work it around 360 degres to clear out any debris that may be in there. 3) With the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. Repeat the above three steps several times. If repeated tries don't work (keeping in mind that it usually does), it then may be necessary to open the lens barrel to access the lens cover mechanism.
You can open the lens barrel up to fiix the covers, but only as a very last resort. The above procedures normally work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk, and it will void your warranty).
Oct 26, 2009 | Cameras
The lens cover on my Canon Power Shot A530 will not close completely. The camera still works fine, but I am concerned about damage to the lens. Is this fixable?
Oct 13, 2009 | Canon PowerShot A530 Digital Camera
Lens protective cover won't close after I dropped it.
You can open the lens barrel up to fiix the covers, but only as a very last resort. The above procedures normally work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk, and it will void your warranty):
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Jun 30, 2009 | Canon PowerShot S410 / IXUS 430 Digital...
Lens cover won't close and there is internal dust
A stuck lens cover is a fairly common problem, but it is normally easy to fix. A single grain of sand jamming the cover mechanism is normally the culprit, and you want to try to dislodge it: 1) Try blowing compressed air around the lens cover to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Use no heat mode if possible. 2) Gently slide a thin strip of paper between the lens cover shutters and the outer support ring. Work it around 360 degres to clear out any debris that may be in there. 3) With the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. Repeat the above three steps several times. If repeated tries don't work (keeping in mind that it usually does), it then may be necessary to open the lens barrel to access the lens cover mechanism.
Apr 16, 2009 | Canon PowerShot A560 Digital Camera
Shutter won't close all the way
The lens cover of PSA60 opens along with the move of the objective lens. Normally the camera will sound an error beep when the lens does not end to the end position -- the lens cover is also not fully opened. In reverse, the lens will be retracted when the camera is switched off.
The "shutter" (outside lens cover) might have something stuck inside the blades or other mechanical parts that prevents the lens cover fully closed. Try to blow with a clean air (no hot air - because it can damage the electronics or plastics).
Or maybe the blades are probably not flat that may create resistance on the surface. Try to flatten the blades by hands.
Or maybe the mechanical systems need to be calibrated (by Canon service center).
My suggestion, try to exchange/trade-in your PSA60 with the latest model at the Canon center, because I have done it last year (trade-in with PS S5IS).
Aug 08, 2008 | Canon PowerShot A60 Digital Camera
Lense will not close properly
Apr 25, 2008 | Canon PowerShot A70 Digital Camera
Lens cover stuck open
I recently had the lens cover stick partly open.  There are 4 segments to the lens cover, and if we number them from the top, number 2 was not closing.
I gently flicked the segments a few times, in case there was a grain of dirt causing it to stick (although the camera has never been in a dirty or dusty environment).  This caused the lens cover to close fully each time, but now it would not open fully, segment 1 would not open, although it would stay open if moved by finger.
Anyway, after a bit of fiddling, I got it working properly again.  The way that the lens cover appears to work is that only segments 2 and 3 are pushed open or shut by springs, segments 1 and 4 are pushed open and shut by tiny tabs that catch on segments 2 and 3.  If the segments somehow get pushed out of alignment, then they either bind (causing the cover not to shut), or they get disconnected (causing the cover not to open fully.
Now I am not sure exactly what I did to get the mechanism form the stuck open state to the not opening state, but from there the way to fix it is to:
-With the lens open...
- Hold segment 2 in the closed position with firm finger pressure (which will tend to push it towards the lens).
- Push segment 1 towards the open position until you can see that it has cleared the edge of segment 2.
- Lift segment 2 way from the lens so that it will rub past segment 1 as you...
- Move segment 1 to the open position.
- Repeat if necessary to get the technique right.
I can't provide any guarantees, and I am not about to repeat the excercise on my camera, but it was a lot easier than sending it off for repair.
Dec 12, 2007 | Panasonic Lumix DMC-TZ3 Digital Camera
Lens cover sticks closed.
If you're careful this problem is a relatively easy fix for many digital cameras. The design of the lens cover mechanism is usually simple and very similar throughout camera brands. Here's an example fix for a Canon A400 with similar problems:
Sep 30, 2006 | Fuji FinePix A303 Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
153 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Syzys
Are you a Sony Camera Expert? Answer questions, earn points and help others
