Question about Nikon D70s Digital Camera
Laptop Question I would like to know , is it possible to put 10GB of Memory/RAM on a laptop if it is specifically built, made to order. Thanks
    Problem Solver:
  • 20 Answers
I just built a new computer and found the amount of RAM one can install is limited to the amount the computer can use. There is a good starting article here. http://support.microsoft.com/kb/929605
I hope this helps
Posted on Dec 22, 2008
My hard works but me screen will not come on after installing 2 GB of ram , but the screen works when I put in the 1 GB of ram...
A) ALWAYS helps if you post the laptop manufacturer name, and model number.
Model number is on the Bottom of the laptop.
B) EACH Ram Memory slot has a MAXIMUM Amount of ram memory it will support.
If the TOTAL Maximum Amount for the laptop is 2GB, plus there are two Ram Memory slots, and the Maximum Amount for EACH ram memory slot is 1GB, what you are doing = NO.
Awaiting laptop manufacturer name, and model number.
C) Also, post what you see on the 2GB ram memory module, or info elsewhere for it.
Need to know WHO made it, and what it's specifications are.
May NOT be for YOUR laptop.
Regards,
joecoolvette
Feb 16, 2013 | Computers & Internet
Minimum memory of laptop?
The specification does not tell you the minimum memory. If available you may put 64/128/256/512MB DDR2 667 MHz ram. But these days minimum ram size available in the market is 1GB DDR2 667MHz ram. So this is the minimum.
The most important is the maximum memory it can support. This model can support maximum 2GB DDR2 ram.
Jan 18, 2011 | Fujitsu Siemens ESPRIMO MOBILE V5515...
I have a HP NC6120 laptop and am tring to upgrade the RAM, I found one card slot, but, don't know where the second socket is. do you?
Hello, and thanks for using FixYa.
If the 2nd slot is not in the bottom of the laptop, then you will find it from under the keyboard.
According to HP specifications of the laptop the memory is Upgradeable to 2048-MB maximum (1024-MB SODIMM in slots 1 and 2) So yes the laptop does have two memory slots. It will be under the keyboard.
Please let me know if you require further assistance or if you have any questions.
Thanks,
Ekse
Oct 17, 2010 | Computers & Internet
I have 512 K memory chip ,can I add this to my travelmate 6492
I do not know your specific model of laptop, but if the above specifications are accurate, then most likely not. Most laptops have two DIMM ports, where you place the RAM. This laptop probably has two 1gigabyte pieces already installed. This means to add yours, you must remove one and replace it, thereby decreasing your RAM to 1.5gigabyte total. Now under the rare possibility that your computer has a single 2 gigabyte RAM installed, then yes you can really easily. Just open up the panel on the back with the RAM inside and check. If only one is installed, then install the other (you can use google search to find the exact process), and your computer will be ready to go. I hope this helps, -Robert
Aug 26, 2010 | Acer TravelMate TM5720-6337 NoteBook,...
HP Pavilion dv7 ram upgrade, came with 4gb ram, supposedly is able to upgrade to 8gb, is this possible?
Yes. The specifications say the MAX memory is 8GB
Memory 4096MB Memory Max 8192MB
You should go to Crucial.com and run their online tool for ram upgrades. It will tell you exactly how much and what type of memory to add.
Thanks for using FixYa.
Mar 19, 2010 | HP Pavilion dv7-1130us laptop
How do i replace ram in a toshiba 2450
Unclip top trim the one with the on button ,undo 3 screws lift up the keyboard and put in your memory in the slot under the plastic reassemble in reverse order
Cheers
Sky
Feb 20, 2010 | Toshiba Satellite 2450-401 Notebook
Is it possible to install high desnsity memory RAM on a T42
The T42 can support up to 2 Gb of RAM.
The laptop comes with 512Mb of RAM under the keyboard and a spare memory slot on the bottom of the laptop.
To install 2Gb of RAM put 1Gb in the memory slot under the kerboard - need to remove the old RAM and put the other 1Gb in the memory on the bottom of the laptop
T42 Memory specs.
  • 64-bit Double Data Rate (DDR) non-parity SDRAM memory
  • PC2700 at 333MHz
  • Two 200 pin SO-DIMM memory slots, one slot is pre-populated with 256MB or 512MB, leaving one socket available
  • Supports up to two 1GB SDRAM SO DIMMs
  • Supports maximum memory up to 2GB
Sep 22, 2009 | IBM ThinkPad T42 Notebook
Can the memory be upgraded (increased) from the basic (factory installed) 512mb on the Sony PCV-W300G?
Hi there.
As far as i know you can upgrade the RAM to 2GB, 2x1GB 184pin PC2100 DDR DIMM Desktop RAM modules is what it can take.
Thanks for choosing FixYa!!
May 28, 2009 | Sony VAIO PCV-W300G PC Desktop
Frustratingly slow
You should bumb your memory from 256 to at least 512, and better yet if at 1024.
Mar 14, 2009 | Dell Inspiron B130 Notebook
Pny bravo laptop memory installation problem
You need to go to your manual and check if this new RAM is on the qualified venders list. Many motherbaords have problems with RAM and are picky about which you put in it even being the same speed and specs. If you dont have the manual , go to thier website, there is a list threr related to your laptop. also make sure the RAM is seated properly in the slot, that also cn cause an err
Sep 18, 2008 | PNY 1GB microSD Memory Card
Nikon D70s Digital Camera Logo
16 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
