Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Intuitive washer fault code 43 coming up - Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
  • Anonymous Feb 20, 2009
    code 43
I had same problem and followed starcee's advice on howtomendit.com
I unscrewed top cover, then unscrewed and lifted up the grey computer cover. The balance switch is underneath on the right with a yellow and white wire coming off.
I removed switch from clip and then removed the wires/clips from contacts. There was definitely corrosion on the contacts. I soaked switch overnight in vinegar. Then rinsed with water. Then dried switch out for day.
Put it all back together and am now on second load of washing.
Posted on Mar 02, 2009
Error 43 ( lights 3,5,7 & 8 and some beeping)
(Make sure all power is unplugged)
I popped off the two screws holding down the controls. Then undid the screw holding down the grey box with the main control board. Under this in the right hand corner is the out of balance switch. The small microswitch can be eased out.This is part# 30 in the manual (see link below). My one had corrosion and the switch was gummy.
http://www.stokes-aus.com.au/StokesAP/Manufacturer_Info/FP/WASHERS_DRYERS/479091%20Washer%20Ph1%20GW500%20600%20650%20700%20MW050%20060%20070.pdf
I then bypassed switched to check, all good. Now I need to fix switch (vinegar method) or buy new....around $30.00
Thanks for the posts
Posted on Jun 22, 2009
Code 43 is an out of balance switch problem, i found mine was just sticking, if you pull it out (under the electronic control unit, under the top panel) you may be able to find out if its stuck or if it needs a new one, you could possibly find one from another model. hope this helps
Posted on Dec 26, 2008
After reading the above I bought a brand new balance switch - only $5.95. To replace it took just 5 minutes. Easy as
Posted on Apr 14, 2009
    Problem Solver:
  • 8 Answers
The vinegar solution works! Even though I was sure my machine was really out of balance due to washing one brand new towel in it, I tried this trick and now my machine works perfectly. I've done three loads since then.
A great way I found to dry the switch is to seal it in an airtight container with a lot of those silica dessicant sachets you get in bottles of pills or new bags.
Posted on Mar 31, 2012
3 Suggested Answers
SOURCE: fisher and paykel intuitive washer what is a code 43 please
That link doesn't have any Fisher Paykel products on it!
Posted on Jun 10, 2008
  • 28 Answers
code for out of balance oob switch probably needs replacing if load wasn't off to one side.
Posted on Jun 21, 2008
43 error fisher paykel
Out of Balance Switch Fault Fault code #43
The out of balance switch is permanently activated or the harness to it is disconnected.
Nov 17, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
Intuitive Iw509nw fault code 9 what's it mean
the size of the machine needs to be set. if you recently replaced a board the first thing you need to do is 'size set' the machine and instructions should come with the board. holding wash temp up/down and pressing power should get you into the menu, though it's too much to explain here.
Aug 16, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
Error code 43 on intuitive top loader
hello click this link for error code 43 this is an out of balace error and this link will tell how to fix as well http://applianceguru.com/forum2/3397.html if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations Thanks Rick
Mar 01, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
Washing machine stopped filling up and an error 43 or 43 came up on screen
Hi just read your posting.Now Error code 43 means you have an OUT OF BALANCE SWITCH FAULT.The switch is located under the control module which is located under the top panel.Would you like me to guide you throe the testing and possible replacement of the Switch?The secondary source of this error code is your Motor Controller.But we must test the switch 1st as the switch is the most likely component that is faulty.Have you or can you borrow an electrical test meter to test the switch.It would make it easier to test the switch with the tester but there are ways around this.Please reply for further assistance and I am sure I can help you rectify this fault.Looking forward to your reply.
Aug 07, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
FP fault 43
code 43 is an out of balance switch problem.Once replaced, would fix the issue.
One trick that might work ;-
Thanks.
Jul 01, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Code 49 and Manual Book
Fault 49 usually points to the cold inlet valve. I have come across many with this fault that the valve tests ok and it needs the motor controller replaced.
Jan 06, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and paykel intuitive washer what is a code 43 please
Jun 20, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
HI, Go to this site is has all fault codes all you do is find your product click it and it will show you the fault codes and what they mean and suggest how to fix it. http://www.repairclinic.com/0078.asp
Jun 09, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
May 30, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
1,644 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
