Question about Scotsman CSW45 15" Ice Maker with 26 lb. Ice Storage Capacity, 44 lb Ice Production per Day, Drain R...
Scotsman ice machine(sce 275g)
I have a scotsman ice machine, stopped working. When i tried to reset, the compressor turn on but the water in let valve will not open. I checked the vale itself by giving direct power then it will open up.Any idea?
Thank you
  • jeminijoseph Jan 23, 2009
    I have the same model with same problem.
  • kulwant Oct 08, 2013
    sce-275 it spark when i turn on
    Guru:
  • 462 Answers
The older cubers were opperated by a cube size thermostat. when the temp reached the cube size tstat setting it would energize a harvest timer motor and this timer would continue running through a holding switch on the timer. when the cam comes around and the micro switch drops the water is introduced (it would be warm) and the hot gas from the refrigerant would be introduced to the evaporator causing the cubes to drop. at the end of the cycle the cam pushes op in the holding switch and finally open it and because the cube size tstat is now warm the timer motor stops.
The timer had a white plastic stem with a 1/4" D shaft. It would only turn clockwise. Try looking for this and advancing it to see if your sol valve will open or get voltage to the valve.
Posted on Jun 02, 2009
If the water is cut off to the house, will the Scotsman ice machine automatically shut down?
I don't know the answer but you can go to the Scotsman website and they have manuals for their various machines.
https://www.scotsman-ice.com/service/
Jan 07, 2018 | Scotsman Kitchen Appliances - Others
Scottsman SCE170A-1B how can i have to make ice faster
The only way to make ice faster for this machine is done with cooler ambient room temperature and colder water temperature from supply water before it reaches water sump tray.
Jun 06, 2014 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Why Scotsman CM3 ice machine shows diagnostics water problem?
should you have any questions, Thanks John Tripp Appliance 911
First let's look through the different service manuals. CM3 Water level sense diagnosticsDOWNLOAD
Head Pressure Control Kit - CM3DOWNLOAD
Reduce Air in CM3 ModelsDOWNLOAD
Replacement of the CM3 controllerDOWNLOAD
Service Handbook to 2007 - CM/CM3DOWNLOAD . I am here should you have any questions, Thanks John Tripp Appliance 911
May 15, 2014 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Mv450 scotsman high pressure
Check to make sure the condenser coil is clean, fan motor is running during freeze cycle. High Ambient temp, Ventilation, The higher the temperature entering the condenser coil the higher the head pressure. Fan motor failure, pressure switch failure. The cut out pressure varies 400, 450 or 500 PSIG. Water supply failure. not enough water running over the evaporator plate will cause high presser.
Jul 30, 2012 | Scotsman Cooled Modular Contour Cuber Air...
Scotsman DCE33A-1WB Residential Ice Machine Problem
Making good ice. Could be cube size control. Could be a weak compressor. Also these machines are household and meant to run in air conditioned space.
Aug 02, 2010 | Scotsman DCE33PA1BC 15in Built-in...
Scotsman dc33pa ice maker
Make sure the curtain is not torn and there are no leaks from the resivoir. If ok check to make sure you have enough water pressure to the machine. Make sure you have enough water passing through the valve during harvest cycle. To check... turn the timer cam to harvest cycle. Water should come in quickly behind the curtain on the right side and the timer should advance three minutes to freeze portion of cycle and stop running. Water should spray and form ice for approximately 25min. Then the timer advances for 5 minutes into harvest cycle and it refills with water again.
Nov 21, 2007 | Scotsman CSW45 15" Ice Maker with 26 lb....
Scotsman CSW45 15" Ice Maker with 26 lb. Ice Storage Capacity, 44 lb Ice Production per Day, Drain R... Logo
500 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
John Tripp
John Tripp
Tim Whalen
Beto Flores
Beto Flores
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
