Question about Optoma MovieTime DV10 Multimedia Projector
My Optoma Movie Time remote control doesn't work anymore. I have changed the old AA batteries and put brand new ones, but it doesn't work. What can I do? Does the remote control have other batteries that are needed to replace? My projector is only 2 years old and I have only used it times. Can I get a replacement?
  • Sun96 Jan 09, 2009
    I have also the exactly same problem and I also use it only time (150 - 200 hrs).
  • herbicide86 Feb 18, 2009
    The same problem here, no response over a fortnight (so far) from Optoma CS (via phone and email) who were meant to be sending a form re: purchasing a new one.
SOURCE: toshiba laptop won't work with new optoma projector
-toggle the laptop display using the FN keys and F5 I believe. -lower laptop resolution to 800 x 600 -look in laptop display properties for lcd or external display settings, see if it (external crt) has to be enabled on the laptop first.
Posted on Aug 26, 2007
Marrie
  • 563 Answers
SOURCE: Optoma DV10 MovieTime Color Wheel replacement
Hi guys
Your best bet on getting your hands on a Service Manual would be to contact Optoma themself.
As for changing the colour wheel , it is pretty straight forward if you were able to open up the unit and get to it.
The colourwheel is mounted with three tiny scrws to a bracket in which it sits. And the bracket in it's turn is fastenend to the body of the Projector with two tiny screws.
First unscrew the bracket from the casing of the Projector and then take off the three screws that holds the Colour wheel to the bracket. Replace and do the whole proses again - but obviously just the other way round.
This is really easy to do yourself.
Give me a shout if you need any further assistance.
Thanks for using Fixya and good luck.
Posted on May 07, 2008
marsrover
  • 682 Answers
SOURCE: projector has no power
close lamp compartement door firmly because door switch can disconnect power from projector if not closed firmly.
Posted on Sep 22, 2008
hawk127311
  • 350 Answers
SOURCE: I plugged my optoma projector
Here is a link to a webpage that gives you a detailed explanation with pictures. Although it describes how to hook up the ipod to a TV, it is exactly the same for a projector. More than likely from your description you already have the wires, so you need to enable the video settings.
Setting up your iPod video options lets you control how you export video. The iPod Video Options screen selects how your iPod handles video file playback.
To open these settings, choose Videos -> Video Settings from your main iPod menu. This screen offers three settings: TV Out, TV Signal and Widescreen. Adjust to produce the video playback style you need.
Use this setting to choose from:
  • No. Playback remains on the iPod itself.
  • Yes. A TV signal is produced.
  • Ask. The iPod prompts you whenever you play a video file.
http://macdevcenter.com/lpt/a/6341
I hope this helps and good luck. Please vote and leave a comment.
Posted on Oct 30, 2009
SOURCE: optoma hd70 starts flashing colors
I removed the front cover and top panel, Using the Radio Shack dust removing spray, removed all dust from interior including circuit boards, color wheel ect, now it,s operating like a new projector.
Posted on Jan 04, 2010
Replace battery problem. Toy will not work with new AA batteries.
Simply slot the positive terminal of the battery compartment make the positive pole which is usually wider the contact is possibly no better nor stuttering contact voltage which can cause problems.
Dec 19, 2015 | Toys
Optoma movie time projector has a vibrating sound
Normally this sound noise is the small FAN inside. Dirty or faulty. You must open the proyector, or go to some shop repair.
God bless you
Jan 25, 2013 | Optoma EP706 Projector Remote Control
Magic eye light is on, but the remote control doesn't work anymore
open the remote control, and clean the keypads from oxide, corrosion, dirty.
change the batteries and put a new ones.clena the contacts batteries with pencil erase.
retight the springs contacts batteries, for better contacts. and try again.
Otherwise you must go to the repair shop TV for fix it.
God bless you
Sep 23, 2012 | Televison & Video
Xbox 360 controller not powering up
If the control is wireless, try changing the battery device out, use a different type. for ex; AA batteries to a re-chargable one. If the control is wired, try changing out the cord or get a new control. If it doesn't work, try here . Hope it helps.
Dec 08, 2011 | Microsoft Xbox 360 Controller
What batteries fit vp-440
This tester requires AAA batteries.
Please rate my reply. thanks.
May 31, 2011 | Amprobe Non-Contact Volt Probe Product ID:...
Sleep Timer on remote does not work
First try to access the sleep timer menu from the controls on the TV to verify the TV is working.
If that works then the remote has the problem.
Now try this;
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
If this does not work, then you may need a new remote unit.
Mar 10, 2009 | Olevia LT37HVS 37 in. LCD HDTV
Code list
I have the code list. I'll have to scan it to put it on. But does it work? None of the codes worked for me.
Mar 02, 2009 | Universal Remote Control Battery Free...
Optoma ep721 remote problem
return the projector (still under warranty, if bought new). if it's used, reset the settings on the projector to factory default. if still nothing, replace the remore.
Sep 24, 2008 | Christie 38-VIV211-01 LCD Projector
Wont power up optoma movie time
it's probably not this: Try using the remote to turn it on. I cleaned out mine a while ago and the controls on the main unit stopped working. Only way to turn it on now (for me) is the remote.
Feb 12, 2008 | Optoma MovieTime DV10 Multimedia Projector
Optoma MovieTime DV10 Multimedia Projector Logo
259 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Electro Med Services...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
