Hi, after having some occasions when this computer would not start, solved by pressing F8 when booting, I created the 3 no. DVD reboot disks and everything was fine for a few days. I ran Anti virus checks and quaranteened somethings that were on there. Ok I thought, maybe that was the problem. Now after a few more days of normal operation it does not switch on. The fan runs and green LED comes on for 2 secs thenboth go off again. Pressing F2, F8, F10 F12 and zero while starting dont make a difference. Reboot disks make no difference. Just starts for 2 seconds, fan and LED but black screen, then off again. AC power is connected and LEd for it is green. Any idea what I should try next ?
Try to access the BIOS screen, as check for the hardware helth and connection status.1) Black screen shows fault in RAM check he slot settings or other RAM.
2) If device shuts down itself in 2 seconds as you said, there might be a fault with the mother board or SMPS circuit which is not at related to any quarantined file by your AV.
Regards:
Himanshu
SOURCE: Toshiba A105 keeps Restarting ---
maybe the power input is error
the uncorrect power input will result bad
or,
it's your mobo broken
SOURCE: I got a virus, removed it with anti virus and
Hello
Thank you for using FixYa for your problem
Have you done a repair with the XP discs
Also there is a disc called techey tool kit, in this there is a HDregeneration program, run this to scan and repair the HD
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Testimonial: "Thank you very much. Your answer was the most helpful of all. I appreciate your time and very useful advice."
Thanks to all of you, i am going to try a third party reboot programme to see if I can at least get the screen to start, then try to get into the BIOS. I will let you know how that goes.
Richard, I do not have windows XP discs. It is running on windows 7. I tried Kaspersky rescue cd download:http://majorgeeks.com/downloadget.php?id... and the DVD starts but then after 1 to 2 seconds it powers off again, no change
Himanshu, I cannot get to the BIOS screen, so cannot try your solution
