Question about Toastmaster 208 Pizelle Maker Waffle Maker
Pizzelle maker 208 won't heat up.
I've only used it a few times. I plugged it in tonight and the lights were lit, but it never heated up.
  • 5,568 Answers
Most appliances that work with heat, are equipped with a thermal fuse so if the thermostat fails, the fuse opens and prevents a fire. It is basically a good idea since all of our junk now comes from China and half of it is poorly designed and unreliable.
These fuses are normally not user replaceable since they are crimped or welded into series with one side of the AC line. And, they are tough as hens' teeth to find anyhow.
A year ago, I had three coffeemakers of the same model die in as many days. I took a refund.
The Toastmaster toaster we have, bought because of the name and appearance, is the absolute worst toaster we have ever owned. It regularly leaves one side of each slice burned, the other too light. I'm afraid the name means nothing anymore.
Posted on Dec 22, 2008
I have a pizzelle maker when do I know the right time to open & pour batter and when it is ready to be removed without burning
Some irons have one light that indicates that the heating element is on. I think that the Saulton iron has two lights. One light indicates that the iron is plugged in. The second light indicates that the heating element is on. You should wait until the second light goes off before trying to bake the first pizzelle. The second light will turn on and off as the thermostat regulates the heat. The cooking time depends on the pizzelle iron that you use. A good iron can bake a pizzelle in 30 seconds. The Salton iron WM8PZL takes up to 90 seconds for each cycle. Check the pizzelles after 30 seconds. The first pizzelles are seldom good. Experiment with the baking times to get the baking time right. After that keep up a steady pace to produce consistent results.
Early pizzelle irons were heated over open fires and made good pizzelles so with some practice you will be able to make pizzelles too.
Link to Recipe http://allrecipes.com/recipe/pizzelles-iii/
Jul 19, 2014 | Salton Pizzelle MasterWM-6Non Stick...
Gold medal 2404 won't heat
Double check that the kettle is plugged into cabinet.
Does the Switch light up? if not it is the switch is bad.
If it does, than either it is the kettle lead wires, or themostat, or the heat element that is bad. In that order.
Oct 06, 2012 | Gold Medal 2404 Funpop Popcorn Maker
Broken leg on Villaware pizzelle maker
You might try putting a screw of about the length of the original leg into the underside of the casing (drill it a little with a power-drill or a Dremel, then carefully insert the screw with a handheld screwdriver, testing it at intervals to make sure it's the length of the leg,) and then cover the screw in some Sugru. www.sugru.com should be able to sell you a few packets of the stuff; it's heat-resistant, very strong, and I've used it in several kitchen-gadget fixes.
Aug 29, 2012 | VillaWare 3600 Prego Pizzelle Baker
Steady yellow light
To reboot unplug the unit for 30 minutes. then plug back in. This may fix the problem, and try this link for troubleshooting PDF.http://homeappliance.manualsonline.com/manuals/mfg/bionaire/127176.html...
Apr 20, 2017 | Holmes Products BH3955-U Bionaire Utility...
Where do I find this perticular make and model? I need 2 or 3 of 'em
You are out of luck as this is an old problem the season is long past.
I am fairly shure that Toastmaster no longer makes this Pizzelle iron. A better solution is an American made Pizzelle Iron by C.Palmer
Built like a tank and will probably outlast you. I wouldn't buy a non stick appliance from anyone as the coating is easily damaged.
http://www.cpalmermfg.com/products/Pizzelle-Maker.html
Oct 31, 2011 | Toastmaster 208 Pizelle Maker Waffle Maker
Manual for Toastmaster Pizzelle maker Model 208
what is the part # for the 208 pizzelle Thermal Control Module, and where can I purchase one?
Oct 01, 2011 | Kitchen Appliances - Others
When you first light the pilot works fine after cooker heats up it may cycle a few times and the pilot goes out and then when you try to relight it will only stay lit while the pilot button is being...
Hi there. Try cleaning the thermopile, it must be free of soot or any other form of dirt, the pilot flame should be of good quality, as well as the gas pressure.
Regards.
Aug 02, 2011 | Imperial IFST25 Deep Fryer
Toastmaster 208 Pizelle Maker Waffle Maker Logo
210 people viewed this question
Top Toastmaster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Henry  Thomas
Henry Thomas
Are you a Toastmaster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
