Question about LG DLE2512W Electric Dryer
Cracked Drum on LG Dryer Model #DLE2512W
My drum in my dryer has cracked and clothes are getting stuck in it now. I see several people have the same problem with other LG dryers. Has there been any recalls?
If not, what is the replacement drum item number, how do I order it, and how hard will it be to fix ourselves?
Also...my dryer gets stuck on 6 minutes for a long, long time.
  • 8 more comments
  • Anonymous Jan 19, 2009
    I have the same problem with the same dryer
  • numdoc Jan 26, 2009
    Same problem, same Dryer.  I hate that I have to spend money and time on a dryer that is just out of warranty.  I feel that I should be able to put a brick in the dryer and it not crack the drum.  Clearly a failure in the metal or the weld.  I should have stuck with my old Kenmore... It was 10 years + old and worked fine, but we had to go "green".
    A quick update:  the part 3045E4002D is no longer avaliable and the new part 3045E4002C is 147.88 plus shipping.  What is note worthy is that although this is a "non stocking part" and as such does not allow for returns, they have 13 of them in stock in the GA warehouse.  If this cracking is not a problem then why do they have so many at one location?
  • mysports Feb 09, 2009
    • drum is also cracked after 1 yr
  • andersonmh Feb 19, 2009
    I also have a cracked drum on my DLE2514W dryer. The replacement part is 3045EL1002D. I noticed that there are newer rev drums available e.g.3045EL1002E and 3045EL1002F. Will they fit my dryer and are they made of a thicker material or have better welds. I would like to replace the drum with a stronger one if possible so I don't have to do this every 2.5 years.
    Thanks
  • lorishelton Feb 24, 2009
    I have the same problem with a crack in my Dryer Drum. Looks like the weld came loose and the drum cracked now I am getting clothes stuck in the crack. I only owned the Dryer for 2.5 yrs and pd $1300 alot more then I would have pd for a desent Whirlpool. I called LG customer Service and they stated they will do nothing. I will never purchase another LG of anything again. My $500 Kenmore dryer lasted 10 Yrs before I had any problems.
  • Anonymous May 02, 2009
    Cracked drum, argh!!!!
  • David Morrison
    David Morrison Oct 17, 2012
    My Kenmore dryer broke at the weld not even 2 years old, Sears said tooo bad
  • shelly Sep 16, 2013
    I have the same problem - for the second time - with my samsung front load dryer
  • bendts
    bendts Jan 26, 2014
    I have been fighting with lg to replace even under warranty now for 18 months, and still nothing. Never again!!!!
  • 1,543 Answers
If you are still looking for information on this:
No, there has not been any recall.
It is not a real common problem. I only see 1 or 2 a year, which is not many. (LE errors on washers are much more common, for example) The part number of the drum for a DLE2512W dryer is 3045EL1002D and lists for just over $100. You can find a service center to order the part from (in the US) at http://us.lgservice.com/index_b2c.jsp
I would rate the repair at about a 5 or 6 out of 10 on a scale of 1-10 in difficulty. (Basically, remove top, remove front control panel, remove front panel, remove front drum support, remove belt, drum comes out the front, reassemble.)
Posted on Jan 21, 2009
Rivit strips of 24 guage stainless over the cracked seam using stainless rivits and this shoud hold the seem and crack securely. ( grind the corners and edges of the metal strips so they are smooth. )
Posted on Mar 25, 2009
  • DuctapeDan Oct 26, 2010
    Thanks for the suggestion. It's exaclty what I did, before reading this. I thought I was nuts, or just cheep. It's worked OK, but the drum is no longer perfectly round, or perfectly balanced. My drier makes more noise now and vibrates quite a bit. I would only recommend this as a temporary fix until you can afford a new drum. A replacement drum is on my list of future purchases.
2 Suggested Answers
  • 5 Answers
SOURCE: Cracked Drum on LG Dryer Model #DLE2512W
I had a 2514 with a similar problem. Cracked drum. This is what I did to fix it. With the new drum. No noise at all.
Ordered drum from Sears parts. 3045EL1002D
Cost of 85$ + 15 to ship. It came in 5 days.
Here is how to do it on a DLE2514W. Takes about an hour. I only used a phillips screw
driver. Take your time and look over the situation. I hope that I rememberd
everything. Good luck.
Dryer Drum Repair
Dryer Drum Repair
1. Remove L bracket with 6 screws at the top, rear.
2. Slide top back 2 inches to unlatch and remove.
3. Remove control panel with 2 screws at top, inside corners.
4. Carefully unplug 4 plugs from back of control panel.
5. Looking at inside at the top. Remove wiring bundle from 2 guides.
6. Unplug wire from dryer light.
7. Open dryer door and unscrew 2 screws behind door just below lint trap.
8. Remove 4 screws at top of front panel that holds the door.
9. Lift up front panel to remove. I couldn't get the door switch plug to disconnect
so I carefully rotated it an set it on top of the dryer.
10. Remove upper case bracket with 2 screws in front and 2 screws inside at top.
11. slide up a bit to unlock from sides. Watch routing of dryer switch wire bundle.
12. Remove lint trap duct with 2 machine screws. Carefully slide down to remove.
13. Remove front drum support with 4 screws attached to sides. Lift up to disengage
sides. Lift drum to free from rollers.
14. Observe how drive belt is routed around motor and tension roller. Push tension
roller up and release belt. Carefully take belt off and remove.
15. Almost done. Lift drum up at rear to free from rear rollers. Remove.
16. While your're there vacuume up dust and reverse procedure to install.
Posted on Apr 02, 2009
Cracked drum lg tromm dle2512w dryer. is it worth replacing? dryer is about 3 yrs old
I'd say yes, especially if you replace it yourself to avoid a service call. Top needs to come off (screws at back, then push top back 2 inches and lift off), remove front, remove 4 screws holding front bulk head / front rollers, slip belt off tension pulley, remove drum, reverse to install.
Sep 25, 2010 | LG DLE2512W Electric Dryer
LG DLE2512W Dryer says chech filter, starts, heats and turns but makes loud noise. Maybe something stuck? A sock?
Drying drum is not on its host. Lay down the dryer and then bolt it after aligning it.
Oct 07, 2009 | LG DLE2512W Electric Dryer
Cracked drum on LG dryer
visit this online store I believe the price is $164 before shiping.Thanks for your interest in Fixya.http://www.appliancefactoryparts.com/search/partinfo.php?partsID=324980&modelsID=125623&typeName=applianceshvac
Sep 04, 2009 | Dryers
LG Tromm Dryer Thumps when running
The drum on my dryer is cracked, it thumps the entire time it runs, and it snags up all of my wife's clothes. We hate these appliances!
Aug 14, 2009 | LG DLE2514 Electric Dryer
Dryer thumps when running, clothes get stuck...
It always helps if you list the brand and model number in your post. I would look at the seam on the drum to see if the weld has cracked. (right at the front and / or rear of the seam.)
Jun 10, 2009 | Dryers
Cracked drum on the DLE3777W model
The drum is a part number 3045EL1002F which will set you back at least $135. Still well worth the repair, especially if you can install it yourself. You have to remove the top by removing 3 screws in back and sliding top back about 2 inches and lifting off. Then, remove front panel. Remove 4 screws holding the front bulkhead. Remove belt from drum. Remove drum. First time might take a hour, second one you do will take about 15 minutes.
Now, don't rate me down because you don't like having to repair your dryer. I didn't manufacture it. I'm just giving you a bunch of free advise.
May 18, 2009 | LG DLE2512W Electric Dryer
Dryer Drum Repair
Dryer Drum Repair
Feb 10, 2009 | LG DLE2515S Gas Dryer
Bump
Look for a crack on the seam of the drum, right at the front or rear of the drum.
Dec 29, 2008 | LG DLE2512W Electric Dryer
LG DLE2512W Electric Dryer Logo
6,264 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
