Question about Oasis Hunter 54' Ceiling Fan
Have replaced bulbs, but no light. Even ch'kd & re-set breaker.
Wall switch is working properly, as the other two switches are working properly. Even ck'd and reset breaker, but still nothing.
  • mbengleman Dec 22, 2008
    The light was working immediately before changing the bulbs, and has always worked previously.
    This particular fan does not have a remote.
    I have pulled the light chain several times, but light still does not work.
    What is the "light chain switch?" Or what would it look like?
    Scholar:
  • 75 Answers
You said, "Wall switch working properly, as the other 2 are....Are you talking about other wall switches? If your light is not working, I would check the pull chain switch if it has one. If not, you either have a wire not attached properly (you did not say if they have ever worked) or if you are dealing with a remote, I would bet you 10 to 1 that your remote is bad, more than likely in the part inside the fan. There has been a rash of these things going bad.
Posted on Dec 22, 2008
  • Gerry Haverland Dec 22, 2008
    The light chain switch is the light chain you mentioned, I suspect the switch is bad. It is attached to the upper end of that chain.
How do I replace the door light switch?
I appreciate your post, Deborah!
From what you have described you need to replace the door light switch on your Frigidaire freezer. In order to assist you further I would need your model number. You can locate your serial tag (which lists your model number) on the inside wall of your freezer. I look forward to assisting you. -Matt
Apr 27, 2015 | Frigidaire Freezers
Dimmer switch legrand 735446 not working after bulb blew. Always on, never off or dimmed
Yes, replace it. But once you have it removed, you might want to check it with a resistance meter to confirm that the problem is the switch and not a wiring problem. If the switch gives virtually zero resistance in any position, then this is definitely the problem. The actual source of the problem might be that it's getting a bit hot in the block of 8, especially if they are all dimmers. If the wall plate tends to feel hot you might want to replace some of them with regular switches. Better that than burning the place down.
Feb 09, 2013 | Electrical Supplies
Switch has worked fine for 2 years and now it works, then doesn't work
Check all connections where any power wires or ground wires are connected. Even on the switches. and yes on the fan itself. Sometimes a wire on a connection will vibrate loose and will work then not work. Make sure they are tightly put together.
Dec 04, 2017 | Westinghouse Wireless Ceiling Fan and...
Replaced 2 of 4 bulbs with 75watt bulbs. It sparked upon turning on the light and now the light does not work at all. Fan still works????
In the cealing where the fan is mounted, you have wires in the switch the control the fan speeds, to the motor and wires that control the light. Most likely there is a wire exposed or short that every time you turn light on, it of course blows light out. Als check , open up switch on wall first to make sure no loose wire on wall switch. Please turn of breaker first, make SURE power is off. Please if this advice helped, give me 4 thumbs to help me and others, thanks, Mike
Jun 16, 2011 | Hampton Bay 48 In. Palm Beach in Textured...
My brake light was not working so I replaced the bulb, it still doesnt work with handlebar lever or foot pedal.
Check circuit breakers/fuses for proper operation. If circuit breakers/fuses ok, then could be a wire problem that would be common with both brake light switches, most liklely in rear fender area. You do have the switch on when checking brake light?
Apr 16, 2011 | 2000 Harley Davidson FLSTC Heritage...
I was changing a light bulb with one of those metal extension rods that unscrew and screw back in the replacement bulbs. It evidently didn't seat correctly and pulled off the bulb and created a quick...
If you have not already done so, I would check at the fuse or circuit breaker panel to see if you have blown a fuse or tripped a breaker.
Aug 28, 2010 | Vacuums
Cannot set timer properly
This timer only works with incandescent light bulbs. It does not work with CFL's (compact flourscent light bulbs). Intermatic model ST01C will work with CFL's and LED's. I ordered one today from WestsideWholesale.com. They had the best price.
Apr 22, 2009 | Intermatic Programmable 24 Wall Switch...
AEG D2160 Double Oven - electrical fault
you may find that one arm of the oven selector switched has fused to its contact.
Sep 07, 2008 | Ovens
Oasis Hunter 54' Ceiling Fan Logo
135 people viewed this question
Top Oasis Dryers Experts
Are you an Oasis Dryer Expert? Answer questions, earn points and help others
