How to set timing on Daewoo leganza 2000 Engine Number T22SED025092
SOURCE: how to set a timing belt on a daewoo leganza
You will need these tools:
13mm open end wrench 10mm shallow and deep socket 8mm socket long flathead screwdriver 17mm deep socket T50 torx socket 1/4", 3/8ths and 1/2" ratchets and extensions E10 inverted torx sockets 6mm Allen wrench 15mm open end wrench 7mm socket 12mm open end wrench 14mm socket 12mm socket 8mm, 9mm and 10mm Allen head sockets 19mm socket pry bar needle nose pliers.
If you are doing this because your timing belt broke, you will also need to buy a complete cylinder head, head gasket set, and both idler pulleys. ALL DAEWOO MODELS WILL BREAK THE INTAKE AND EXHAUST VALVES WHEN THE TIMING BELT BREAKS.
Start by removing the air cleaner assembly from the throttle body, remove the air filter and housing jack up the vehicle and remove the wheel, remove the plastic shielding in front of the accessory drive belt assembly, remove the accessory drive belt, place a jack with a block of wood on top underneath the engine oil pan remove the front engine mount, remove the crank shaft pulley (the four Allen head bolts only not the 17mm bolt in the center.) Remove the metal plate behind the engine mount bracket on the engine, remove the plastic timing belt cover, three clips on top and two 10mm bolts on bottom. Rotate the engine until the #1 cyl. is at Top Dead Center (TDC) on the compression stroke or line up the crankshaft timing mark with the mark on the inner timing belt cover (notch in cover with notch in pulley) on the camshaft pulleys (intake cam line up the line on the pulley with the line on the inner cover) (exhaust cam line up the arrow on the pulley with the arrow on the inner cover) Now loosen the 13mm bolt in the belt tensioner and using the Allen wrench, rotate the tab until there is slack in the belt. Remove the timing belt. At this time I would recommend you replace the water pump, both plastic idler pulleys as they tend to overheat and lockup, and the belt tensioner. Make sure all your marks are lined up, you may need a helper to hold the exhaust cam in place as it tends to move during belt installation. Put the timing belt underneath the crankshaft pulley, install the belt leaving the intake cam for last and NO BELT SLACK on the right side between the crank and the exhaust cam. Once the belt is installed, rotate the crankshaft over two revolutions and make sure is rotates freely, and your timing marks are aligned perfectly. If not, the engine will not run properly, tension the belt as needed. Installation is the same as removal. To clarify, on the DOHC engine, the intake cam gear has a line on it, and the exhaust cam gear has an arrow on it. These should be lined up with the corresponding line and arrow on the VALVE COVER, pointing straight up. I just went through this process over the weekend, and spent quite a bit of time looking for these marking as I had removed the valve cover. Once I found them, it was plain and simple. In addition, be sure to not over tighten the belt when reinstalling. The tensioner has markings on it for "old" and "new". DO NOT adjust past "new", as the car will sound like a jet engine, and the belt will not last for very long. One more item that you might as well replace while you are in there is the cam position sensor if you have not already replaced it as there have been issues with them, and the timing housing has to be opened to get to it. The timing is set at: 6 degrees (both manual and automatic transmission)
SOURCE: Daewoo Leganza 2000 timing belt broke
Hi.
If the idler pulley, broke, with the car running, (I think is the most probable), There is no way to fix the car just replacing the timing belt and the idler pulley. This is an interference engine, that means if the timing belt or the idler pulley breaks, you need to replace the whole cylinder head, that's because the valves are bent. I just fix my daewoo, I tried first to just change the idler pulley and set up the time, but it did not work. I had to replace the whole head cylinder, timing belt and pulleys.
I got the information to set up the timing belt from a Library, The program is Mitchell on demand.
Thanks
SOURCE: How to set and align timing on a 2000 Daewoo Leganza
Its pretty simple here is a diagram of your marks, http://www.2carpros.com/car_repair_information/tec_info/2000/daewoo/leganza/2000_daewoo_leganza_timing_belt_diagram_marks.htm contact me if you need more help. Thanks for using FIX YA
SOURCE: daewoo leganza 2000 2.2 liter if all the timing
It should be top dead center on a compression stroke and all the valve are closed. Both cams have a line the lines up with marks on the valve cover. Basicly the marks on the cams both are set to point to twelve o'clock. The mark on the crank shaft pully points to 6 o'clock or strait down
