Question about Panasonic DMR-E30 DVD Recorder
Panasonic DMR E30 when you press open it says LOCK on display
This unit worked fine until recently when you press open to insert dvd  display says LOCK
Nickstar19
  • 417 Answers
SOURCE: i have a panasonic dvd
ITS DEPENDS ON WHAT DISC YOUR USING SOME ONLY TAKE DVD+R SOME TAKE DVD-R AND SOME TAKE BOTH DVD+R DVD-R
Posted on Jul 02, 2008
SOURCE: Panasonic DMR-E30 with U99 fault
Saludos : Yo tenia el mismo problema. Mi dvd DMR-E30 tenia el
mismo problema . Codigo U99 . Y no funsionaba nada.
Entre a la pagina de soportes de Panasonic y baje el Firmware.
Luego lo grabe en un cd ,el cd lo coloque en la dvd y la dvd se actualiso automaticamente. La dvd funciona perfectamente tanto
con DVD-RAM como con DVD-R. Esta solucion la saque de esta
misma pagina fixya . Gracias Fixya. Att. LACF
Posted on Jan 01, 2009
SOURCE: Panasonic DMR- EA18 DVD player/recorder - Remote control Problem
I figured out, unlike all the other posts, you don't have an enter button. But Instead, you would hit the 2 and OK button at the same time for a few seconds. I had the RC1 message and I did the 1 with OK and it worked. so if you have RC2, you should hit the 2 and OK. Should work!!
Posted on Jan 31, 2009
  • 46 Answers
SOURCE: Panasonic DVD player will not read DVD.
Sounds like you laser head is dirty, buy a dvd/cd clearner disc and run one and maybe twice, that should fix it, if your still having issues most likely you will need to replace it.
Posted on Apr 03, 2009
SOURCE: Disc won't eject, stays in "RECOVER" mode
I have a panasonic DMR E-60 and had the same problem. What I did was remove 2 side screws and 3 rear screws and lifted top cover off. Then if you are facing the front of the unit to the right of cd unit there is a little nipple that locks the mechanism. Push that in, which would be to the left if your facing the front of the unit. Then press the eject button. Mind you it must be plugged in to power. Be careful not to touch any of the green boards or metal. Hope I was clear. I sent it to panasonic but they wanted 40. just to look at it and up to 140.00 to fix it.
Posted on Jun 03, 2009
Hello, my remote for my Panasonic DMR-EZ47V DVD Recorder / VCR Combo recently stopped working, and whenever I press a button on the remote, I get a message on the display as "RC1" I'm guessing...
Actually, you are sort of correct, in a sense, RC1 means remote command mode 1 (the default mode of your combo unit). There is one way you can try to fix this:
Remove the batteries from the remote, press any button on it to clear its existing memory buffer, then re-insert them or replace them with new ones. While unit is on (no DVDs or tapes in it), point the remote at it - press and hold 1 and ENTER/OK buttons together for 10 seconds, then release.
This should (in most cases) restore full remote command operation to your combo unit - if when you press a channel button on it, and the unit's front channel changes, the remote is now functioning as it is meant to.
The good news is this will constitute any workshop repairs or costs (except perhaps new batteries for the remote if required).
I hope this helps a bit.
Apr 21, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
How to convert my Panasonic DMR -E30 dvd recorder from uk region to multi region format
Turn On player with no disc inserted
While pressing Shift on the remote press Setup
Press Enter twice
Move the cursor to Other
Enter the appropriate four-digit region setting, beginning with 000
Press Enter
Press Return twice
Switch unit Off for at least 3 seconds
and here are some other HACKS for your players
like Macrovision bypass ISCSI BAYPASS ETC
http://www.videohelp.com/dvdhacks/panasonic-dmr-e30/1585
Jan 17, 2008 | Panasonic DMR-E30 DVD Recorder
Panasonic DMR-ES45V - DVD recorder / VCR combo Remote not workin
My remote is not working. When I press a button, I get the following message on my unit: U12, U30, SET #, CHK REMOTE #, or RC #. What can I do to fix this? The message displayed means that the remote control and unit are not communicating and the remote needs to be programmed. To program the remote, press and hold the same number that is displaying on the unit and the [ENTER] or [OK] button for more than 2 seconds. For example, if the unit displays “SET 2”, press and hold [2] and [ENTER] or [OK] for more than 2 seconds.
Jun 04, 2009 | Panasonic DMR-ES46VS DVD Recorder/VCR
Apr 03, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic dmr-e55 won't work, just says "hold" on display
HOLD or X HOLD? If the latter - which is most likely - then the Child Lock has been activated! Press and hold ENTER and RETURN simultaneously until HOLD disappears!
Jan 22, 2009 | Panasonic DMR-E55 DVD Recorder
DVD Recorder Screen keeps saying HOLD and not switching on
CHILD LOCK:
The Child Lock Deactivates All Buttons On The Unit & Remote Control.
To Deactivate Press & Hold (OK) & (RETURN) Simultaneously Until "X HOLD" Disappears.
Oct 28, 2008 | Panasonic DMR-EH50 DVD Recorder
Jun 29, 2008 | Panasonic DMR-E30 DVD Recorder
DMR E100H panel button does not work
call Panaonic 1 708 981 4842 and talk to tech support, it sounds like a faulty unit and should be return immediately
Feb 01, 2008 | Panasonic DMR-E100HEBS DVD Recorder
Panasonic dmres10 dvd recorder showing ' x hold '
This is the child lock feature, to stop unwanted use of the unit. Using your remote control, hold down 'enter' and 'return' until a message is displayed.
May 05, 2007 | Panasonic DMR-ES10 DVD Recorder
Panasonic DMR-E30 DVD Recorder Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
