Question about Electrical Supplies
Question about Portable Generator
Will a portable generator with the following specs be able to power a surge protector with 700W running on it? I'd assume it would, but I've seen some reviews about the amps being low.
  • 2,000W peak / 1,500W continuous output
  • 4-stroke / 80cc EPA approved engine
  • Synchronized single phase brushless motor
  • Durable tubular steel frame with sock absorbing feet to absorb vibration
  • Up to 9 Hrs Run Time on 1 Tank of Gas at 50% Load
  • DC Output: 12V at 10Amp - Perfect for charging your Car, RV, Jetski or Boat battery
  • Posted by on
      Scholar:
    • 75 Answers
    It will not even know it is working! Honestly, it will be a breeze for it!
    Posted on Dec 22, 2008
    How to find portable generator brands?
    There are numerous sites online that are providing specifics of portable generator. These are typically specially manufactured for those people who are looking for good quality portable electrical generator and it's assessment. To find out more please click here.
    Best Selling 2000 Watt Portable Generator Brands 2016 Top Brands Guide
    Aug 05, 2016 | Electrical Supplies
    I have a Lincoln SP135 mig welder, and my house circuitry isn't up to the task, so I'm looking for a portable gasoline generator. How many watts am I looking for?
    HI Jim, When you're buying you portable generator tell the store person you're buying the generator for your mig and give that person your specifics..... P.S. Listen and ask.... AND take a day or two if you're not sure..... CHECK OUT EBAY as well as you can barter price mate, I hope this helped..............CHEERS..
    May 06, 2016 | Electrical Supplies
    Why won't my stanley 8000 generator put out power?
    You have to be missing a switch to turn on the power outlets once it is running. That or a breaker needs to be turned on.
    Jun 01, 2014 | Stanley Portable Generator: 8000 Running...
    Generator want put out power
    Check breaker on generator and if not that could be the copper windings that produce power
    Jun 27, 2012 | Generac XP Series Portable Generator...
    No power output from Briggs & Stratton ProMax 7500E generator
    You may have exciting field broken. Look for a fuse or wire break.
    Jun 04, 2010 | Briggs Stratton Portable Generator 305cc...
    Portable generator head stopped making power
    portable generator head stoped making power engine runs fine sircut brakers are fine
    Mar 16, 2010 | Pramac Electrical Supplies
    Low voltage, freqency appears erractic but engine speed is constant, auto idle surges
    called hunting. Adjust the air fuel ratio crew until it stabilizes, The tur idle to specs.
    Nov 19, 2009 | Porter Cable 10,000 Watt 20 Hp Portable...
    Have an fg5700ak runs ok but no power output what
    Typical diodes are 10 amp for these. The stator and rotor both have VERY low resistance readings. The reading typically will be below that which will register MEANINGFULLY on the digital meters.
    My generator had 10 amp diodes with surge protectors across them. One of the protectors shorted and generator output was zero. Mine is a 6KW diesel silent unit.
    Replaced the diodes with 70 amp ones with surge protectors that have 20 times the energy absorbtion as the originals. Unfortunately this required some lathe work to make holders for the diodes and the surge protectors to ride on the rotor.
    Used the light bulb trick to remagnitize it once diodes were replaced.
    Nov 10, 2009 | McCulloch 13HP 338 Cc Portable Generator #...
    Portable generator pops breaker when temp is over 75 degrees
    I take it you have RV plugged into generator. Hopefully direct with no extension cords. Are you using a 30 to 15 amp adapter to plug into generator? What is the rating of the breaker on the generator that keeps tripping, suspect it's only 15 amp?
    Jul 20, 2009 | Dometic Rooftop RV Air Conditioner
    Coleman generator OHV3000
    The carburetor is probably clogged up. Mix a bottle of carburetor cleaner with the gas to see if that would help. Also check/replace the fuel filter.
    Sep 10, 2008 | Coleman Powermate Premium Plus 6250W...
    Electrical Supplies Logo
    147 people viewed this question
    Top Electrical Supplies Experts
    Craig Butler
    Craig Butler
    Steve
    Gene Haynes
    Are you an Electrical Supply Expert? Answer questions, earn points and help others
