Question about HP Computers & Internet
Having a hard startup with the computer, takes time to get the computer to start, doesn`t start at the exact moment, I need to keep pushing the button on the tower to TRY to start the computer, but to no avail.
    Scholar:
  • 57 Answers
Probably a power supply failure is imminent if it's not already dead. Make sure the vents on the power supply are clean and aren't stopped up with dust. There needs to be room for the system to breath and keep itself cool.
You can replace the power supply yourself, as long as you get one with the same power connectors for the motherboard. The number of pins and the amount of connectors are quite different for different systems and power supplies (more than you need is better than less). I would also get one that has a bit more power than your current one. For instance, if your power supply is 300 watts, I'd get a 350 watt one.
Posted on Dec 22, 2008
Computer takes long time to boot?
To fix this problem you need to limit startup services. To do so follow these steps:
Click Start - write msconfig in search box and Click Enter> Click on StartUp tab
Deselect the programs you want to stop
If problem still exists then use system optimizer tool like Reginout for an instant fix. You can easily limit startup services by using this tool.
Mar 27, 2013 | Microsoft Windows 7 Home Premium 64BIT...
Restore imb thinkpad r50 to factory setting
If the recovery partition on the hard drive is still on the hard disk then -
With the ThinkPad off, push the power button and the minute you see the startup screen push the F11 button, hold it for just a moment and release it. That will take you to the rescue and recovery application
Mar 08, 2013 | IBM ThinkPad R50e Notebook
I have an HP G42 the laptop won't boot or start
HP laptops are well known for motherboard issues, and will usually involve a replacement board, at this point have it checked before a decision is made.
Sep 26, 2012 | Computers & Internet
How to reset the hard disk
What do you mean reset the hard disk? There's no such thing. Exactly what is it that you are trying or wanting to do? What type of problem are you having that makes you think your hard disk needs resetting?
Are you talking about Formatting the Disk which wipes it out completely and makes it unusable until you reinstall the operating system?
Are you talking about doing a System Restore which takes your computer back to a certain date and time before you started having problem. And it keeps your documents, music, pictures, videos, programs (unless the program was installed after the date you selected).
Are you talking about a System Recovery which sets your computer back to the first time you brought it home after you purchased it. You will lose all your data, documents, music, pictures, videos and program that you installed.
Apr 08, 2012 | Toshiba Satellite L305D-S5881 Notebook
When i install windows xp there is no drive
I take it you are trying to install the operating system. If the computer tells you there is no drive, then you need to check in the setup (like pushing F2 or DEL or whatever the computer tells you to do at startup) and check to see if it actually sees a hard drive. If it doesn't, then your hard drive has gone bad and will need to be replaced.
This all assumes that you have installed the hard drive correctly and if an IDE drive, you have correctly set the jumpers.
Dec 08, 2011 | Computers & Internet
I want to reset my laptop to it's factory settings.
hello.push DEL or F2 immediately after powering on.
Than your are in the bios
push F5 confirm
push F10 confirm
restart the pc
try recovery again
Jun 30, 2010 | Acer Aspire One PC Notebook
My computer won't startup
Take the cover off the hard drive location,reseat the hard drive,if works your are fortunate. If it doesn't buy a new WD hard drive.
Oct 09, 2009 | Computers & Internet
It takes too long to start up
Try deleting your temp files to clear up space as well as run hard drive defragment and disk clean up. This helps most time. If you find that your systems is still running slow, you may need to add more memory to process the data you have on your hard drive.
Good Luck
C2Solutions
Aug 07, 2009 | Dell Inspiron 530s Desktop Computer...
Windows Vista will not start up
Here's to to restore your laptop. Keep in mind that this will most likely delete everything off your hard drive and restore it to factory defaults.
If you choose not to restore your system, I would recommend taking it to a local computer repair shop.
The procedure is as follows.
1. Turn off the computer.
2. While holding the F8 key, turn on the computer.
3. The Advanced Boot Options menu will be displayed. Use the arrow keys to select Repair Your Computer and press ENTER. 4. Follow the on-screen instructions.
Apr 29, 2009 | Computers & Internet
Automatic program start-up not wanted on my computer
Click on Start, the run. In the box type in msconfig.
Click on the startup tab. Uncheck each program you do not want to start up with your computer. Keep in mind that some items are required for startup for windows so don't uncheck anything you are not sure of.
Exit and restart. Once it restarts you'll get a message just click ok to exit out of that message and those programs will no longer start up with your computer.
Thanks and please take a brief moment to give this solution a rating of fixya.
Mar 12, 2009 | Microsoft Windows Xp Home Edition English...
Computers & Internet Logo
37 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
