To unlock your Nokia 1208 you can make use of the unlock codes.
You can get the unlock codes from the site Onlinegsmunlock.com
and unlock it easily.
Ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
SOURCE: unlock Nokia 1208
Your unlock code for Nokia 1208 for the network T mobile,here is the code
#pw+2846475677 +1#
How to use: Remove SIM card and turn phone on. Enter code in to main screen. To get the p push your * key 3 times, the w is the * pushed 4 times. Dont forget to remove SIM card, when entering codes! After entering unlock code phone will display: SIM restriction off - when lock has been successfully removed; Code error - when entered unlock code is wrong; Cant undo restriction - when you have tried to enter wrong codes too many times. You have only 5 tries to enter proper unlock codes! After that your phone can be unlocked only via cable, unlock codes wont work anymore!
SOURCE: Forgot unlock code Nokia n82 mobile
send me ur imei no. on
[email protected]
i will provide u secirity code
if u r satisfied pls vote me
SOURCE: NOkia 5310 SD Memory Card Problem
i have forgotten the password to my SD memory card. FExplorer.sis is not supported in NOKIA 5310. Can any one help for this... plzzz...
- To unlock you Nokia 6120 (if forgot or lost
lock code) you can unlock it using a master code. - To get the master code i need
the IMEI code of your mobile phone.
- With the help of this IMEI code we can
get the master code of your mobile and unlock the
mobile and reset it with a
new password.
- The IMEI number can usually be found on the sticker underneath
the battery or by typing
*#06# into the phone keypad.
Hope this helps, please rate if the information was helpful, thanks!
