Question about U-Line Icemaker
We have a u-line ice maker 10-years old... The ice maker works fine until the plastic line split the clear plastic line in the ice maker has split.. One end I can replace easy where the water come in from the sink but where does the other end attach??? Thanks Ed
  • thehanksfami Dec 22, 2008
    How do I get to it?? The elaporator plate
    Surely I can find it...
  • 700 Answers
It should be going to the fill valve inside of the unit. it should be by the evaporator plate.
Posted on Dec 22, 2008
  • Todd Born
    Todd Born Dec 22, 2008
    http://www.u-line.com/products/category.... this is a linki for uline, good luck
  • Todd Born
    i apologize there is a plaec on the back of the ice machiunre where the water gets hooked. up to
    User’s Manual
    CONNECTING THE WATER SUPPLY
    On Ice Maker models BI 2015 and Combo 2075FF, install a 1/4 inch
    outside diameter copper water line (not supplied with unit) from the
    nearest COLD water pipe. When connecting the water supply, follow
    these guidelines:
    • Review the local plumbing codes before you install the unit.
    • The water pressure should be between 15 and 150 psi.
    • Install a shut-off valve in the 1/4 inch outside diameter supply
    line.
    • Connect sufficient tubing to the unit to allow the unit to be
    moved for cleaning and servicing. However, make certain that
    the tubing is not pinched or damaged during installation.
    • U-Line recommends the use of copper tubing for installation.
    Figure 3
    1. Locate the compression fitting
    and ferrule packed in the
    unit. Slide the compression
    fitting and ferrule over the
    water supply line. Do not use
    thread sealing compound or
    tape.
    Using two wrenches,
    tighten the compression fitting
    on the supply line (see
    Figure 3).
    UL134
    2. Carefully bend the water supply
    line into position and connect
    the line to the solenoid valve
    (see Figure 4). Avoid kinking
    the water supply line.
    UL103
    WATER
    CONNECTION
    Figure 4
    9
    3. For recessed installations,
    allow extra water supply line
    length to provide slack for easy
    removal from the recessed
    area (see Figure 5). This will
    also safeguard against kinking
    the line.
    Figure 5
    CAUTION
    If you are not intending to use
    the ice maker and do not connect
    the water supply (or turn
    the supply valve off), it is
    imperative to raise the bin
    arm of the ice maker (see
    Figure 6). Failure to raise the
    bin arm may result in damage
    to the water valve.
    Figure 6
    NOTE
    Problem Solver:
  • 11 Answers
Www.u-lineservice.com is the company website
1-800-779-2547 is the tech support line
The water line connects right behind the grill in the front of the unit. The line goes through the back and routes up to the front. You should know that plastic line is NOT recommended for the supply line. PLease only use copper or call the mfg to get an install kit. They have a really nice braided line kit for this unit.
Posted on Dec 23, 2008
Ice maker
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
other ice maker related issues and solutions:---
Ice maker dispensing ice with black or white plastic pieces in ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-ice-with-black-or.html
After replacing ice maker assembly, ice is not getting made?
http://alltypesofpartsreplacing.blogspot.com/2011/10/after-replacing-ice-maker-assembly-ice.html
Ice maker is leaking water and causing the ice to freeze?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-leaking-water-and-causing.html
Ice maker is noisy and not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-noisy-and-not-making-ice.html
Refrigerator ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/refrigerator-ice-maker-stopped-making.html
Ice maker leaks water into ice bin causing a glob of ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaks-water-into-ice-bin.html
Amana Refrigerator leaking water from ice maker?
http://alltypesofpartsreplacing.blogspot.com/2011/10/amana-refrigerator-leaking-water-from.html
Ice maker leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaking.html
Ice maker is dumping the ice cubes out before frozen solid.
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-dumping-ice-cubes-out.html
Water overflowing ice maker?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflowing-ice-maker.html
Ice cube is getting stuck up hard in ice maker
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-cube-is-getting-stuck-up-hard-in.html
Icemaker quit working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/icemaker-quit-working.html
Quit making ice
http://alltypesofpartsreplacing.blogspot.com/2011/10/quit-making-ice.html
Water leaking into ice tray, frozen glob of ice
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-leaking-into-ice-tray-frozen-glob.html
Not making ice, and water leaking in freezer?
http://alltypesofpartsreplacing.blogspot.com/2011/10/not-making-ice-and-water-leaking-in.html
The ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice_20.html
Ice maker not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-making-ice.html
Ice maker quit working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-quit-working.html
Ice maker dispensing black pieces of plastic in the ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-black-pieces-of.html
Replaced Ice maker but its still not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/replaced-ice-maker-but-its-still-not.html
Ice maker leaked creating an ice block?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaked-creating-ice-block.html
Ice tray leaked?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-tray-leaked.html
Ice maker stopped functioning?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-functioning.html
Ice maker stop working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stop-working.html
Ice maker failed
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-failed.html
Old ice maker stopped working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-stopped-working.html
Old ice maker started leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-started-leaking.html
Ice maker not working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-working.html
Ice maker overfills and cause water to flow into ice dispenser and freezes?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-overfills-and-cause-water-to.html
Ice maker didn't make ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-didnt-make-ice.html
Ice maker was leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-was-leaking.html
Ice maker was leaking after it filled up with water?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-was-leaking-after-it-filled.html
These will help.
Thanks,.
Dec 21, 2012 | LG LFX25976ST - 3-Door French Door...
Every day or 2 I have to mop up water on the freezer side of my side by side. it is about 10 years old now.
sounds like the drain is blocked.you might have to remove the inside back panel in the freezer but look at the bottom of the panel,if you see ice there,there's a drain hole under the ice,melt it out with a hair dryer then you have to clear the drain,i use a steamer to do this,i stick the nozzle into the hole and the steamer blasts through whatever is in the hole,if you don't have a steamer you can try to melt the ice and then blow hot air into the hole to melt the ice down in the drain,then use a turkey baster or anything that will blow into the hole,when you think the drain is clear pour hot water into the hole,if it goes down the hole it's clear if not keep hitting it until the water goes down,watch out trying to snake anything into the hole,the lines are plastic,you can try a plastic tie to snake down the hole.if the drain isn't blocked check to see if one of the water lines are leaking from under the fridge or you could have a problem with the ice maker but you'll see ice forming from that,,good luck.
Apr 12, 2011 | Admiral Refrigerators
Icemaker makes shells. Outside is frozen but
Hollow cubes are caused by not having enough water in the ice mold. Fill it up manually by pouring water in it and see how the cubes turn out.
look for an adjustment behind the plastic endcover with a +/- on it. - is less water. + is more water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
There is a screen filter before the water inlet valve in the water line. It can get partially stopped up with sediment blocking water flow.
Oct 28, 2009 | Freezers
Maytag fridge no water to icemaker any suggestions
Pour about 2/3 cup of water into ice maker . If it freezes and dumps , replace the water valve . If it does not dump , replace the icemaker . Also make sure the coils are clean beneath refrig , and the clear fill tube , which fills the icemaker , is clear of ice (not frozen up ).
Sep 12, 2009 | Maytag MSD2756G Side by Side Refrigerator
Ice maker does not work this is less than a year old and it has stoped working water is on as the water side works
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Sep 08, 2009 | Refrigerators
Ice maker has quit making ice
Lower the freezer temp. The icemaker won't come on until the temp is low enough.
Mar 10, 2009 | Fisher and Paykel E522B Stainless Steel...
GE GSS25SGRE side by side water dispenser...
The same thing happened to me. If you pull the refrigerator out and remove the large silver panel, you will see the water lines on the left. The line going to the ice maker was fine, but the line going to the water dispenser was split. You may have the same issue.
Jan 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Jenn air side by side refrigerator ice maker not working
On mine the water inlet feed tube would freeze solid. Removing the ice tray and using a hair dryer to completely thaw the tube would get it working for another month or so. My frig had a solid rubber inlet tube. I noticed at the appliance store that newer models had an inlet tube that was split on top. I got one of these from a local appliance parts store, and it fixed the problem. The tube replacement it easy. Get to the back of the frig. Turn off the water supply. Carefully pry the white plastic piece out ( located on the upper right side when facing the back of the frig. ) of the frig. When you have the new one in hand it will be clear what you are going to do. Pull out the old remove the water line. Attach the line to the new tube and insert it. Turn on water, check for leaks, and you should be ok. This repair is only effective if you have an inlet tube that freezes up. There can be many other malfunctions that stop ice makers from working. This was my problem. Replaced the tube 3 years ago and ice maker has worked fine since the replacement.
Nov 16, 2008 | Jenn-Air JCD2389G Side by Side...
Water leak From Back Of Fridge
hi that small hose is going in to the ice maker. buy a small clamp at the hardware store, and clamp the plastic hose holder. thanks the appliance doc
Oct 16, 2008 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
GE profile performance tfx30ppz ice dispenser not working
Had the same problem. The water line from the valve to the ice maker was cracked due to heat from the compressor.
Jan 09, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
U-Line Icemaker Logo
168 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Charles T Nevin
Charles T Nevin
jasbo
jasbo
john h
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
