While connecting TS4GJF300 to my laptop USB not recognised needs support
Error 43 is a usb universal serial bus controller problem for windows 7 you might try First, please disconnect all USB devices. Then, go through the following steps: 1. Press "Ctrl + Esc" to open the "Start" menu. 2. Type "devmgmt.msc" in the Search bar and press "Enter". Click "Continue" if necessary. 3. In Device Manger, press Tab and use "Up" and "Down" to move the highlight to "Universal Serial Bus Controllers". 4. Press "Right" and expand it. 5. Press "Down" to move to the first item and press "Delete" to remove it. 6. Repeat the step 5 and uninstall all items under "Universal Serial Bus Controllers". Then, restart your computer and Windows 7 will reinstall all controllers automatically.
click start control panel administrive tools ,computer management ,device manager scroll down
universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
if you can see your usb drive but its not working
ports(com&lpt)right click update driver
hope this helps
The Code 43 error is one of several Device Manager error codes. The Code 43 error will almost always display in the following way:
"Windows has stopped this device because it has reported problems. (Code 43)"
Details on Device Manager error codes like Code 43 are available in the Device Status area in the device's properties
