Question about Maytag MER6772 Gemini Electric Kitchen Range
Bottom oven lock will not lock to clean my Gemini model MER6770
I got my top oven to clean. The display said that both ovens were locked when only the top one was locked. I let the top one cool and cleaned and then tried to clean the bottom and the display gave me an F9-5 code to call service. It said the cleaning feature was not available and now neither oven will heat up and I still get that code. I unpluggled it several times and it didn't help. I have guests coming for the holidays tomorrow. Help!!!!
Karla Timpani
  • 61 Answers
The lower oven may have a problem . It could be a few different things the door latch mechanism, oven door switch, the metal rod that pulls the latch over all are quite difficult to figure out. I would recommend calling an authorized servicer on this one. good luck
Posted on Dec 22, 2008
What is Error message F9-5, bottom oven door is locked
Hello & Welcome to FixYa
Error F9-5 in your Maytage Gemini means Latch unlock lower and is displayed due to obstruction in door lock mechanism. If after cleaning the door lock mechanism the problem is still there then replacing the door lock mechanism is recommended repair. Please get back to me if you have any other questions.
Kevin
Feb 08, 2011 | Maytag MER6772 Gemini Electric Kitchen...
Cleaned bottom oven. Top oven door won't open
Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
Also check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Apr 11, 2010 | Maytag Appliances 27" Electric Double Wall...
Purchased at Maytag Gemini MER6770 in 2000. It
Sounds like the cancel (or stop) button is making contact by itself. Clock (oven control board) may need replacement.
One option to buy it new, your part number is 12001661
Coupon "New10" chops 10% off.
Another is to send the clock to be rebuilt. Google "stove timer rebuild", you'll find plenty of companies which can repair your original clock. In case you need it, the original part number is 74004542.
To get to the clock, remove the back of the control panel. Good luck.
Oct 24, 2009 | Maytag MER6772 Gemini Electric Kitchen...
The ovens fail to work after the cleaning cycle - displays says "call service". Now both ovens will not operate and neither do the timers.
Maytag model MER6772BAW was displayying f9-2 and call Authorized
service after cleaning also top door was locked and feature were disabled. I was able to solve the problem by unplugin the stove and waited about ten seconds before re-conecting once up the top door unlocked cleared the f9-2 error by pressing Auto set button and number 9 for Defauts. Perhaps this can help you.
Aug 14, 2009 | Maytag MER6772 Gemini Electric Kitchen...
I meant to push broil, but pushed clean and my food is locked inside. How do you cancel the clean?
Look at following areas for the model number
  • Under Right Front Burner
  • Under Left Top Burner Front Or Rear
  • Under Main Top Left, Rear Or Center Front
  • Under Left Rear Or Right Front Element
  • On Nameplate Inside Burner Box
  • On Front On Burner Box Bottom
  • On Nameplate On Oven Door Liner
  • On Main Front Behind Oven Or Compartment Door
  • On Front, Center Bottom Of Burner Box
  • On Thermostat Cover Under Main Top
  • Get me the model ,number for your oven and I will be able to help you better, Thanks, Sea Breeze
Mar 29, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Self-cleaning oven will not start.
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
sad
Dec 11, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Maytag top oven lock won't lock
Do you get any error codes? What shows on the display when you try? does it make any noises , like it is trying to lock? Is it a manual lock with a lever?
Jan 19, 2008 | Maytag MER5775Q Electric Kitchen Range
Self cleaning MAytag Gemini GAS oven
A wonderful feature is that the ovens self-clean with the press of a few buttons. Only one oven can be programmed to self-clean at a time. Remove the oven racks. Turn off the oven light and close the door. Press the "Clean" button and then press "Auto Set" to automatically clean the oven for 3 hours. Press the "Auto Set" pad again to set the oven for a 4-hour clean cycle, or press the button one more time for a 2-hour cleaning. The oven locks when in cleaning mode. When the oven is finished cleaning, the word "Cleaned" will be displayed on the control panel, and the oven will remain locked until the oven has cooled, which takes about an hour. To cancel the self-clean cycle, just press the "Cancel" button. Simple!
Dec 28, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Maytag MER6770 F1-3 code Serial #12650733ws
F1-3 is the code for the upper oven being over 950 deg F.
If the oven is now cool, then most likely there is a problem with the temp sensor in the upper oven.
You will need to remove the rear panel from the stove and check the resistence of the sensor to know for sure if it is bad. The only other way is to hook a new sensor to the harness and see if doors will unlock then.
Post back if you have any questions.
Nov 26, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Maytag MER6772 Gemini Electric Kitchen Range Logo
204 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
