Question about Shop Vac 925-13 Canister Wet/Dry Vacuum
Shop vac sucks water for a few seconds then it spits it back out
I was sucking water off a basement floor it was working for a few seconds and then it started to spit some of it back out. so i cleaned the canister out to see if that would work. the vac has suction and the hose isnt clogged, tried it again but did the same thing should i be using the filter for water too?
Don't use the paper filter for sucking water. It can ruin it. It will still be usable if you just set it out to dry but there is no reason to use it for water in my experience. I have a sears shop vac and it will fill up more than half full without ejecting the water.
Posted on Mar 15, 2009
Sucking and blowing
Shop-Vac® Brand. The Original Wet/Dry Vac™
https://www.shopvac.com/
Shop-Vac® is proud to be an American-based company. ... When we say the Shop-Vac® is powerful, we're talking debris cleaning, leaf-blowing, heavy-duty, wet or ... Many of our vacs are backed with a 3 to 5 year warranty, but we've seen ... I had just gotten back from work, so my arm was hurting, and I really didn't want to ...
My ShopVac Blows - WOOD Community
community.woodmagazine.com > Forums > Tools and Tool Buying
Nov 23, 2009 - My ShopVac suddenly started blowing dust out the exhaust ports. I don't mean a little dust, it blows almost as much dust as it sucks in!!!! ... ... I'd look it over very carefully looking for tears or splits. Might be a good idea just .... A few months ago I purchased a Dust Deputy and hooked it up to my shop vacuum.
10 Shop-Vac Vacuum Hacks For Around The House - Thrillist
https://www.thrillist.com/.../10-shop-vac-vacuum-hacks-for-around-the-...
Sep 14, 2015 - Simply flip the switch from suck to blow and blow leaves to your heart's... you really need to get your act together if you're using a Shop-Vac for ...
Shop Vacs...and dust control? - Home Forums - GardenWeb
ths.gardenweb.com > Home Forums > Cleaning Tips
Jan 09, 2016 | Shop Vac Vacuums
Hoover floor mate h3000 will not suction water from floor when cleaning
Your collection canister may not be positioned tight enough in its place ment site. Tip machine back using foot pedal (as if you were going tio start using machine to clean) Insert collection canister (bottom container, then insert top canister with solution. The two canisters must be flush with machine side seams and must sit in position tightly. This is sometimes very tricky and may take a little elbow grease to make it click into place. Hope this helps
Jul 08, 2015 | Hoover Floormate H3000 Upright Wet/Dry...
Can not get my steam vac to suck up water everything else works.done half floor empty water to do other half of floor and it just stopped sucking up water
  • There a twist lever on the side to change from floor to tools. If "everything else works" then you have it on tools. Twist it back to floor and it will work.
Sep 11, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
Vacuum motor noise and smell
If the ball was stuck and you sucked water into the motor it could cause it to smell like it's burning if it ruined the motor
Jan 10, 2014 | Shop Vac Vacuums
Shop-Vac 6.0 hp Peak 12 Gallon 'Exploding' after 10 seconds of use. Happened twice on two different brand new Shop-Vacs.
Since you said you were sucking water out of a "trench" I would bet there was some debris in the trench that impacted the impeller on the vacuum and caused the metal impeller to fragment, taking the plastic pieces with it. It is highly unusual for this to occur on vacuums if some type of debris, such as a small stone or piece of metal does not reach the high speed impeller/fan. I suggest using either a foam sleeve over the filter cage, or an old nylon stocking if you can get one, to screen out the debris that will cause this condition.
Nov 20, 2013 | Shop Vac Vacuums
Vacuum picks up some dirt and debris but not all, and spits some back out?
Some blockage at the pickup or in the hose if it uses one---dirt etc being kicked back out is a clear sign of this----if it has a tube check that first, and if a head with turning brush do not miss looking for a blockage there.
Dec 11, 2012 | Eureka True Clean Upright Vacuum (Yellow)...
My shop vac is not sucking anything only blowing air out of the open hole where the hose should go if I wanted to blow something. I want it to vacuum not blow out. The filter sleeve and dry cloth are...
I just had the same problem, the vac wouldn't suck in. Turned out to be because the filter was WET. It works great when I take the filter off before sucking up water or liquids! Not sure if this applies in your case, but definitely something to keep in mind. : )
Jan 17, 2011 | Shop Vac Shop-Vac& Mini Hang Up Wet/Dry...
Every thing clean & sucking well except wont pickup off floor. brush in good condition &rotating. any answers would help.
This is hard to answer without see it in person. Check and make sure there is no broken pieces on the bottom where you could loose suction. Also make sure you have the machine set correctly for either bare floors or carpet. If it is on set on carpet and yopu are cleaning bare floors you might loose suction there also. Also make sure you check all pathways for the dirt to get to the canister fo any signs of blockage. Are all the filters in place like they should be? Sounds like the suction is getting diverted from the floor somehow, make sure everything is secure and locked in place on the canister. Also check on the top of the handle and make sure the little purple screen is moved back into place covering the top of the handle, you could be sucking more air in thru this inlet and not enough off the floor! This is usually moved out of the way when you connect the hose to the handle for your attatchments. It may still be pulled back and needs to be moved forward into place!
Nov 15, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
My basement is flooding and my 5 gal shop will not **** up the water. It works momentarily and then spits the water back out
You should remove the filter that is inside the vac. This should allow for the vac to **** up the water. But just in case that doesn't do it, here is a link to a site that may contain a free download of your manual:
www.shopvac.com/parts_pdfs.asp?p=%25&Submit=Search
Just look up your type of vac and click on it.
Good Luck!
Jim
Oct 01, 2010 | Shop Vac (464-38-10) Canister Wet/Dry...
My sanyo power brush is spitting out dust instad of sucking it in
Check for a plugged hose or wand, this is a classic sign of a plug some where between the power head and canister.
Tom
Sep 24, 2009 | Sanyo SC-X1000P Canister Vacuum
Shop Vac 925-13 Canister Wet/Dry Vacuum Logo
1,384 people viewed this question
Top Shop Vac Vacuums Experts
Mike
Are you a Shop Vac Vacuum Expert? Answer questions, earn points and help others
