Question about Magellan RoadMate 1412 Car GPS Receiver
Garmin 1412, wont run on battery power, DC only. Need info on maybe a full reset whether to return as defective
  • sammer003 Dec 25, 2008
    I have the same problem. It's brand new. I've charged it with a 120v to USB charging adapter, the same for my phone, pda, bluetooth headset - anything with mini-usb. I've tried charging it OFF, and ON for 3+ hours each time. As soon as I unplug it, the battery level goes from FULL to ONE bar, and then within 10min, it will auto-power off on batteries.
    I'm going to return it.
  • m_c_shepard Jan 17, 2009
    When we unplug from 12v thebattery will not turn on. It will not work in the car using the cigarette lighter. It gets power will not chargethe battery
I found there are select 120v AC adapters that will work on Magellan GPS. When a working 120v or 12v adapter to mini USB adapter is plugged into the unit, the battery bars will be 'scrolling' and therefore charging.
When your adapter, or even USB cable from your computer, is plugged into the GPS unit, and the battery goes to FULL, it is NOT CHARGING. The battery bars must be SCROLLING for the unit to charge. In this case, get a different adapter until it works.
Posted on Dec 28, 2008
  • donald_gi10 Sep 24, 2011
    I have the same problem and I just fixed mine. The stupid at magellan soldered the USB port to the board using sideways solder joints, without a "stop" for the back of the USB port, so every time you plug in the USB, you are stressing the solder joints which eventually fail. (1) get a tiny micro screwdriver and pull out the 4x plugs on the back which cover the screws, (2) unscrew the 4 screws on the back, (3) using a midsized or larger micro screwdriver, pull off the back, (4) using your thumb, press down on the micro USB port and plug in the charge cable, mine came on right away with my thumb pressing the 4 solder connections down, (5) use a soldering iron to reflow the joint.
Charging problem
If the internal battery won't charge, then the battery is likely defective. Contact Garmin to find out your options. Whether still under warranty or not, they can usually repair it for less than the cost of replacing it. They're a good company with a good reputation for customer service.
Jan 26, 2014 | Garmin Astro 320 - Gps Receiver
My garmin will not turn back on
First make sure that it is fully charged. Try a soft reset by sliding the power switch to the left and holding for at least 10 seconds.
Common problem with this model is a defective USB port that prevents the battery from being charged or powering the unit with the DC charger.
More info can be found here:
http://www.sharc.net/gps_charger_repair.htm
http://www.sharc.net/discus/messages/6/313.html?1338221806
Mar 19, 2013 | Garmin nuvi 200W GPS Receiver
Have JVC gzmg230U camcorder. battery works fine. But will not work on the camacorder. Cam only works with AC charger.How can it work with the battery?
It hard to isolate the problem like this. But maybe we can begin with this, try to test your data battery(your battery) press and hold BATT INFO while you are charging, it must show you some percentage of power available if not check battery contact..or maybe the battery itself has problem, symptoms of defective battery is like it easily indicates full or no response at all. Lastly I want you to try with another battery you know its good. If all of these doesn't help I'm afraid that your camera needs service sometimes DC JACK makes problem after frequent connect/disconnect. Hope it helps
Feb 26, 2010 | JVC GZ-MG330 HDD Camcorder
My garmin nuvi 265 will keep shutting down and rebooting while being used. any suggestions, it is just over 1 year old and this happens whether on battery power or if connected to DC power
I can help you reset and fix your Garmin Nuvi 265W.
Getting stuck on the flashing Garmin logo, or a message about not finding any maps, or freezing and rebooting, are indications that the firmware / system software inside your GPS has been corrupted.
There are three steps to take to get your Nuvi 265W running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_____________________________
Nuvi 265W Manuals here.
Feb 01, 2010 | Garmin Nuvi 265W GPS Receiver
Good Morning, My sat nav has turned it's sefl off and wont come back on .....! Any ideas ..... Regards, Lee.
If you have an AC to DC eliminator (adapter) for this unit try to switch it on while this adapter is connected. May need to keep the power on button pressed for 2 or 3 seconds. Also check whether there is fuse in the cable that runs from your cigarette lighter plug to the GPS. If there is one, check whether it is a blown fuse. If there is a multimeter available check the voltage at the tip of the cable. If all these seems to be alright, and if this is a very old unit, check whether you can open this unit and replace the battery. Most chances are that the battery is dead, or it is not charging.
Jan 28, 2010 | Garmin StreetPilot c510 Deluxe GPS...
Dell inspiron 700m wont power up
Which way do you power up the laptop?
The AC power or laptop battery?
If the AC power, you should check the wire is connected well.
If the battery, you should check whether the battery is charged full.Maybe the battery is aging, you need to get a new Dell inspiron 700m battery.
You can get a replacement at shop-batteries.com
Aug 26, 2009 | Dell Computers & Internet
Midland rechargeable battery packs won't recharge and vibrate
You might contact Midland Radio Corp to see if they have a fix for your problem. If I had to give an educated guess I would say the batteries need jump started (which sometimes happens when they are new and too low of charge; or there is a problem where they contact the charger and they are not receiving a full charge; or they are defective. I am sure the factory would be happy to assist you in solving the issue.
Here is there info: http://www.midlandradio.com/contact_us.asp
MIDLAND RADIO CORPORATION
5900 Parretta Drive
Kansas City, MO 64120
P. 816.241.8500
F. 816.241.5713
Email: mail@midlandradio.com
Nov 07, 2008 | Radio Communications
My garmin nuvi will work on battery power but will not work if attached to charger.
what charger? AC or DC? You need to give more specific information. If it's the DC charger, check for a blown fuse in the charger or a fuse for your cigrarette lighter socket. The AC charger is non-user servicable and will need to be replaced if it's defective.
Nov 05, 2008 | Garmin GPS
Roadmate 1412
We did not get a solution in the chat room. So we returned the unit to Costco and things are fine with the new unit although the return guy seem surprised that the fault could be in the unit itself. Thanks anyway.. Do we get that refund?
Jul 10, 2008 | Garmin StreetPilot C330 GPS Receiver
Magellan RoadMate 1412 Car GPS Receiver Logo
318 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Steve
Steve
Are you a Magellan GPS Expert? Answer questions, earn points and help others
