2002 Nissan Sentra Logo
Anonymous Posted on Dec 22, 2008
Heater blowing cold air
2005 nissan sentra blowing cold air. No leaks on floorboard, coolant level is ok and is clean, the air seems to have no heat at all in it. No indication of air pockets in system and no indication of engine overheating Just started looking into this. the heater blew some slightly warm air this morning on and off. My wife said the water temp guage was slightly cooler than normal.
I added a little bit of coolant last night, maybe 1/2 gallon. It still goes up to the top of the normal range of the temp guage, but not beyond. Then it goes back to just below normal.
I wonder if the thermostat went bad, and then the computer detected it and shut off the hot water to the heater core? After reading some of these questions I think the computer is involved somehow.
  • Anonymous Dec 26, 2008
    My wife took it to a dealer garage, and they said it needs a new head gasket. This was apparently a problem with that year, and there are a lot of stories on the Internet about it. So I think I can accept their diagnosis.
    BTW, when adding coolant, this engine needs to have an air valve opened so that bubbles can escape.
    I assume they found some coolant on one of the plugs. So this is a job I can do myself, and while everything's apart, I will replace the belts and an idler. And maybe the timing chain tensioner.
  • Anonymous Nov 27, 2011
    So, it's been over a year, maybe two since I had this problem. It was a blown head gasket, and what was happening was exhaust gas was blowing through the leaking head gasket into the coolant, and those bubbles accumulated in the heater core. The simple test is to open the coolant reservoir and sniff for exhaust. It has a peculiar odor, not what you'd expect from a coolant reservoir. Also, you can test the coolant if you have that wherewithall.
    I could get it to blow hot by driving up a steep hill, and then within a minute, the bubbles would return to the core. Especially when the engine was at high rpms, it might run hot for a moment due to fast coolant flows, but the gas would quickly return.
    this is a problem with these sentras, it is a borderline lemon thing, in my opinion, but not bad enough to cause any kind of recall. I'll never buy a nissan again, unless i absolutely have to.
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Oct 16, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
3666
Points
9
My 2005 Nissan Sentra 1.8s with 55,000 mi. blows cold air from the heater. Coolant not circulating in engine. Lower hose stays cool to touch. Both heater hoses cold. Changed thermostat - didn't fix it. Coolant not leaking or dirty. None in oil - no oil in radiator. Changed worn water pump belt - pump spins freely with no noise or resistance. Cooling fans come on after warm-up. Temperature gauge stays in normal range then jumps to hot and back again. Coolant good to 10 below - didn't freeze here yet. No other problems or repairs to car. Afraid to drive and make worse. Help!
Dean Bendickson
Level 1:
Habit-Forming:
New Friend:
  • Contributor 28 Answers
  • Posted on Jan 29, 2015
Dean Bendickson
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
28
Questions
0
Helped
20730
Points
35
I am a nissan tech. The sentra and altima can be hard to burp all of the air from the cooling system. Depending on what engine that you have in the car, some of those nissans also have a water valve besides the main thermostat. They are very temperamental that there is a 50/50 coolant water mix. There is also a lot of head gasket issues that we have seen on those engines
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 23, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2721
Points
Just simply change the thermostat....I had the same problem and this is what I did and now it's hot as hell.
Aaron urban
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
Aaron urban
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
Questions
0
Helped
2721
Points
My 98 nissan altima gxe hhas had this same problem and I have already replaced the thermostat but the water still isnt circulating and heater did work until the car overheated...There is no indiction that the water pump is bad...The temperature gauge stays on normal but the car is overheating
2003 toyota celica vvtli 190bhp heater blowing col dair only and engine over heating. no signs of leaks oil clean, coolant resivour just above min any ideas whats broken cheers
If it is blowing cold air, that means the coolant level is low, the heater core has no coolant in it. Sounds like a head gasket is leaking.
I have an 1996 Nissan Sentra GXE i live in ND and the heater only blows luke warm air while at full operating temperature. I replaced the thermostat and flushed the heater core which seemed clean....
Sounds like it's the air control flap which determines the mix of heated and fresh air. This could be vacuum controlled or manually with a cable.
Blows cold air from heater. Replaced Thermostat. Still blows cold air.
will try to help. is your radiator full of fluid? sometimes there will be an air lock, or [air in hoses] with the engine running at first started!!! take the radiator cap off, fill with 50/50 antifreeze. or if you are in alaska, seek advice from local parts store on level you need for coverage.you may have a bad bad heater core, but not likely because you would say you have fluid leaking onto passenger side floorboard.you may have purchased the car used?somewhere there is a blockage in your system.either a bad radiator,heater core,i will try to help because i've had same problem,in the FRONT OF RADIATOR]place a small peice of cardboard in the front of radiator!!ONLY COVER HALF OF THE RADIATOR] slide it down in front of the radiator on the side of the part where the radiator fan is not at. then you will have heat. if yout engine temperature rises to unsafe level, cut cardboard in half and replace!!!make sure;to put in front of the radiator only!!!this will apply heat to car while in motion!
2004 nissan sentra heater only blows hot air at 30 mph none when at idle
check your coolant level, it's probably low. if so find the leak to prevent serious engine damage. if coolant level is ok, suspect a thermostat that is stuck in the open position. good luck.
1helpful
Heat blows out cool air when sitting but when drove it blows out warm air 2005 nissan sentra
low coolant. check coolant level. possible that u have a coolant leak
7helpful
2answers
No heat
4helpful
3answers
My 05 sentra with 79k miles heat will warm up and then get cold after a mile of driving, we have tried to get the air pocket out, the mechanic stated he thought it could be a blown head gasket, another mechanic said it was a bad heater core. Any advice would be appreciated.
Top Nissan Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Nissan Expert? Answer questions, earn points and help others
