Question about Toshiba Satellite A100-S8111TD Notebook
When I open the lid of my laptop fully, the screen goes black.
I only get the screen to illuminate if it is open less than 90 degrees. If I open any wider than that, the screen goes black.
    Scholar:
  • 130 Answers
Sounds like the ribbon cable connected to the display is loose, I would send in for repair, shoun't cost much.
Posted on Dec 22, 2008
Screen goes black close lid and open screen works fine
what configuration of the power manager do you use? laptop goes to hibernation mode automatically or by pressing the power button or by closing the lid?
Feb 04, 2014 | Dell Inspiron 1420 Laptop
My HP Pavillion G6 laptop screen goes black if not tilted in two certain positions
Sounds like the cable feeding the inverter is either faulty or has a bad connection. You will need to take the laptop to bits. See utube video.
http://www.youtube.com/watch?v=M7CEtfJtu_Y
Hope that helps.
Dec 29, 2013 | HP Pavilion Computers & Internet
Dark screen when fully open amilo m1425
There is a loosing in circuit board, you might not be able to fix this problem by your self it needs technical proficiency
May 13, 2012 | Fujitsu Siemens Amilo M1425
When I open my laptop lid pass 90 degrees, the screen goes blank
It should be a Problem of a loose conection.
if you feel you are good to take it apart there are a lot of tutorials on the web in how to take it apart and reattach the flex cable. (maybe even change it)
otherwise take it to a laptop specialist
Jun 07, 2011 | Toshiba Satellite P200-0TD00Y Notebook
My toshiba satellite laptop screen goes black every time I open it passed 90 degrees what should I do
REplace the flexible cable that feeds the screen from the motherboard if it is damaged or just plug the cable in as it may not be connecting properly.
Jan 27, 2011 | Toshiba Satellite A135-S2276 Notebook
When the screen is tilt back more than 90 degrees shuts off
Look closely at the area where the computer "folds";
there's a small sensor that should trigger when you *CLOSE* the lid -- perhaps, something is triggering that sensor (a small pin) when you're exceeding 90 degrees, putting the computer to "sleep".
Apr 05, 2010 | Compaq CQ60-215DX Notebook
Screen turns off when opened
There is a thin ribbon cable that runs between your screen and the rest of the laptop. every time you open/close the lid it flexes that cable.
Something in your cable is coming loose, it could be that a wire in the cable is broken and connects only at certain screen angles or perhaps one end of the cable is loose.
You need to take the bezel off to get to the cable, verify that the cable is plugged in, if the problem still occurs then replace the cable.
You should find the cable fairly cheaply on ebay, search for acer "model" lcd ribbon cable.
Let me know if this helps.
Mar 24, 2010 | Office Equipment & Supplies
DS Lite, the top screen goes black when opened the whole way when the game is opened to a 90 degree angle the screen is clear and works fine.
There are a few things that could have happened, the most likely that one of you cable clips is loose, and when you open it fully, it pulls it out just enough so that the connection is lost.
Your going to need to open your DS, (the forms at www.powergamingparts.com are the best forms to find these instructions) then just disable your clip, and reinsert it, and then close the clip, and put you DS back together. Just ask if you need any additional help.
Sep 27, 2009 | Nintendo DS Lite Console
DV9000 Black Screen
You just need to diable presentation mode.It's not the switch.
Mar 22, 2009 | HP Pavilion dv9000t PC Notebook
If I open my Satellite A105 display too far, it goes black.
Hi, This is definitely a loose connection problem.
Does the screen go completely black or just a part ?
If its just a part, LCD is defective. You may have to change the whole LCD screen. You can get one for ~180$ from ebay
If the whole is turning off, I guess the power cable might be little loose.
You can open the LCD panel and check if you know what you are doing.
Else take it to a normal technician and ask him to open the LCD panel and see it.
Nov 17, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
250 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
