Question about D-Link DIR-625 (790069292637) Wireless Router
Cant figureout how to set a password to a d-link router
I want to set a password to my d-link router dir-625. but i cant figure it out for the life of me. please help other people useing it are slowing down my connection
  • 104 Answers
Hi…I’ll try and lend a hand. There are several ways to set up wireless security on this router. However, I’ll help you set it up using the manual method.
Important note: use a wired (Ethernet) connection to the router to set up wireless security.
There are four main steps:
1) Login to your router.
I’m sure you have done this already, but here it is again for clarity. Type the router address in the address bar of a web browser. For this router, it is http://192.168.0.1
Select ‘Admin’ from the dropdown box, then enter your password IF you have set one – otherwise, just leave the field blank and press return.
You should then see the configuration screen/user interface.
2) Change the router password.
If you HAVEN’T set a password, this is a good place to start. Go to Tools >Admin option. Set and confirm a password for ‘Admin’, and note it down. Also, set and confirm a password for ‘User’. Click ‘save settings’ when finished.
Make sure these passwords are not easy to guess, or a neighbour could log into your router and view/change all your settings.
3) Change the SSID (router name):
Go to Setup > Wireless Settings. You should see an option marked ‘Wireless Network Name’ or SSID. Change this from the default, ‘dlink’, to anything you like –as long as you can remember it. It is case sensitive, and you can use up to 32 letters – but don’t use something that could identify you, or your location. Click ‘save settings’ when finished.
4) Enable encryption
Still in the 'Wireless Settings' menu option, you should see the ‘Wireless Security Mode’ section. Under the 'Security mode' dropdown you have a number of options for encryption. WPA is safest....I would pick WPA-Personal.
You should see a dropdown box marked WPA Mode – select Auto. Leave Group Key Update Interval at the default of 3600s.
Under Pre-Shared Key you should enter a long password, or passphrase, between 8 and 63 letters/numbers long. This can be any series of letters/ numbers, or you can use a phrase with numbers ( eg - 456HappyhOLIdaystoyou8899). It is case sensitive.
Note down the passphrase carefully. You will need this to connect wirelessly. (The WPA shared key may also be called the network key, PSK, pre-shared key or passphrase). Click 'Save settings' when finished.
That's it, you have done enough to secure your network, and can close the screen.
There are further security options to enable if you wish, but these three are the most important.
When you next connect wirelessly, you'll see the router with its new name in your 'available wireless networks'. When you attempt to connect, you are asked for the WPA shared key you set in Step 4. If all goes well, you can then save this and will connect automatically in future.
Hope this helps you. Please come back to Fixya if this doesn't work or if you need help with any of it.
Posted on Dec 23, 2008
I don't know how to reset password for d-link DIR-625
Section 1 - Product OverviewHardware OverviewConnectionsUSB Connect a USB 1.1 or 2.0 flash drive to configure the wireless settings using WCN.Reset Pressing the Reset button restores the router to its original factory default settings.LAN Ports (1-4) Connect Ethernet devices such as computers, switches, and hubs.Internet Port The auto MDI/MDIX Internet port is the connection for the Ethernet cable to the cable or DSL modem.Power Receptor Receptor for the supplied power adapter.D-Link DIR-65 User Manual
If you don't know it you can check our list of default router and modem password list here.
If you have changed it and don't remember it you may have to reset your device to factory default using the reset button on most routers.
Sep 23, 2011 | D-Link DIR-625 (790069292637) Wireless...
I don't know how to set a password on my d-link router because my internet is insecure. How do i do this? I have the default username and password, but i don't know what to do from there.
1.Open your Internet browser and type in the default IP address for your DIR-625 wireless router: 192.168.0.1. A window will appear asking for your DIR-625 wireless router network name and password. If you do not know your existing network name, enter the default network name, "Admin." Leave the password blank. If you have already set up a network name and password, enter it now. Select "Log In."
2.Select "Wireless Settings" from the left-hand navigation bar. Put a check mark in the box marked "Enable Wireless."
3.Type your new wireless network name for your DIR-625 in the box labeled "Wireless Network Name."
4.Type your new password for your DIR-635 in the box labeled "Pre-Shared Key."
5.Select "Save Settings" from the top of the screen to save your new password.
Feb 07, 2011 | D-Link DIR-625 (790069292637) Wireless...
Hi, i m not able to connect my wii on internet.
You need to set up the IP address, Gateway and DNS fields from your route's main menu.
Actually dir-625 have a default IP Address: 192.168.0.1
Default admin username: Admin
Default admin password: (blank)
Also check it in your Local area connection, your Gateway Address: 192.168.x.x
Jan 08, 2011 | D-Link DIR-625 (790069292637) Wireless...
How do I reset my D.Link DIR-625 router if I forgot the password?
Thank you for posting on fixya. Am pleased to help you.
I understood your issue and I would request you to follow the below steps. Note: Once reset is done, DIR-625 will have the default settings.
Look on the rear side of DIR-625. There should be a small hole, usually just to the
left of the power jack on DLinks. Inside that hole is a small button. Find
something small enough to press and hold it while the DIR-625 is powered up.
While pressing and holding, watch the lights on the front. With DLinks, its
usually the M1 and M2 lights that will go solid while holding the reset
button. Keep holding the reset until they start blinking. Its now reset.
To reconfigure:
1. Type in 192.168.2.1 on your web browser. 2. At Router's login page, type your username and password(Default Username: admin Password: (blank) ). 3.Once you are in, browse the different tabs for various settings. [ Contact DLINK customer support for details. Toll free number on products box] .
Thank you an have a great day. Feedbacks are appreciated.
Nov 01, 2010 | D-Link DIR-625 (790069292637) Wireless...
How do you change password
To change the password on the router you'll need to login into it using the userid/password you initially setup, if you don't remember what those are you can always reset the router back to the factory settings via the reset button on the back of the router.
Jun 21, 2010 | D-Link DIR-625 (790069292637) Wireless...
I have D-link 625 Wireless router but i try to connect on my desk top computer by Belkin G wireless USB network Adapter 5012. If i put password on WSK-Personal ( on wifi password setting) is not going...
Check your settings on your wireless setup and make sure the adapter on your computer is set to Security Type: Shared. That is the most over-looked stumbling block.
Nov 15, 2009 | D-Link DIR-625 (790069292637) Wireless...
How do you retrieve a lost password on dlink dir-625
Is it the password to access the router menu or to connect to is? sometimes the password for the menu is 1-9 or 0123456789 and to connect the default is usually one of the numbers on the sticker on the router itself
Sep 26, 2009 | D-Link DIR-625 (790069292637) Wireless...
Need to set channel to 1 or 11 to download to wii for DIR-625
Go into the wireless router configuration
Start up a browser and tpye in this URL
http://192.168.0.1
The login name = admin
The default password is blank (ie nothing unless you have changed it - this should have been done for protection)
then go into the wireless settings and change the channel to whay you need and save the settings.
Sep 13, 2009 | D-Link DIR-625 (790069292637) Wireless...
How do I open port 30000 in a DIR-625 router?
Hello marquitos4,
Go to http://portforward.com/english/routers/port_forwarding/Dlink/DIR-625/DIR-625index.htm
and you will find all the info you need regarding port forwarding through your D-Link router.
The page is specific to the DIR-625 but just about any make/model is supported at http://portforward.com/
Enjoy,
FixThemAll......
Dec 15, 2008 | D-Link DIR-625 (790069292637) Wireless...
D-Link DIR-625 (790069292637) Wireless Router Logo
1,670 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
