Question about HP Compaq nc6220 Notebook
How do i get the internal ram out of a nc6220?
  • 69 Answers
1) take out of the power cord
2) remove the batterry from the notebook
3) turn the notebook around to the bottom
4) remove the screws from the caps under the notebook
and there u will find the hdd,wifi,memory and so on
the memory sits in to small hooks gently push it to the side and the memory will pop out
Posted on Dec 22, 2008
  • 741 Answers
There are two slots for RAM in the NC6220. The RAM is DDR2 and will take 1GB per slot. So first ensure you have the right RAM. Then turn the laptop over and:
  1. unplug and remove Battery from laptop
  2. Open memory compartment on bottom using Philips screw driver
  3. inset memory in open slot, if no open slot remove current memory by pinching metal clasp on side of memory
  4. Close compartment and power up you are off and running.
HP Compaq NC6220 No Power
Computer does not boot up The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
Jan 07, 2013 | HP Compaq nc6220 Notebook
Battery is not charging, I only get this "plugged in, not charging".
How old is the battery? It may be done. Is it a replacement?
Dec 14, 2012 | HP Compaq nc6220 Notebook
Compaq nc6220 freezes during POST
Start in Safe Mode by pressing F8 during boot. Then...
Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig > Startup tab and uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running.
This just disables them in startup. Programs will still load, but when you initiate.
Oct 04, 2012 | HP Compaq nc6220 Notebook
I have nc6220 1.86 with 1GB ram and 60 gb drive but unable to instal win7
what error messages are you getting? more than likely it's failing because the graphics hardware is NOT compatible with Windows 7.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
May 28, 2012 | HP Compaq nc6220 Notebook
Where is my ram
usually located in a door on underside of laptop
Mar 28, 2012 | HP Compaq nc6220 Notebook
It powers very well but no display both on external and internal vga
Check ram and inter change it, if problem is not solved when its mother board problem...
Check with nearby laptop service center.
Nov 06, 2010 | HP Compaq nc6220 Notebook
My laptop microphone is muted
Open control panel and double click Sound.Under recording tab, select Internal mic and click properties. Verify if the levels are set too low for the microphone.
Hope this helps :)
Aug 06, 2010 | HP Compaq nc6220 Notebook
I have 1.49g ram and need an upgrade to 2g
The absolute best way is to go to www.crucial.com. The website will test your PC automatically and tell you exactly what you have and what kind of RAM you need. It will also offer the correct RAM for you on the same site, so you can do it all in one swoop..pls rate this solution. Once you receive the RAM, the Sticks are under the largest panel under your notebook. You can get the manual off of your manufacturers website to see exactly which screws to take out..but normall its under the largest plate..good luck..pls rate this solution
Apr 23, 2009 | HP Compaq nc6220 Notebook
Hp nc6220 not starting up
You could have a motherboard problem or faulty RAM modules.
Try reseating the RAM modules and the boot up the laptop or get the RAM modules tested at your friendly computer shop.
If this doesn't work, most you have a nice pape weight.
You could then salvage the hard drive and insert it into an USB hard drive adapter case and use it as an external USB hard drive.
Apr 18, 2009 | HP Compaq nc6220 Notebook
HP Compaq nc6220 Notebook Logo
247 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
