Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
Ignition failure code on my furnace
I am getting an ignition failure code on my coleman evcon furnace. I have already cleaned the flame sensor with a 220 grit sandpaper. The problem remains. The unit calls for heat from the tstat, the ignitor glows bright orange, the flame ignites and i can see it thru the observation hole, then just as the blower motor kicks on the flame goes out. PLEASE HELP I AM COLD!
  • randywilhelm Jan 01, 2009
    I have a coleman Model DGAT070BTE that will glow and then ignite, but when the blower kicks on the flame goes out. I have already cleaned the sensor unit off with steel wool. I did notice a small break in the insulation of the yellow wire going to the sensor unit, located about 3/4" from the aft end of the sensor.
4 Suggested Answers
  • 3328 Answers
SOURCE: coleman evcon furnace
is the air filter clean afc could be dirty
Posted on Jan 22, 2010
  • 3328 Answers
SOURCE: I have a coleman evcon model dgat070bdf furnace.
Hi check the flame sensor is clean also check out the pressure switch , and check air filter is clean
Posted on Feb 05, 2010
SOURCE: Have a Evcon Coleman Furnace shows three green
I have had the same problem with mine for the last 2 years. Remove the motor on the side of the furnace(usually held on by 3 screws) and turn the fan blades inside by hand. after sitting all summer it seems to get stuck. If it moves freely, replace the motor and try to start it again. This fixed mine the last 2 years! Hope this helped.
Posted on Oct 04, 2010
Where is my flame sensor on a single burner coleman evcon high efficiency furnace
If this is a hot surface ignition system, the sensor may also be your igniter.
Dec 11, 2013 | Heating & Cooling
Ignition failure coleman furnace
It could be the flame sensor is dirty remove and clean it with some steel wool or fine sandpaper and reinstall . Hope this helps
Dec 05, 2013 | Tools & Hardware - Others
Coleman evcon furnace
So the furnace will come on and heat sometimes ? Then other times it will click but not heat ?
Check for fault codes if it has them and make sure it is clean inside burner tubes and clean the flame sensor.
Oct 13, 2013 | Heating & Cooling
I have a coleman evcon model dgat070bdf furnace. As soon as the furnace fan kicks on the burner shuts off. Any ideas?
Feb 05, 2010 | Coleman Propane Forced Air Heater...
Evcon Coleman mobile home furnace needs repair
if you know what the flame sensor is try gently cleaning it with sandpaper they get gummed up sometimes and don't sense the piolet flame, if they don;t see a piolet it will not allow it to kick the gas on
Oct 10, 2009 | Tools & Hardware - Others
Burner flame going out on windy days on Coleman Evcon LP furnace
This sounds like a bad heat exchanger. It is possible that you do not see the crack because the crack is closed when the heat exchanger is cold (or room temp). Allow the furnace to heat up, this will allow the expansion of the crack. Turn the power off and examine the heat exchanger while it is still hot.
Mar 31, 2009 | Coleman Propane Forced Air Heater...
Dec 22, 2008 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
862 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
