Before cooking, rinse rice in warm water until water becomes clear. Then place
the rice in the inner pot with fresh water.
Take care to use proper water to rice ratios.
Use a 1:1 ratio of rice to water plus ½ cup of water for white rice and a 1:1
ratio plus ¾ cup of water for brown rice.
P.S. - If you find that the solution/answer
I provided led you to, or resulted in a fix, please close the ticket with a FixYa!
rating.I would be very grateful for your show of appreciation. If it hasn’t, please do not assign a rating just
yet. Please post back as to what steps you took, results, etc, and I will try to
assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers! IrishDruid
Comment by IrishDruid, posted on May 03, 2008
Just wanted to inquire if your issue is resolved, or if there is anything
further I can do to assist you…
If you find that the solution/answer I provided led you
to, or resulted in a fix, please take a moment to close the ticket with a FixYa!
rating under my solution.I would be very grateful for your show of appreciation.
Should you have any further questions, please feel free to
post them here.
Cheers! IrishDruid
Comment by IrishDruid, posted on May 31, 2008
P.S. -You can rate this solution with one of
four votes, if you feel your issue is resolved.
"FixYa!"
- The solution provides great advice on how to solve the problem.
(Positive Rating)
"Helpful"
- The solution provides useful leads that helps solve the problem.
(Positive Rating)
"Thanks
for Trying" - The solution does not solve the problem but the
effort is appreciated. (Negative Rating)
"Inappropriate"
- The solution has absolutely nothing to do with the problem.(Negative
Rating)
If your issue is not still not resolved, do not
assign a rating just yet. Please post back as to what steps you took, results,
etc, and I will try to assist you further as best I can.
IrishDruid
Was this solution helpful? Show your Appreciation by rating it:
Show your appreciation by commenting on How much water should I use with my rice cooker with different types of rice? Type of Rice:Cups of ....:
Solution #3
posted on Aug 08, 2005
Powe33 - usenet poster
Rank: Apprentice Rating: 0%, 0 votes
Oriental/Soft Rice: 2 Cups of Water, 1 Cup of Rice Basmati/Indian Firm Rice: 1.5 Cups of Water, 1 Cup of Rice Brown Rice Varieties: 2 Cups & 2 Tablespoons Water, 1 Cup Rice
My Aroma instructions say for 2 cups of rice to add 2 1/2 cups water, for 3 cups add 3 1/2 cups of water etc. (add the same amount of water as rice plus and additional 1/2 cup of water)
Add an additional 3/4 cups of water for brown or wild rice.
that's very easy.. if you wand your rice to be dry, then use the same exact number of cups of water with the rice.. example,
2 cups of rice + 2 cups of water = dry rice
if you want it to be soft, add additional 1 cup of water. example
2 cups of rice + 2 cups of water = soft rice
i need to know how much rice to add to a salton 3 cuo electric rice maker and then how much water to add, using long grain rice thankyou mamae4@aol.com
