Question about Motorola Mobility RAZR V3
Select button my select button has stopped functioning, so i am unable to access anything that requires the use of that button, does anybody have solution or suggestion?
  • 62 Answers
Open up your keypad through your phone check the solved solutions, and check to see if something clogging it or if it's dirty, but if the button is worn and won't pop in and out when you press it this wont help.
Posted on Apr 10, 2007
Unable to write the file to "Destination Folder"
A recent (Dec 2015) Windows 10 update seems to have removed the access required for the service account used by Brother to write to the hard drive. This fixed the scan function for me...
  1. Navigate to the directory where you write the files (C:\Users\YourID\Pictures\ControlCenter3)
  2. Right click on the Scan directory and open Properties.
  3. Click Security tab.
  4. Click Edit
  5. Select WMPNetworkSvc
  6. Allow Full Control
  7. Click OK
Nov 11, 2011 | Brother MFC-6890CDW Printer
Tip
Lost Remote Control? Here's a way to help.
So you have lost, or, your remote doesn't work? You can't "Do anything" without it.... Right.... NO Wrong... ALL TV sets have a number, usually about 5 - 6, "Buttons" on the side, front, somewhere. usually close to the "Power ON" switch. Now these "Buttons" will perform nearly all, if not all, of the main functions of your "Remote" They WILL be marked, MENU, +, -, <, >, & OK or ENTER. Now you simply have to depress each button to access the "Functions" you want. One button WILL control the "Function" say Channel, and the <, >, will Go UP & DOWN. This is the same for everything. So one button will make it, say go UP, another will make it,say, go DOWN. Repeated presses on the "Function" Button will scroll through the "Functions" IE: Channel, Brightness/Contrast, Selecting Inputs, once "Selected" another "Button" will move the "Selector" through to the Bottom & another will scroll it back Up, sometimes the ONE button will simply continuously scroll "right around" Of course have a look in your manual... you know that paper thing you shoved away in the cupboard... This will explain it all. ALL TV's and devices that use a "Remote" are ALWAYS able to "Control" the MAIN functions of the unit,via keys on the actual unit itself. So don't despair, just spend a bit of time learning your "Buttons" that way even if the "Remote" does go walkabout, or the batteries go flat, or it just stops working.. well now you can still have complete control.. the only draw back is you will have to get put of your seat to do it. A small price to pay?
on Feb 13, 2010 | Televison & Video
Remote control not working with tv
The remote control is an acess to the TV device for example only from a distance. A remote controll for functionality would require to insert batteries a power source making possible communiction with devices requiring reception transmittion of signals. The remote is handheld pointed to the direction of TV requiring signal before button pressed woudl achieve response. a common button to start the remote control experience is pressing on the power button, that displays a signal on the TV. The TV should momentarily produce a sound and lighting effect,, and displaying on the dark screen a light blue screen. The initial signal response from remote control to TV indicates devices are functioning as required. Additional buttons on the remote controll could perform functions of several available.
The remote control has master button, menu on which every additional function is deriveable. Once the menu button is pressed with remote pointed in the direction of TV, should dicplay a list of options on the blue screen already established by power button. Every additional remote control device functionality is achievable by only after the first two buttons have been powered and pressed to display option results on a screen of TV. The remote controll buttons remaining perform complementary functionalities. For example, the arrow keys on remote control make movement of the options displayed on the screen, where a comfrimation button or identified as select allows to confirm remote functions displayed on the screen. A remote control could have several functionalities only accessible once made to display in screen. The three most common buttons on a remote control are First power button that powers on the TV, menu button that displays a list of functionalities on the powered on bl;ank blue screen, and using the arrow buttons on the remote would moves an indicator arround the screen area options. The selection button makes confrimation of the option.
Dec 02, 2010 | Philips Televison & Video
The main control function button doesn not operate so I cannot access or send anything. I cant even ring anybody
most slide phone experience such problem.what you need to do is to change the cord or flex as some people may call it.Solved
Nov 02, 2009 | Nokia 3600 slide Cellular Phone
Unable to get anything to scan?
Some machines require the purchase of an optional scan board in order to work. They still put buttons like "FAX" and "SCAN" on the machine even when they don't have that function on-board.
Just a thought.
Good Luck
Apr 04, 2009 | Office Equipment & Supplies
Unable to text from my Sony Ericsson k850i
try reset all settings,go to settings and master reset,heres the codes,0000...gudlock
Feb 17, 2009 | Sony Ericsson K850i Mobile Phone
Error 30
I have the MFC 465CN - I was receiving two error codes:
Unable To Clean - Error 30
Unable to initialize
To fix, I first cleared the memory by unplugging the printer, then holding down the red stop/exit button, keep it held, power up the printer, and dont let up the button until it finishes the start up.
I then pressed the "ink" button and performed a cleaning, alignment, and quality check. After this, everything worked fine.
DO NOT try to print anything from your computer or have any pending print jobs while doing this - it appears that pending print jobs, or anything in the printers memory was interferring with the initilization and cleaning cycle it performs.
Hope this helps...
Jan 10, 2009 | Brother Multi-Function Center MFC-240C...
KVT-719 NAV button not highlighted unable to select
Well I see no help here, but emailed kenwwod and they told me:
The Garmin menu is not accessible from the main source select screen, only thru the V.Select which you have already discovered.
The reason why "NAV" is displayed as an audio source is if you were to add a GMX30 XM Radio/NavTraffic antenna, you would be able to access XM radio (subscription required). So unless you have the GXM30, you will never use that source key.
Jul 12, 2008 | Kenwood KNA-G510 GPS Receiver
Iphone touch-screen
sir whats ur model\????
May 28, 2008 | Apple iPhone Smartphone
I have a Faxphone B640. Unable to place into fax/tel mode. can access only manual, answer machine mode and DRP
1. Press Function key - wait for TEL REGISTRATION to appear
2. Use left or right arrows to select RX SETTINGS
3. Press Start/Copy
4. Use left or right arrows to select DRPD
5. Press Start/Copy
6. Use left or right arrows to select OFF
7. Press Start/Copy
8. Press Stop key
Now, when you press the Receive Mode button, it should cycle through Fax Only, Fax/Tel, Manual, and Ans Machine Modes.
May 27, 2008 | Canon Office Equipment & Supplies
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
