Question about Kyocera Mita FS 1000+N Laser Printer
The printer will not load the papers
Papers are properly loaded in the tray and yet the printer indicates that there is no paper (the ligtht indicator for this problem lighted up).
Please tell me what to do to rectify this. My printer is:
Kyocera FS1000
  • 191 Answers
Hi you may try:
1) paper input sensor dirty, clean paper input sensor usually near the tray input roler area there is a micro switch or a led light sensor with two wires.
2) paper input sensor fail or disconnect between sensor and socket on the board, you have to open the cover to check.
Posted on Dec 22, 2008
Media tray empty
Printer is not sensing the papers.Try and re-load the papers a few times
Apr 24, 2014 | Brother Office Equipment & Supplies
"Load paper"
hey not a big problem. its usually encountered by many users.
i too get this many times.
this happens when you keep papers freshly.
it needs to sense the papers kept.
now what you do is just keep more papers or try re-aligning the papers kept inside
Dec 27, 2007 | Ricoh Aficio CL2000N Laser Printer
Tray 1 load recycled letter?
Switch off & on once the printer, load papers in both trays, go to system choose file ask to print, when dialog box appears go to properties, select tray2., the shoot print, check its printing or not. If its printing problem in tray1 paper sensor,clean it.Reason why its not taking from tray 2. In menu settings its selected default tray as tray1. if no paper present in tr1 printer ask to press OK choose another tray to print, during this period indicating error.Best to do: clean all paper path sensor tray1 and tray 2 to prevent further errors... Pl revert..best of luck..
Feb 03, 2012 | HP LaserJet 4100dtn Printer
I just installed the printer i would want to know where to load the plain papers for copies when i print
It Depends on what model printer you have. There should be a symbol that indicates paper on the paper tray. That is where the blank paper should feed into the printer.
Mar 31, 2011 | Computers & Internet
I keep getting a printer jam when trying to print, I clear the jam and then it sticks again, wither in the tray, the inner door or the fuser, any ideas appreciated..
Please check the error code when paper jams. The code will indicate where the jam is. Also let me provide some tips to prevent paper jam.
Flex, fan, and straighten paper before loading it. Make sure the paper lies flat in the paper tray. Do not load too much paper. Make sure the stack height does not exceed the indicated maximum height. Make sure the guides in the paper tray or the manual feeder are properly positioned and are not pressing too tightly against the paper or envelopes and push the paper tray in firmly after loading paper. Use only recommended paper or specialty media.
Do not load wrinkled, creased, damp, bent, or curled paper. Do not mix paper sizes, weights, or types in the same stack and make sure all sizes and types are set correctly in the printer control panel menus.
For Further Assistance, please contact Lexmark Technical Support.
Mar 14, 2011 | Lexmark C534dn Color Laser Printer
On the top of the hp 2015 there is what looks like an 8 with like a sideways N next to it that keeps lighting up on my printer and inhibiting it from printing-- I don't have a manual to tell me what means.
Hello, The printer is indicating a Paper Jam.
Check the tray for proper paper loading, length and width. Check the rear exit, any paper back there? Check under the toner cartridge for loose papers.
1) Turn the printer off 2) Remove the main paper tray 3) look inside the hole in the printer from where the tray came out. You should see black rubber roller. paper dust can build up on this roller and cause the paper to slip. You can wipe this roller down with a water dampened lint free cloth, 4) Re-insert the tray, with paper in the tray. 6) Turn the power on to the printer. 7) Does the printer come ready? Print a test page.
For further information GOHERE
Feb 03, 2011 | HP LaserJet P2015 Printer
My sharp ar122en copier cannot load paper, please
Does loading mean picking papers? If so remove the paper tray and rotate the semi-circular rubbers . Clean them with a clean damp cloth and return the tray loaded with papers.
May 10, 2010 | Sharp AR-5316 Advanced Digital Imager...
How do I load envelopes to print?
Load the papers/ envelopes from left hand side edge and adjust the knobs of printer tray to accomodate the paper, if present. Usually printer will have the seperate markings on the tray to indicate where to load envelopes and labels.
I hope this is useful to you
Oct 02, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
The readout says Paper Jam, open front cover to clear, press i. There was no jam. A page exiting the printer stuck at the bottom end. I pulled it out easily and intact. Immediately, the red light went...
open the printer again.you didnot specify which kodak printer you have. take all papers out of paper tray .fan them properly to make sure that no two papers are sticking to each other. load papers again in to the printer,contact kodak @1800 421 6699 if u face problem again.
Jul 25, 2009 | Office Equipment & Supplies
Paper feeder not working properly
did you load your papers the right way? Look on your paper tray. There should be a few snaps right on the sides of your paper tray. Make sure you use those snaps to keep your papers confined in your paper tray
Mar 20, 2009 | HP Photosmart 2575 All-In-One InkJet...
Kyocera Mita FS 1000+N Laser Printer Logo
188 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Adorjani Laszlo
AAAA262430
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
