Question about Motorola Mobility i355 Cellular Phone
Ptt button not working
How to replace ptt button?
  • 31 Answers
That job will require micro soldering and a replacement switch. I recommend these guys to do the work. Cell Phone Technicians
Sorry I could not provide a DIY solution but this task is not home friendly.
Good Luck
Posted on Dec 22, 2008
PTT button on RDV 2020 is hard to push
This problem is typically caused by small component behind the PTT button being cracked or broken. The RDX series radios respond best if the user presses the PTT button in the center versus the top or bottom sections of the button. Once the button becomes hard to press it is best to get the radio repaired. Commonly if the radio remains in use the PTT issue will get worse as the internal PTT component is pressed harder, pushing it further away from the outside button and eventually loosening it from the component board.
Best regards.
Apr 18, 2014 | Motorola RDV2020 Two Way Radio2 VHF 5...
How to repair a motorola rdu2080d PTT button
If the push to talk button is damaged. You will need to disassemble the radio to get to the circuit board. The PTT is usually surface mount soldered to the board. You will need silver electronics grade solder, a flux pen, a solder sucker or solder wick, a replacement PTT, a soldering iron 25 watts or greater, screwdrivers to match the screws in the casing during disassembly, a table mounted vise to hold the circuit board during repair/ soldering, a very fine grit sand paper to remove any oxidation off the terminals of the PTT for a perfect solder connection, and probably a magnifying glass to inspect the new solder connection with the PTT to the circuit board.
Most of the soldering tools can be purchased at radio shack.
if you have no experience soldering, I recommend going to YouTube and watch the videos posted on DIY soldering to get a good understanding of the whole process from start to finish. There is a huge amount of informational videos on the subject there. I could sit here and try to explain the whole process and why but as the saying goes a picture is worth a thousand words (but a video is worth a million ).
Hope this helps. Have an excellent day.
Mar 25, 2012 | Motorola RDU2080d Two Way Radio
Is it possible to fix a non working PTT button on a RDV2020
The PTT button is one of the common failure parts. It is replaceable, but best done by an experienced repair center.
The following things can happen over time:
1) The internal PTT switch can wear out from frequent usage.
2) The user begins to press harder to get the PTT to work, bending the PTT switch further away from the external button the user is pressing.
3) Plastic diaphram, if any present, gets broken in half, and the external PTT switch doesn't work anymore.
Several companies offer flat rate repair on this style unit for around $85.
Best regards.
Aug 02, 2011 | Motorola Mobility RDV2020 RDX Series On...
How to disable ptt button
easy just get a safty pen and a drop of superglue and run it in the crack of the ptt button let it get hard then u have solveld the problen id and my samsung rugby 2 works fine i don't have to worry about every time i go to open my phone that dam ptt message
Jan 13, 2011 | Samsung Rugby SGH-a837 Cell Phone
How do you disable the PTT button on the Samsung
From what I have read, there is no setting to disable the PTT
If you don't plan on using your PTT in the future.
Look for the PTT button on the left side of the phone.
Take a pin slide it under the button and pop it off.
On the back of the button, there is a little tab.
Take a nail clipper and shorten the tab just a bit.
Snap the button back on the phone.
With the tab shortend, the PTT will not activate when pushing or hitting the button.
Aug 24, 2010 | Samsung Rugby SGH-a837 Cell Phone
How do you disable the PTT button on the Samsung Rugby? I do not
1) Pry the PTT button out with an exacto knife.
2) Cut the center post off the back with the exacto knife.
3) Reinstall.....very easy fix takes 30 seconds. PTT will never work again.
Jul 24, 2009 | Samsung Rugby SGH-a837 Cell Phone
How do you disable the PTT button on the Samsung Rugby? I do not use Push to Talk, but I keep getting the "Would you like to initialize PTT service?" question every time I accidentally hit the PTT button....
Stick your fingernail or a thin blade between the button cover toward the front side of phone. Pry it out just like would the charge port cover. Cut off the protruded part of the button cover (this is the pusher stick that activates the real button), and then press the button back in place.
Now the button is no more but looks functional, the only caveat is that if you suddenly decided you want PTT to work, your button is dead unless you can aquire a new button cover somehow.
Jun 22, 2009 | Samsung Rugby SGH-a837 Cell Phone
One way comm only
swap batteries if does not work this unit should need repair or replace, display blinking can be produced for power failure ( battery, contacts, circuits) or can be a controller issue.
Feb 07, 2008 | Motorola Talkabout T5500 (7 Channels)...
Transmission problem
A couple of things you can try:
1. Use electronic contact cleaner (spray type) on the PTT switch;
2. Use an external speaker/microphone and/or handsfree VOX headset
3. Replace the PTT switch. 4 solder points. Might not be easy but doable.
The last would require that you remove the defective PTT switch and use that as per sample when looking for replacement. Some printers uses the same type of switch. Familiarity with electronic components/circuitry, use of a DVM and a soldering iron would also be required.
Hope this be of some idea/help. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Dec 17, 2007 | Motorola Talkabout T5800 (22 Channels)...
Motorola Mobility i355 Cellular Phone Logo
230 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
