Question about Fujitsu Siemens AMILO Pro V1000 Notebook
I have a nec versa sx labtop do I need the battery to power it on or should the ac adapter do the job
  • 67 Answers
It should power on without the battery
Posted on Dec 22, 2008
Battery will not charge
The Versa SX battery is an old battery, so it is possible that it is dead and can not be recharged anymore.
Feb 13, 2014 | NEC Versa SX Notebook
Remove versa 6060 bios password
Follow these steps to clear the password:
NOTE: These steps also clear CMOS.
1. Shut down the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
2. Disconnect all external devices connected to the computer.
3. Disconnect the power from the computer by first unplugging the power cord from the AC outlet and
then unplugging the AC adapter from the computer.
4. Remove the battery
5. Remove the real-time clock (RTC) battery
6. Wait approximately 30 minutes.
7. Replace the RTC battery and reassemble the computer.
8. Connect AC power to the computer. Do not reinsert any batteries at this time.
9. Turn on the computer.
All passwords and all CMOS settings have been cleared.
Aug 13, 2012 | NEC Versa 6060 Notebook
LAPTOP NOT STARTING.
You will just unplug the dc adapter and remove the battery from back side .Now hold down the powr switch for more than 40 seconds ,and again will install the battery and the adapter.
Now You will start the laptop and,hope it will solve.
Dec 24, 2010 | NEC Versa SX Notebook
Packard bell versa e400 power only comes on when connected by the mains adapter. it has a battery in it but will not power up from it.please help
Hi there.
Basically the batteries dead and needs to be replaced!!
This is a common problem right across the board with all laptops, in some cases its the powerboard on the motherboard itself which won't charge any battery new or old.
To troubleshoot it you will need another battery to test with it.
Good luck
Jun 12, 2009 | NEC Versa SX Notebook
Nec versa 4230: What is 4 pin adapter pinout ?
It is 13.5 v dc.
When viewing the end of the cable that connects to computer with the centered notch up, upper left and lower right are positive.
Upper right is negative (per the labeling on back of ac adapter),
Mar 01, 2009 | NEC Versa LX Notebook
No power
The laptop should power up with the AC Adapter plugged in, if it works, and you want to be mobile, buy the battery pack for it. Battery's sell for around $75 in some places on-line.
Have a nice day!
Dec 22, 2008 | Fujitsu Siemens AMILO Pro V1000 Notebook
Nec versa e600
If the system will not run from the AC adapter, then it issue is normally limited to one of 2 possible failures.
1. The AC Adapter has failed.
2. The connection on the motherboard has failed.
If under warranty, contact NEC to get the adapter replaced or system repaired.
If the warranty has expired, then your best bet is to first try a new AC Adapter and see if the adapter has failed.
If that doesn't work or if the power connection on the motherboard is obviously broken/loose then a replacement motherboard is the most likely answer.
here is a link to a replacement adapter:
http://www.batterypowerplus.com/store.php?f=view&item=1990&brand=NEC&model=Versa+E600
May 17, 2008 | Computers & Internet
How much is a nec versa lx I had one and theyre good want another
Check ebay should be cheap these days probably $100 for a good working one.
Dec 19, 2007 | NEC Versa LX Notebook
Stuck in suspend/sleep/standby... I think...
Take the battery out for a minute and put it back in. Don't plug the AC adapter in. Now turn it on. If it comes on go to 'settings' 'control panel' 'power settings' set everything to 'never' and make sure nothing is checked under the differant tabs. Ray
Jun 21, 2007 | NEC Versa SX Notebook
Fujitsu Siemens AMILO Pro V1000 Notebook Logo
182 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
