Question about Freezers
Freezer runs continually
I have an upright freezer and everytime I open the door it is running. I cant ever remember when I have not seen it running (blowing cold air into unit) when we open it. I am sure this will shorten the life of the freezer as well as cause higher electric bills. I bought the unit at a yardsale 4 years ago. It is an upright Frigidaire Freezer model # FFU16F6AWZ. Manufactured in 07-93.
I remember my dad having an ancient chest type that sat by the back door of the kitchen. Whenever he would go to the garage, he would gently thump it with his foot near the light and it would go off. Apparently he had the same problem as I did many years later now. Thanks for any help. Joe
  • 1 more comment
  • Joe Yount Dec 22, 2008
    Since this is the thermostat; is this something I can do myself? I am pretty handy and have repaired washers, dryers etc.... Any ideas on finding a good exploded view of this product? Thanks again, Joe.
    Dont see a thermostat. Is this the same as the defrost timer? Closest thing that I see that looks like a thermostat on the drawings.
  • Joe Yount May 24, 2009
    Still dont know where the thermostat is located. Please help. Thanks, Joe.
  • 750 Answers
Hello jyount130960
Welcome
This is a bad thermostat that if not repaired will cause the compressor to burn out prematurely.
You should service it right away!
Thank you,
for using Fix ya.
Please remember to leave a solved rating before you sign out!
Posted on Dec 22, 2008
  • Neil Golan
    Neil Golan Dec 22, 2008
    All the diagrams are at this sight on the left side an can be made full page. you can order parts here too!
    http://www.pcappliancerepair.com/model-d...
    Please remember to leave a solve rating here before you sign off!
    Thank You Huum.
  • Neil Golan
    No that's not it. let me find it for you!
Frigidaire upright freezer door will not seal
Hi Chris, this is AP! Thank you for your post.
I understand you are having trouble with the door sealing on your upright freezer. Many times this can be caused by the freezer not being leveled. If the freezer is not leveled during installation, the door may be misaligned and not close or seal properly, causing cooling, frost, or moisture problems. To level your upright freezer use a carpenter's level to level the freezer from front-to-back. Adjust the plastic leveling feet in front, 1/2 bubble higher, so that the door closes easily when left halfway open. I hope this information has been helpful.
Mar 02, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
High pitch whistle after closing door
It is possible that the door gasket is defective
Jul 01, 2013 | Frigidaire FFU17M7HW 17 cu. ft. Manual...
MAGIC CHEF FREEZER THE DOOR IS NOT OPENING FOR 8.8 CU FT UPRIGHT FREEZER MCUF88W -- BRAND NEW JUST BOUGHT?? HELP
If You run Your finger in between the rubber seal that is resting on the freezer and the frame of the door , the rubber seal will break lose. When you open the door the seal is attache to the door.
Just had the same problem after unboxing.
Simple, just be sure to do the entire door.
Sep 27, 2010 | Magic Chef 11.8 cu. ft. / 334 liter...
Yesterday the door on my 14 cubic ft upright freezer did not stay shut tight (it was ajar about 1 inch for about 6 hours). When I became aware I closed and locked the door to be sure it stayed shut, but...
it may take upto24 hours to settle to -18C,remember it has to cool right through the food in the freezer,as well as the walls.also if the food went soft, it is spoilt......cook meat asap then refreeze.
Aug 12, 2010 | Kenmore Freezers
Door will no vacuum seal closed
Are you sure compressor is running? If it is make sure the evap fan is running. You should be able to hear the fan when you open the door. If ypou do not hear a fan running then fan has gone bad. 4390914 and approx cost is rediculous in my mind but it is approx. 150.00 to 160.00 . Crazy for a fan motor.
Jan 28, 2010 | Whirlpool 17 cu. ft. / 481 liter Upright...
My Kenmore freezer is continuously running. It
clean all of the door seals and all of the contact point with freezer
Jul 17, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore upright freezer
reason is that the evaporator is blocked with ice and hence no air circulation.
either
switch off for 24 hours with doors open
or
remove back panel inside freezer and melt ice off with a hairdryer
Oct 16, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Running continuously
Hello bxrjer,
Welcome,
You said, you have a FFU20FC6AW2 freezer that I have noticed is running continuously. Explains my $400 electric bill.
How old is the freezer?
The thermostat may be faulty.
But check out this list first.
If the black tubes running back and forth that carry the freon is under the freezer and behind the plastic grill down near the floor you may want to remove the grill cover and gently run a refrigerator brush across the coils. Ive seen them never cleaned and full of lint and dust 2 inches thick.
This is not good for the freezer or any refrigerator too!
They need to be clean so air can run across them or they over heat and get hot.
Room or outside weather is hot. It is normal for the freezer to work harder under these
conditions.
Reasons why Freezer may run too much or too long.
1.Freezer had recently been disconnected for a period of time. Freezer requires 4 hours to cool
down completely.
2.Large amounts of warm or hot food have been stored recently. Warm food will cause the
freezer to run more until the desired temperature is reached.
3.Door is kept open too long or too frequently. Warm air enters the freezer every time the door
is opened. Open the door less often.
4.Freezer door may be slightly open. (Freezer is not level. It rocks on the floor when it is moved slightly. This condition can force the cabinet out of square and misaligned the door.Freezer needs to be leveled if this occurs.
Floor is uneven or weak. Freezer rocks on the floor when it is moved slightly. Level the floor by using metal or wood shims under the freezer or brace floor supporting the freezer.
5.Temperature control is set too cold. Turn the control knob to a warmer setting. Allow several
hours for the temperature to stabilize.
6.Freezer gasket is dirty, worn, cracked, or poorly fitted. Clean or change gasket. Leaks in the
door seal will cause freezer to run longer in order to maintain desired temperature.
Let me know what you find
Huuum
Please remember to leave a rating before you leave.
Aug 18, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Maytag Freezer
sounds like you need a new door gasket
Aug 15, 2007 | Magic Chef 11.8 cu. ft. / 334 liter...
Freezers Logo
175 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
