Question about Fujitsu Siemens AMILO Pro V1000 Notebook
No power I have a nec versa labtop which doesn't power up, Ithink the battery might be dead, should the labtop still power up with the ac power cord or do I need the battery to power it up?
    Scholar:
  • 130 Answers
The laptop should power up with the AC Adapter plugged in, if it works, and you want to be mobile, buy the battery pack for it. Battery's sell for around $75 in some places on-line.
Have a nice day!
Posted on Dec 22, 2008
Laptop will not start on battery
Is the battery charging? What does the battery icon say when you hold the cursor on it? How old is the battery? Is it original or a replacement?
Mar 08, 2013 | NEC Versa VX Notebook
Remove versa 6060 bios password
Follow these steps to clear the password:
NOTE: These steps also clear CMOS.
1. Shut down the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
2. Disconnect all external devices connected to the computer.
3. Disconnect the power from the computer by first unplugging the power cord from the AC outlet and
then unplugging the AC adapter from the computer.
4. Remove the battery
5. Remove the real-time clock (RTC) battery
6. Wait approximately 30 minutes.
7. Replace the RTC battery and reassemble the computer.
8. Connect AC power to the computer. Do not reinsert any batteries at this time.
9. Turn on the computer.
All passwords and all CMOS settings have been cleared.
Aug 13, 2012 | NEC Versa 6060 Notebook
My NEC Versa 3200 laptop screen now keeps on turning bright and then dim for few seconds and then back to bright. It does this few minutes after stat up. Any advice on this, thanks.
Generally a laptop will do that when it changes from AC power to battery power and visa versa. The tendancy is that either the power jack is going bad or the power cord has a broken wire near the head. Another reason laptops do that is if the AC adapter is not rated for the laptop it's being used for. Like, if you were to use a Netbook charger to charge a full size laptop, you will get the same problem. Check the charging cord for and abrasions or cuts and move the wire close to the head around in circles and see if it has a "sweet spot". Take the battery out and try starting the laptop on AC power only. If the problem is in the cord it should shut the laptop down or keep it from coming on. Either way, it's most likely one of those three things. Hope this helps
Sep 02, 2011 | Computers & Internet
My laptop nec versa stopped to work suddenly. I
A questions are to be asked here. Does the laptop work when connected to AC power supply? If yes does the battery charge when connected to AC? If yes does this turning off happen when running on battery too? Please answer these questions so that I can help you with the diagnosis.
Regards,
Sai.
Nov 21, 2009 | NEC Versa VX Notebook
Packard bell versa e400 power only comes on when connected by the mains adapter. it has a battery in it but will not power up from it.please help
Hi there.
Basically the batteries dead and needs to be replaced!!
This is a common problem right across the board with all laptops, in some cases its the powerboard on the motherboard itself which won't charge any battery new or old.
To troubleshoot it you will need another battery to test with it.
Good luck
Jun 12, 2009 | NEC Versa SX Notebook
Laptop does not boot up when you press the power on button. I have not used this computer for a number of years and I'm sure that the battery is dead. Do you need the battery to run on AC? The cmos cl
Here is what i can say:
no you do not need a battery to run ac
you do not need a cmos battery to bot
Does the light stay on?
if so find a way to check if the screenis working.the connectors may be disconnected.
try useing an external monitor
Apr 15, 2009 | Computers & Internet
Nec versa 4230: What is 4 pin adapter pinout ?
It is 13.5 v dc.
When viewing the end of the cable that connects to computer with the centered notch up, upper left and lower right are positive.
Upper right is negative (per the labeling on back of ac adapter),
Mar 01, 2009 | NEC Versa LX Notebook
Connection
Possibly a Failing Battery...
Remove Your Laptops Battery, And Power On With AC Power alone... Then Try Wireless..
If It Works Again Normally, It's Your Battery Going Dead...
Feb 07, 2009 | NEC Versa VX Notebook
NEC Versa M320 cmos problem!
Click on this link for the parts breakdown of this laptop
Oct 21, 2007 | Computers & Internet
Fujitsu Siemens AMILO Pro V1000 Notebook Logo
244 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
