Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Kenmore elite trio model 596.73509201 freezer not cold
Everything thawed out in freezer, both freezer and fridge blow cool air.
I vacuumed condensor coils best I could.
one thing I noticed was that compressor was hot to the touch and heard clicking from compressor after un plugging for about 15 minutes.
the evaporator does not seem to be covered with ice and I can hear and feel air blowing from both fridge and freezer.
somewhere I read a post about an overheat capacitor on compressor being bad could that be the case?
Any help would be appreciated Thanks!
  • Anonymous Dec 26, 2008
    Everything defrosted- all food lost
SOURCE: Kenmore Model # 596.735032.. Fridge is cool, Freezer is not freezing
After pulling the fridge away from the wall and removing the lower right hand panel I noticed that the compressor (big round black ball with copper tubing) was not turning on. I also noticed that there was a ticking or popping sound comming from it every couple of minutes or so. After doing some research online in numerouse forums I decided to try and replace the overheat relay that is attached to the compressor. It only took maybie five minutes at most to change it and the compressor is now working with nice cold air comming into the fridge and freezer. Hope this helps someone else with the same problem.
Posted on May 10, 2008
22yooper
  • 828 Answers
SOURCE: KENMORE TRIO 2004 59675523400 REEFER/FREEZER NOT COOLING
It is the compressor that has failed. The hum is it trying to start and the following click is the overload protector opening. What is the temperature where the refrigerator is located? Allow the compressor to cool down before trying to restart it. If it still does not restart after it has cooled off it is done.
Posted on Jun 03, 2008
kevin000
  • 1847 Answers
it should not be the compressor as the bottom is only not cooling.
Posted on Jun 23, 2008
SOURCE: Kenmore Elite Trio 596 73503200
Did you ever get the problem fixed with the compressor noise
Posted on Jul 09, 2008
SOURCE: Newer kenmore elite trio refridgerator not cooling
The repair person came and in my case it was a start capacitator connected to the compressor. When he replaced the start capacitator the compressor came on immediately and started working. The charge $ 240 (Flat Rate) for the fix. The repair person told me its a universal start capacitator which I found online for $29. Worth trying to fix yourself before paying $240 if your a handy person.
Posted on Feb 10, 2009
My ge refrigerator model pss26sgpa is not cooling in fridge or freezer
make sure the condensor fans are clean they are prob. full of dust. bottom rear of unit.
Apr 18, 2012 | GE PSS25NGM Side by Side Refrigerator
I have a kenmore elite refrigerator about 10 years old, side by side model 50599003, still blows air but both frig and freezer are blowing warm are. condensor?
Check for clogged condensor coils underneath rear of fridge.
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 16, 2011 | Refrigerators
We have a Kenmore Elite Trio (bottom freezer- Model#596 73502201-bought 2004) and both the fridge and freezer are blowing cool air but not cold. Food in freezer has defrosted and the fridge temp. is much...
Check to see if the evaporator behind the back metal cover on the freezer side is all frosted up, if it is, then it will probably be the defrost heater which is bad and letting it clog with frost causing low or no airflow. The heater is not expensive and can be ordered online on ebay.
If you need further help, reach me via phone at https://www.6ya.com/expert/gary_9c859f4aa7e5ab10
Mar 02, 2018 | Kenmore 73502 / 73504 / 73509 Bottom...
I am getting an ER FF message on my refigerator in the section where it normally gives you the fridge and freezer temp.
f =heat exchang you have to check the condensor fan and evaporator fan , clean the condensor coil . if the frost build up to block air way. need to check heat element and defrost thermostat. good lock
Jan 10, 2011 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
Kenmore Elite Trio Refrigerator not cooling
No, it is not a failed condenser. You need to see if the compressor is running though. When it runs you shaould have a fan in the freezer running, a fan underneath the fridge running, and the compressor should be running. I would be willing to bet that either the compressor is bad, or the start relay on the compressor.
Sep 08, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Oct 10, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore Trio 596.75509400
My problem is identical to jcalhoun on Sep 21, 2008..I have a Kenmore Trio 596.75502400. Freezer is ok..Lights are on. Any help would be appreciated.
Sep 21, 2008 | Refrigerators
Trio: humming and temp in freezer rising
It sounds like the condensor fan motor is seizing up. This is the fan that cools the compressor down. Does the outside of the fridge feel excessively hot to touch? Can you feel air being circulated under the fridge or behind the fridge? It could also be a faulty defrost timer. Try to identify where the buzzing is coming from and if it is the condensor fan you can put a normal standing fan behind the fridge, blowing onto the compressor untill the repairman can get to you.
Oct 29, 2007 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
188 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
