Question about LG 24 in. LDS 5811 Built-in Dishwasher
Doesn't clean dishes completely, especially the top rack. also it doesn't completely empty out the detergent dispenser.
  • 2 more comments
  • cross5150 Feb 17, 2009
    I have the same problem, dishes are still dirty and the detergent door is stained with soap and detergent is running down the inside of the door.
  • Anthony Patrick Feb 22, 2009
    I had the same problem (and a few others). Turns out that "EVERY" gasket/seal in the dishwasher failed. The tech had to come in and replace every one of them. They had all become soft and when touched would leave a black smear on your finger. This dishwasher is a real piece of junk. If you are thinking about buying an LG - don't!
    I had the same problem. The drain hose loops around the back of the dishwasher (it is inside of the cabinet - behind the back panel) to prevent water siphoning. The hose is turned at a very sharp angle and the material is so flimsy that it cracks after about a year due to vibration. In my case, the water leaked through the floor and damaged the ceiling downstairs. The fix is to apply silicon based glue and wrap the "stressed" part of the drain hose with heavy duty tape (the type where the tape anneals to itself after curing). This dishwasher is a real piece of junk. This is only one of many problems I have had with it.
  • louisa3 Mar 03, 2009
    Soap dish doesn't empty soap out but even when I manually dispense it, the dishes do not get clean. I won't buy LG appliances again. Their dryer fell apart after 3 years also.
  • 423 Answers
To the people here with the poor cleaning problems:
Try these steps:
Buy a small box of Cascade or Electrosol diswashing powder. Use only it for 30 days and report back. Do not use gel, tablets or ultra low end detergent. I have proven that ultra cheap powder WILL cause problems.
Also, fill a bowl or large cup with white vinigar, place it in the bottom shelf of of the empty dishwasher. Do not add any detergant. Run a normal or quick cycle.
If you still have poor cleaning, it is time to call for service or remove the filter beneath the lower rack and search for debris that will need to be removed.
Please report back with your results and the make/model of the dishwasher. Good Luck!
Posted on Mar 29, 2009
I have a whirlpool dishwasher DU920PFGZ0 and the detergent dispenser door doesn't open all the way to release the soap
Is there a tall dish/cookie sheet/pan blocking the dispenser door from opening fully? Check inside the rack of the dishwasher to see where the dispenser door lines up.
Oct 11, 2011 | Whirlpool Dishwashers
Hi I have a Blanco dishwasher BFDw8 which is having poor wash results in the top tray I have tried all the trouble shooting things in manual. Investigated further by opening door during wash cycle several...
  1. Check the water temperature. Should be 125 to 140 F.
  2. Check pump re-circulation., Listen, see if it sounds like it is spraying the water around with enough pressure.
  3. Check water level when the fill cycle has completed. Should be just under the heating element. If not, possibly need to replace the water inlet valve.
  4. Check the spray arm and pump cover for splits or leaks.
  5. Check to make sure dishwasher is draining after each cycle. There should only be a little water in the bottom of the tub.
  6. Make sure the dishes are loaded properly, or dishwasher is not overloaded.
  7. Possibly try a different detergent. Some liquid-gels will bubble and a pump cannot pump bubbles.
Scrape away large pieces of food, bones, pits, toothpicks, etc. Burned on food should be loosened before loading. Empty liquids from glasses and cups. Foods such as mustard, mayonnaise, vinegar, lemon juice and tomato products may cause discoloration of stainless steel and plastics if allowed to sit for a long period of time. Unless the dishwasher is to be operated at once, it is best to rinse off these food soils. Load racks so that large items do not prevent the detergent dispenser from opening. If the dishwasher drains into a food disposer, be sure disposer is completely empty before starting the dishwasher.
just click on the above questions for more help the answer will come to the screen
  1. A common leaking trouble maker
  2. Another common leaking trouble maker - especially for leaking out of the door area
  3. Can I use a rubber or plastic hose for the hot water on my built in dishwasher ??
  4. Some common pump assembly pictures...
  5. Dishwasher Basics
  7. Dishwasher soap notice
  8. Draining and washing help
  9. Help for storing an appliance
  10. How to remove the access panels
  11. I just installed my food waste disposal, now my dishwasher will not drain, what could be wrong??
  12. I moved and lost the tap adaptor for my portable d/w, help!!
  13. Important disclaimer
  14. I would like to try to install my own dishwasher
  15. Loading your dishwasher help
  16. Motor and pump assembly screw and impellor help
  17. My dishes are not as clean as they used to be, what might be wrong?
  18. My dishwasher racks have rusted.
  19. My dishwasher will not fill with water
  20. My dishwasher will not start
  21. My soap dispenser will not open
  22. Sand like deposits inside the glasses and d/w
  23. Some common soap door dispensers breakdowns
  25. Stainless Steel Cleaning
  26. Strange grinding noises and not washing properly
  27. The dishwasher doors falls down
  28. White filming on the glasses
Oct 05, 2008 | Dishwashers
The soap does dot dissolve
assuming you are using the correct dishwasher detergent type and quantity recommended for the dishwasher, the likely cause for detergent not dissolving is that the water is not circulating well enough through the wash arm. Check the wash arms are clean. Do dishes come out clean? Run the dishwasher with a cup correct side up on the top rack. If it is empty at end of wash then there is no water in the top arm.
Is the detergent dispenser door open during wash cycle?
Also lack of adequate wash water template can cause detergent to remain undesolved. Hope this helps.
Feb 15, 2011 | Asko D1796FI Built-in Dishwasher
It began with the dishes on the upper rack not being cleaned. Not the bottom rack is getting less cleaning done and some of the liquid detergent is left in the detergent compartment. I tried doing a...
Check your spray arms for pluggage at the slots and the nozzles. If you can remove them, do so and backwash them over the sink. Unplug the slots and nozzles with a toothpick or fine wire.
This should also help with dispensing the detergent, but reduce the amount to the least that you can use while still getting the dishes clean. We have cut our detergent usage to about 25%. Also, try to not place tall items where they can block the water spray to the dispensing compartment.
Use a good drying agent, and crack the door open when the washer reaches the end of the cycle, as this will help the dishes to continue to dry, and further release the steam, resulting in cleaner dishes.
The reduction of the detergent, along with the cleaning of the spray arms will help a lot. I should note here though that I've had to re-clean the arms after what I thought was a most thorough cleaning. Once they are really clean, they'll work better for a long time (usually).
Best regards, --W/D--
Feb 04, 2011 | Whirlpool Dishwashers
Soap residue on glasses, dishes & flatware...what can I do..I use Cascade & JetDry
Instructions Things You'll Need:
  • Vinegar or lemon juice
  • Gel dishwasher detergent
  1. dishwashers have a rinse aid dispenser. If your dishwasher has this dispenser, fill it up periodically and it will release the appropriate amount of rinse aid automatically at the right time during the wash cycle. This will help your dishes rinse more cleanly.
  2. Rinse aid in solid form
    Some older dishwashers or basic models do not have an automatic rinse aid dispenser. In this case, you can buy rinse aid in solid form that attaches to your dishwasher rack. Solid rinse aid can be hard to find in stores because it is not commonly used, but it can be purchased online.
  3. Vinegar or lemon juice
    Appliance repairmen will tell you that one of the common problems they see with dishwashers is the buildup of excess detergent. If there is too much detergent in your dishwasher, your dishes will not rinse cleanly, no matter how good the dishwasher is or how much rinse aid you use. To clean the excess detergent that has built up inside your dishwasher, put 3 tablespoons of vinegar or lemon juice (concentrate is fine) in the empty dishwasher and run the dishwasher through a complete cycle with no dishes. Do this twice, for two complete cycles of the empty dishwasher with only vinegar or lemon juice added. The acid in the vinegar or lemon juice will break up the detergent that has built up in your dishwasher's interior.
    After you have cleaned the detergent buildup from the inside of your dishwasher, follow the steps below to keep the buildup from happening again and to help your dishes rinse cleanly and prevent residue from accumulating on the dishes.
  4. Gel dishwasher detergent
    Switch to a liquid or gel dishwasher detergent. Any brand will do.
  5. Fill one compartment half full Dishwashers will effectively clean dishes with much less detergent than manufacturers often recommend. The bleach in the detergent, combined with the extremely hot water used in the dishwasher wash cycle, will clean and sanitize your dishes completely, even in small amounts, and using less detergent helps prevent buildup and residue from accumulating on your clean dishes.
    Fill only one detergent compartment(the one that snaps closed) half full with gel detergent. Snap the opening closed and run your dishwasher as you normally would. Your dishes will come out sparkling clean with no buildup or residue, plus you'll save money by using less detergent!
Feb 02, 2011 | Dishwashers
My Asko D1976 dishwasher is not cleaning dishes properly. There is a lot of clumped detergent left in the dispenser after wash cycles are complete, and many of the dishes have dried-on food left on them. ...
First of all, don't pre-rinse the dishes. Check the water temperature, it should be between 120 and 140 degrees. Be sure you are not partially blocking the dispenser door so that it isn't opening.
Sep 18, 2010 | Asko D1976 Built-in Dishwasher
Asko 1996 appears "dead".....no lights flashing, won't respond to repeatedly pushing on/off button. Some water left in the bottom...siphoned it out, cleaned filters, no blockage there. Almost like it's...
Don't know if this will help, but my dishwasher has a "propeller" device above the top and bottom racks that spins while dispensing the water. If the dishes on either rack are stacked too high (i.e. if even one plate comes in contact with that propeller, keeping it from spinning properly) the dishwasher will go through its full cycle but will not use the soap (soap door will still be closed and soap packet still intact) and will not get the dishes clean.
However, it sounds like you either have a bit of a drain issue as well--or perhaps your dishwasher acts the same way as mine (if that's the case) but ceases to drain as well if blocked.
Jun 26, 2010 | Asko D1996SS Built-in Dishwasher
Dishes in top rack not getting clean
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
May 28, 2010 | Frigidaire 24 in. FDB1050RE Built-in...
The top rack is not longer getting clean
Using liquid detergent is the worst detergent to use. One possible solution to your problem could be as follows...pour 2 cups of vinegar in to the tub and run it on the hottest longest cycle with no dishes in it. May need to do this several times (3 to 4). This will clean the residue out and what ever "gunk" may be in the internal parts. Use Only powder detergent. No gel, no liquid and no tabs. These 2 cause a build-up over a period of time of use and reduce the performance of your machine. This should take care of your problem.
Apr 10, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Kitchenaid, new dishwasher, stopped cleaning top rack dishes
The problem most people encounter with dishwashers is a simple inability to get the dishes clean. There might be stuck-on food or residue from the detergent. A water pressure problem may be the culprit. You may need to replace the water intake valve. Another common problem is mineral build-up. If your house has hard water, the mineral build-up can clog the water jets. Clear each jet with a wire or pin, and run an empty load with some vinegar in the detergent dispenser about once a month.
Sometimes, the dishwasher has problems draining properly. There could be a clog in the drain hose, or a problem with the pump. It's also possible that the dishwater is getting too sudsy, and sensors in the washer aren't detecting the soap foam as water. This causes it to shut down the drain cycle too early. Just use less detergent.
Feb 02, 2009 | KitchenAid 24 in. KUDS25SH Built-in...
LG 24 in. LDS 5811 Built-in Dishwasher Logo
200 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
