Question about SanDisk Sansa Clip MP3 Player
My sandisk is not working
My computer will not recogniz the player
  • tinkerbell_b Dec 24, 2008
    when i hook the clip up to the usb drive it notices that its in but my computer isnt letting me know its there
  • 758 Answers
What i would recommend you to do is to uninstall the device andreinstall it back...to uninstall it...assuming that you are running windows xp...click on start, right click on my computer and go to properties..you should have your system properties open then click under hardware then device manager...lookfor the sansa device..it usually located under portable device..if itsnot showing there i would recommend you to look for under disk drives and see if its there..right click on the device and click on uninstall...after you unintall it unplug your device from the computer....Then follow this link below to downloadthe portingkit...http://www.microsoft.com/downloads/details.aspx?FamilyId=A2E73160-E862-4F19-BB26-C0CAFE798955&displaylang=en.Then check the mode of yuor device to make sure it sunder MTP notmsc...To check the mode go under menu, settings and choose usb mode...After you check the mode open up your windows mediaplayer click on tools, options and click under privacy...clear thehistory and caches...after you finish you can plug the device on theback of the computer not the front then windows should recongnize it and it should work properly..if that doesnt solve the problems upgrade your windows media playerto 11 even though you have done that already..and try to reconnect yourdevice..make sure you have it on the back of your computer...
Should you have any questions..let me know..
P.S.Please rate accordingly...
Thank You
Computerrep
Posted on Dec 22, 2008
Mi pc no reconce mi mp4 sansa SDMX8N-4096K-EA70-....... AYUDENM ... se los agradecere
reset the player from the button in that hole it has..and after that run again the driver in the computer but not before removing the old one which is probably corrupted..
If you do not have the driver anymore. get to the support site and download it by the operation system and model ...and reinstall it into computer ..
If you never installed a driver just use the disk that came with the player and install all the drivers on it ..or just the one for your model if it is recognizable by name ..
after that you should see it in My computer folder by name ..or as a removable disk or memory device ...open the folder and add new songs in mp3 format in the folder with the trial ones from factory ..or if it has multiple functions look for the audio or music folder..If id has only one folder just copy the mp3 files in it ..
Jul 13, 2011 | SanDisk SANSA SDMX8N-4096K-EA70 MP3...
Format sd memory card 2g for blackberry usage
Dear,
Just format the card using PC. It is very simple. Right click on drive(card) and select format. It is ready to use.
Regards,
Rakesh Kumar
Apr 01, 2009 | SanDisk 2GB microSD Memory Card
Help please
Try resetting everything back to factory setting or download its drivers from the official website and install them.
That should fix your problem!!!!
Thank You!!!!!!!!!!!!!!
Jul 03, 2008 | SanDisk Sansa m240 MP3 Player
Only get 20 seconds of play
I downloaded the new the updated firmware which corrected the problem.
Jun 28, 2008 | SanDisk Sansa View 8GB MP3 Player - Black
My mp3 player
there isent a way to fix it if it says that on your computer than you will unfortunalty need to purchase a new one.
Feb 29, 2008 | RCA OPAL M4001 MP3 Player
Sandisk cruzer thumb drive
This just means it is trying to recognize the device. All you need to do is allow it to recogniz the device and find the proper drivers. You can put files in here by going into my computer and double clicking the mass storage device. Files can be draged or copied in here, then taken anywhere you need to go.
Feb 24, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sansa clip mp3 player
To help you with that, I need to know what operating system your using (XP, Vista, ect...) and what other devices you have plugged into the computer. There are a few things you can try. When you plug it in, does it say it's connected? Does the "Found new hardware" wizard come up? Let me know, I'll see what I can do to help
Dec 31, 2007 | SanDisk Sansa Clip MP3 Player
Cruzer Scandisk 2.0 titanium
Hi, Not unless you are using Windows98, your PC should automatically recognize the SanDisk Cruzer Titanium as a "Removable Storage/Device". Driver is not required for Windows ME, W2k or XP. If for some reason the SanDisk Cruzer Titanium (non-U3 devices) is not recognizable, then perhaps it is not a problem with the PC but with the SanDisk. Pls try all other USB ports of your PC (front and back). The SanDisk website provides utilities/software for this kind of eventuality. They are Sansa Firmware Updater and Sansa Connect Recovery Tool. Both are available at http://www.sandisk.com/Retail/DriverDownloads.aspx. Pls be forwarned that some utilities can and will reset your SanDisk to default and any or all data can and may be deleted. Hope this be of some help/idea. Pls post back how things are or should you need additional information. Good luck and kind regards.
Sep 30, 2007 | SanDisk 1GB Cruzer Titanium USB Flash...
Won't hold pics or vids
You have to use the Sansa Media Converter to "convert" the files to a recognizable format. Standard image formats do not work. The Sansa Media Converter is on the installation CD. Best of Luck.
Sep 05, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa Clip MP3 Player Logo
27 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
