Question about Smeg Kitchen Ranges
My Smeg oven heats up to extremely high temperature even when the gauge is on 50 degrees celcius so I've stopped using it because everything is getting burnt. To identify the model just before the word 'Smeg' it has 2 sets of 3 circles. It has the standard oven temperature system i.e. 50,100,140,180,200,250 and is fan bake all the time so I think this system is faulty as well. Please help?
Hello, my problem will soon be resolved by employing a professional smeg electrician who said I needed a new thermostat. Thank you for reading but I no longer need 'fixya' assistance this time around.
Posted on Dec 22, 2008
HOW TO REPAIR A THERMOSTAT
Hi, it won't cause your oven overheating by hanging loose. I think your thermostat is faulty. I don't suggest opening it to try and repair it yourself. If your tamper with the metal plates inside, your temperature will not be accurate as where you set it for 120 degrees Celcius or 248 fahrenheit it will meybe give you a true temperature of 220 degrees celcius or 428 fahrenheit which would be chaos. Rather rplace the complete thermostat unit.
May 03, 2014 | Bosch Ovens
Gas Pizza Oven - Heat issues
Many of the Pizza ovens require ceramic plates that line the bottom surface of each oven. These ceramic plates absorb the heat and retain the temperature. I never used our ovens with a bare lower surface, always applied the plates for even heat and distribution.
Mar 05, 2014 | Ovens
SMEG OVEN BRAND NEW WON'T HEAT
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Sep 08, 2012 | Smeg Ovens
Oven Pre-heats too high
Your oven sensor has gone bad and telling the control board/thermostat to keep heating. Find the model number on the range and go to a parts distributor like repairclinic.com or apdepot.com and order you sensor. This is an easy repair.
Apr 23, 2012 | Dacor ER36D Dual Fuel Range
2002 chevy malibu heats up when running at low speeds
CHECK THE THERMOSTAT. THERMOSTAT IS THE ONE THAT SENSE THE ENGINE TEMPERATURE AND TURNS ON COOLING FAN WHEN THE ENGINE IS HOT.
Jan 19, 2012 | 2002 Chevrolet Malibu
The oven temperature isn't correct. Ovenw Won't heat up.
has the oven got a fan on it. if so then maybe fan is faulty.
if convection oven then maybe one of elements is faulty
or the thermostat is a problem
regards
richard saupe
Appliance repairman colchester
appliance repairman
Mar 14, 2010 | GE Profile JT915 Electric Single Oven
Smeg fautly themostat - too hot, burns everything
Sounds like thermostat faulty, make sure sensor is not detached or broken in oven, if still under 1 year old, then I suggest you contact service agent.
Pleas rate my solution.
Thanks.
Oct 10, 2009 | Bosch HBN 452 / HBN 456 Electric Double...
Ovens won't heat up beyond 250 degrees.
if you cant program it for more than the 270 you may have changed it from farienhiet ( bad spelling) to celcius. pushing and holding broil may switch it back.
May 02, 2009 | KitchenAid Architect ® II KEBS208S...
My Ac is always going off within a short time
hi charles,
i don't think the catalyst has something to do with the ac. you mentioned you are in africa and i am assuming it is positive 50 degrees celcius and not negative 50 degrees celcius as stated in your post. i could see a dash before the number 50.
anyway, there is a pressure switch that would de-activate your compressor once the high pressure reaches an abnormal level. and this level could easily be reached at 50 degrees celcius ambient temperature. so it seems there is nothing you can do about it.
i could suggest that you put an adittional fan if you still don't have, to cool the condenser further.
or just try to cool the condenser, while parked, turn the ac on, and doze the condenser with water and observe if the ac would still cut off. if it does not, then the problem is your ambient temperature.
tnx 4 using fixya,
drcool
Sep 30, 2008 | 1998 Audi A4
Kitchen Ranges Logo
431 people viewed this question
Top Smeg Kitchen Ranges Experts
ashburton
Joseph Mueller
Joseph Mueller
Your Consultant
Are you a Smeg Kitchen Range Expert? Answer questions, earn points and help others
