Question about KitchenAid KMTT400-SS 4-Slice Toaster
How do you get melted sugar off inside of toaster?
We have been toasting yummy cinnamon bread, and the sugar residue has melted onto the bars that the bread sits on. How do I get this off? I've tried gently scraping it with a knife, but there is still some bread/sugar goop stuck on the metal part that raises the bread (lifter?). How do I get it off?
    Brigadier General:
  • 8,619 Answers
Use a damp cloth tied on a brush/stick to wipe the sugar residue off the bars. If it still does not help, then soak the cloth in lemon juice and scrub on the bars as it would also wipe out the sugar and would not affect the working of the toaster.
Posted on Dec 27, 2008
Recipe for cinnamon buns in a Charlescraft bread maker
  1. Put yeast in bread machine (I use the top rated one at: first on bottom, then flour, sugar and salt.
  2. Then melt butter in microwave. Add beaten egg, milk and water.
  3. Pour onto dry ingredients in bread machine on the dough setting.
  4. When dough is done, put it onto a lightly floured surface.
  5. Knead in enough flour to make it easy to handle.
  6. If it is too elastic, cover and leave 10 minutes.
  7. Use floured rolling pin to roll out dough on floured surface.
  8. Roll out into rectangular shape to approx 1/4-inch thick.
  9. Use filling and spread over entire surface of dough with spoon.
  10. Roll up dough.
  11. Cut into circle with a sharp knife about 1-inch thick; place these in a greased 9x13-inch pan.
  12. Cover with a tea towel and leave in a warm place for approx 30 minutes, until double in size.
  13. Bake in a 350° oven for about 25 minutes, light brown on top.
  14. When done, make glaze and swirl over buns.
Oct 17, 2015 | Kitchen Appliances - Others
Why does my toaster ony toast one side of the bread
Because the nichrome wire on one side of the toast has broken.
Its time to get a new toaster.
Mar 17, 2015 | Baking
What shouldn i makenfornbreakfast
French toast is nice. You need white bread, 2 eggs, 1 cup of milk, a little sugar, vanilla, and cinnamon. wisk it all together, dip the bread about ten seconds a side and fry on medium heat with a little oil. Makes about 8 to 10 slices.
Dec 27, 2014 | Cooking
Hello After washing my toaster oven screen that I lay the bread on for toasting, the bread now sticks on it when I toast it
Hi, you may have some detergent or soap left on the screen that is causing the bread to stick to it. Try rinsing it heavily with water to remove any residue. If that doesn't work, try spraying the screen with Pam or a similar non-stick spray.
Oct 07, 2010 | Euro-Pro Toaster Ovens
Russell Hobbs RH2T toaster bread won't stay down w/o hold handle
Hi, most new toaster have a selenoid that hold down the handle while toasting then release when done so a spring bring the toast up. Possible problem with the selenoid, the electronic circuit that controls it or the plate that the selenoid holds. When you lower the handle you close the contacts of the AC line inside the toaster so if the handle is raised there is no power.
Aug 04, 2009 | Kitchen Appliances - Others
How can I clean the inside toaster rails
Hi rsands1,
The following link will help you maintain a clean and good toaster,
Nov 02, 2008 | Dualit CTS4E 4-Slice Toaster
Sandwich maker recipes
Found this on another website... not sure where... just had it copied to my word document... but here it is.
Warm up sandwich maker first…. Then spray with cooking spray.
Fruit pies
Two pieces of bread and apple pie filling (2 Tbsp)… cook 2-4 min Sprinkle with cinnamon and sugar when done.
Hot pocket
Ham and cheese
Egg Sandwiches
Egg Bacon and Cheese sandwiches
French toast… batter and cook, sprinkle with cinnamon and sugar? Cover in syrup
Pizza pockets
Cheese sauce and pepperoni
Mexican Fare
Using Tortillas add meat, cheese, or peppers
You can use…
Pancake mix
Muffin mix
Cornbread mix
Stir and pour into the sandwich maker Cook until done a few minutes.
Jun 30, 2008 | Salton Snack n Sandwich SA8 Sandwich Maker
Duraband 4 slice toaster manual model # TS-5221
if u need a manual for a toaster, then u r really in trouble...espcially for the amt of money u paid for it.
if u need instructions on how to use a goes:
A toaster is used to heat slices of bread, bagels, waffles, etc. to a hot, crispy consistency. Most toasters allow the user to set the toasting length to ensure the toasted bread comes out to temperature and crispiness to the user’s likes.
Toasters should be used on a flat, uncluttered surface near an electrical outlet but far from sinks, or running/standing water.
To toast bread in a toaster, follow these instructions:
1. Place slices of toast, one each, in the slots on the top of the toaster.
2. Find the toast setting (a knob or lever) and adjust to the desired wellness of the toast. (Generally, there is a scale printed near the knob or lever ranging from light to dark toast).
3. Push down the toasting lever (moving the slices of bread down into the toaster between the heating elements.
4. When the toast is finished, the slices will “pop” up automatically.
5. Remove the toast from the toaster.
If the bread should get stuck inside the toaster, DO NOT PUT ANYTHING INSIDE THE TOASTER in attempt to dig it out. UNPLUG the toaster, turn it upside down and shake. If the toast does not fall out, use a plastic fork or knife to gently remove it from the toaster. Using metal utensils could damage the heating elements. NEVER stick anything in the toaster while it is plugged in.
*For further safety, it is recommended that the toaster be unplugged after each use.
I wish u luck and happy toasting.
Oct 14, 2007 | Kitchen Appliances - Others
KitchenAid KMTT400-SS 4-Slice Toaster Logo
167 people viewed this question
Top KitchenAid Kitchen Appliances - Others Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Appliances - Other Expert? Answer questions, earn points and help others
