Question about Cuisinart DCC-2200 14-Cup Coffee Maker
Cuisinart 14-cup coffee maker won't put out coffee
Everything seems fine, but the water doesn't boil up like it used to. Now it just splashes up haphazardly. Almost no coffee ends up in the carafe. Any thoughts?
  • 8,596 Answers
Clean it out with 1/3 caraffe worht of vinegar and 2/3 caraffe full of water - just brew the solution as if it were regular coffee - you may have to repeat this process up to 3 times.
-Tha Mp3 Doctor
Posted on Mar 20, 2009
Cuisinart coffee center, ss-15, lights are flashing on cup sizes, and won't make single cup coffee.what to do?
We have the Cuisinart combination 12 cup coffee maker with a 6,8,10 K-cup maker. Today 8/06/2017 the K-cup started making a strange sound stopped working and all 3 blue lights 6,8,10 where flashing and wouldn't make a cup of coffee. After some looking around it seemed that the top stainless steel water injector was clogged, I took a long toothpick and slowly pushed it in as I spun the toothpick around slowly as to not break the toothpick off inside, the water injector is sharp so the toothpick will fray as you spin it around inside this is why you must go very slowly. I also did the same to the K-cup holder stainless steel spike tube to make sure everything was clear and clean, I then ran 4 full water containers through the K-cup system starting with the 6, than 8 and 10 oz. size. I was finding little black objects in my 20oz drinking cup as I was doing this, not sure what that was but after running the 4 full containers through it they were gone. Now it works fine. I hope this helps anyone with the same machine having the same problem
Feb 13, 2017 | Cuisinart Coffee Makers & Espresso...
Why won't the hot water empty into the coffee pot?
Make sure your caraffe has its lid on , and check the bottom of the filter. it usually has a valve preventing coffee from leaking when you remove the caraffe. the lid pushes the valve back open when you place the caraffe back into the machine.
Jul 10, 2012 | Cuisinart DCC-2200 14-Cup Coffee Maker
My two year old Cuisinart 14 cup just started smoking from out of where cord comes out. Is there a recall on this. There are a ton of complaints that they catch on fire
Here is a link to the Cuisinart support site: http://www.cuisinart.com/support/us.html
After unpluging the coffee maker and making sure that no one will attempt to use it please contact Cuisinart to see if the DCC-2200 is on the recall list. If it is not, you should consider installing a new power cord with at least 14 gauge wire....this is assuming that you are comfortable doing this sort of repair. Otherwise, replace the coffee maker! Fires from electrical problems are responsible for too many deaths to take any chances with an appliance that smokes when plugged in!
Jan 15, 2010 | Cuisinart DCC-2200 14-Cup Coffee Maker
Won't finish brewing
We were having the same problem of it quitting the brew cycle about 1/2 way through. We put a mixture of 5 cups vinegar & 5 cups water through followed by a pot of just water and now it works like new. The vineagr must clean some sort of built in sensor.
May 30, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
After taking out the filter basket and all the moveable parts, how do you clean the coffee maker itself?
You actually have to put the parts back in place (except the charcoal water filter and any paper filter you may or may not be using), pour in 2 cups distilled white vinegar and two cups water, and brew the vinegar/water solution just like it was coffee. Vinegar is very acrid, so you will then need to brew plain water to flush out the vinegar. Now, you can put everything back in place, and you are good to go. Remember - if one part is out of place, your coffee maker may beep at you incessantly.
-Tha Mp3 Doctor (also loves Cuisinart)
Feb 21, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Leaks water from the bottom
Under warranty. Cuisinart will resolve. Thank you.
Dec 08, 2008 | Cuisinart DCC-2200 14-Cup Coffee Maker
Will not brew after a power failure
The parts to repair a problem of this magnitude are generally not available. The DCC-2000 has a thre-year warranty. I would call Cuisinart and see if you can get an in-warranty replacement. I have a high opinion of cuisinart and their products, but this particular coffeemaker, I do not personally reccomend.
-Tha Mp3 Doctor````
Jul 14, 2008 | Cuisinart DCC-2000
Cuisinart 12 Cup Digital Thermal Coffemaker
I called Cusinart support and they told me to fill with 2 cups of white vinegar and the rest water, let set for three hours. Did that. Had to keep hitting the on button to get this solution through. Then used a solution of one cup of vinegar and water and this ran through the whole cycle. Ran three more with just water and now it works just fine. Brewed coffee this morning with no problem. Didn't think this would work but seems to have solved the problem. They do suggest you decalcify once a month using the vinegar solution...hope I remember to do this as it would be a lot easier than having to get hitting the on button. Good luck!
Dec 24, 2007 | Cuisinart 12 Cup Digital Thermal Coffee...
Cuisinart DCC-2200 14-Cup Coffee Maker Logo
257 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Marvin
Marvin
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
